Looks suspicious?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Daddio Rick, Apr 25, 2023.
  1. Apr 25, 2023 at 4:50 PM
    Daddio Rick
    Daddio Rick [OP] New Member
    2016 Platinum
    So I am looking to purchase a 2016 Platinum with 80k miles. Seems to bee in great shape. However the driver seat side panel which I assume covers an airbag has a weird zip tie on it. Thee dealer told me that the 2016 commonly had trouble with that panel and if I would get one off ebay they would install it. But thee more I think about it I am wondering if this would indicate the airbag had been deployed. Any thoughts?
  2. Apr 25, 2023 at 4:52 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Seen some posts on here about people who have had that panel fall off.
  3. Apr 25, 2023 at 4:57 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Not so much; most airbag deployments will show up on a car history report. That piece did have a few years where they were problematic, but they'll also snap if someone slides off the seat and down onto that plastic part repeatedly as they are getting out of the truck (basically being lazy about sliding out of the seat to their feet instead of stepping out of the truck if that makes sense).
    The part is held on by a combo of plastic and metal clips/pieces, so you'll want to take a peek at the attachment points and see where it failed to make sure you're getting what you need in parts. Pay attention to the right side (as depicted in the orientation of the photo), as there is also some pieces that will snap off in the area where the seat bottom ties to the seat back. Just tell the dealer that you want to snip the zip-tie to verify what's actually damaged and then look under the front of the seat at the clips that secure that part that point down to the floor during your inspection.
    Bottom line is I wouldn't allow it to be a deal breaker if everything else about the truck is right for you :thumbsup:
    Demented Canine and panicman like this.
  4. Apr 25, 2023 at 7:15 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Based on who I see on that dealer tag in the photo, I wouldn’t be surprised if they zip tied it themselves.
  5. Apr 25, 2023 at 7:15 PM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    The clips that hold that piece on are very weak and brittle. Most people break them when installing seat covers trying to tuck the edge down in that crevice
    Probably an expensive part so I'd price it before you make a decision
    1lowlife likes this.
  6. Apr 25, 2023 at 8:00 PM
    White 2.5
    White 2.5 New Member
    Mt P, SC
    2020 White DC
    With 80k, I suspect that the leather on the lower seat has been replaced recently. Would expect to see wear and tear on the leather with that mileage, and it’s not there. As a result, the clips broke due to impatience is my guess. If that’s all that is wrong with the truck, I wouldn’t worry about it. The plastic piece can be replaced with ease.
  7. Apr 25, 2023 at 8:07 PM
    Airbag is in the seatback I believe, not the seat bottom. Sliding out of the truck puts pressure on that piece and the plastic clips behind it break as others have mentioned. Order a new panel and replace if you like the rest of the truck. The one in my FGT is like that also. The new 3rd gens have issues already with this piece breaking.
    panicman likes this.
  8. Apr 25, 2023 at 8:10 PM
    Maybe clip those zip ties off and put some glue or double stick tape on the metal bar.
  9. Apr 25, 2023 at 8:15 PM
    You could try these....
    4/5" 100 Pack Zip Tie Mount With Cable Ties,Self Adhesive-backed Mounts For Wire Holder , Black Cable Management Clips Wall Anchors https://www.amazon.com/dp/B07Z79LHJC
    50 Pieces Cable Management Desk Wire Organizer Cable Ties Zip Ties Adhesive Cord Clips Cord Keeper Desk Wire Management https://www.amazon.com/dp/B075Y9J42T
    Just cut off the excess.
  10. Apr 25, 2023 at 8:48 PM
    TRD VO
    TRD VO Fix It Again, Tony
    Louisiana
    2015 Inferno CrewMax TRD Pro
    Wouldn't worry about that. :thumbsup: Work a deal out if you can for them to replace it and go for it! Most likely retaining clips or panel itself is just damaged from previous owner or people test driving and getting in and out of the seat and just dragging themselves in/out across the seat bolster and down onto the seat side panel trim causing damage, especially if there's no running board/side steps along with no driver side A-Pillar grab handle mod on the truck to help getting in/out.
    NewImprovedRon and panicman like this.
  11. Apr 25, 2023 at 9:45 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    The airbags come out of the seat bolsters, they literally split the seat covers at the seams and blow the foam apart and all over the cabin.
    Looks like that panel broke and someone patched it back with zip ties to me.
  12. Apr 26, 2023 at 4:48 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I would have the dealer replace it as part of the deal.
  13. Apr 26, 2023 at 4:57 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    That's exactly what I thought. Someone changed the seat cover and busted some tabs.
  14. Apr 26, 2023 at 11:34 AM
    WaterTrash
    WaterTrash New Member
    Common problem with that panel, someone just did a shoddy repair. There are whole threads about it on here with some really nice repair jobs.
    Use it as leverage to get the best deal
  15. Apr 26, 2023 at 11:50 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    I would hate to get snagged by that sharp ziptie.
    My 2018 passenger side has this problem. Seems like a common issues.
  16. Apr 27, 2023 at 4:00 AM
    Daddio Rick
    2016 Platinum
    Thanks all... bought the truck and love it... dealer offered to install if I find part on ebay but just gonna live with it. I drive my Tundras til wheels fall off or in case of my 2006DC the frame rusts out and completely cracked both sides just ahead of rear. This after I drove it 14 years.
    NoMoreGreen and TRD VO like this.
  17. Apr 27, 2023 at 6:52 AM
    TRD VO
    Louisiana
    Congrats on getting the Platinum! :burnrubber:
  18. Apr 27, 2023 at 7:34 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Treat yourself and replace the part.
    No need to have that shabby look for your new to you truck.
    If you have ventilated seats, and I think you might, this is the part.
    Google search the part #, you might find it cheaper.
    71812-0C222-C0 - Seat Back Recliner Adjustment Mechanism Cover (Left, Front) - 2014-2020 Toyota Tundra | Sparks Parts
    If no ventilation, it is this one.
    71812-0C212-C0 - Seat Back Recliner Adjustment Mechanism Cover (Left, Front) - 2014-2020 Toyota Tundra | Sparks Parts
    The plastic clip on the inside breaks, it snaps to the frame piece you can see in your pic.
    There is also a screw that attaches that metal frame piece to the trim piece, it goes in from the inside under the seat.
    It breaks from the weight of the driver on and off that trim piece over the years.
    You can see the crease in your part at the rear because of the flexing.
    Replacing the part fixes it.
    I've also had the screws snap off the frame on that metal piece in your pic, but I don't think that is your issue unless that part is loose.
    Post #4 in this thread has videos showing you how to get that trim piece on and off.
    The videos start at the needed time, you don't have to watch the entire thing.
    The thread is about the screws snapping, but the videos show the removal of the trim piece.
    Mystery bracket | Toyota Tundra Forum (tundras.com)
    It might make it easier to remove the seat bolts and lean it back, but you don't need to take the seat out of the truck..
    Good luck..
    n0rth likes this.
