Loose front shock on top mount cause of my noise?
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Aug 25, 2022.
  1. Aug 25, 2022 at 1:29 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I was driving along today and it hit me what my mystery noise sounds like. It sounds like the top of the shock is loose and moving up and down a bit on the top mount? When I had 5100's put on my F-150 they didn't tighten the tops while on the ground and that is similar to what it sounded like. It is kind of a muffled popping noise and more prevalent over bumps and when I hit the brakes. I bought this current truck used and I think it is all stock but it might not be IDK.
    Anyone have experience this or am I back to smoking my socks looking for a cause.
  2. Aug 25, 2022 at 2:03 PM
    okietundra18
    okietundra18 New Member
    Green Country
    2018 Ltd OR
    Check the wiring harness on the front of the passenger firewall. That’s what mine was and that’s what the noise sounded like. There are threads on here where it’s discussed. The wiring harness falls off of the support bracket and flops around over bumps causing that noise. Zip tie in place.
    IowaGuy[OP] likes this.
  3. Aug 25, 2022 at 2:13 PM
    IowaGuy
    In Process
    Thank you, I will check that and I am hoping that is it. It sometimes sounds like it is inside the cab and sometimes like it is outside. I will do a search on here too.
  4. Aug 25, 2022 at 2:24 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Jack the truck off the ground and start shaking things by hand?
  5. Aug 25, 2022 at 2:39 PM
    IowaGuy
    In Process
    That is on my to do list. It mostly happens while braking though so I am wondering if it is a brake caliper, shoe or ball joint end and like it is pre-loading beforehand. I will see if I can shake it out.
  6. Aug 25, 2022 at 2:58 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    zipties to pull the bundle of wires in tighter towards the metal bracket. This solved a rattle that I swore was in passenger side dash while driving. Pop the hood and look passenger side of the firewall. I had thought there was some loose chunk behind the glovebox from the sound. This was happening at certain speeds or bumps. May not be same thing you have going on.
    Look around sway bar end links for shiny metal that might mean it's bumping when positions are just right.
    HulkSmurf14 likes this.
  7. Aug 26, 2022 at 5:14 PM
    IowaGuy
    In Process
    Holy Tundras, I think this might have been part / all of the solution. I cannot believe that connection bundle made that much noise even though it seemed tight in the factory connector. I used a large zip tie and a piece of rubber to wrap around the bundle and secured it like pictured above.
    I also removed the plastic cover that was on top of a metal box wire cover thing under the passenger seat. It was only held on with a couple of plastic push pin connectors and was loose and rattling.
    I secured the cover on the plastic box next to the wire bundle pictured above. The cover was pretty loose and would rattle when shook.
    I tightened the 4 body mount bolts under the cab
