Looking to tow 8100lbs with 794lb hitch weight
Discussion in 'Towing & Hauling' started by memurphy71, May 26, 2020.
  1. May 26, 2020 at 10:52 AM
    memurphy71
    memurphy71 [OP] New Member
    mark
    2018 Tundra TRD 4x4 Crewmax
    Hi all. We are in the process of buying a Grand Design 3170BH..the dry weight is 8100 pounds and the hitch weight is 794lb. We are also adding the Equalizer weight distribution hitch. I have been back and forth on my 2018 CrewMax TRD 4x4 capability of towing this..Anyone tow something similar in size?
    Thanks!
  2. May 26, 2020 at 11:11 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Cpl_Punishment likes this.
  3. May 26, 2020 at 12:10 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Moved your thread to the towing section.
    NewImprovedRon likes this.
  4. May 26, 2020 at 12:23 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Oh man here we go again....
    Tundyfundy likes this.
  5. May 26, 2020 at 12:23 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    That is a heavy trailer for any half ton, especially the tongue weight loaded. I would recommend a different trailer or a heavy duty truck.
  6. May 26, 2020 at 12:35 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Too much trailer for the tundra imo.
    Probably could tow it, but you might be white knuckling it the whole time and that's not a good beg/end to a camping trip.
  7. May 26, 2020 at 1:01 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    We've been looking at Grand Design too. The 3170 is big for a bumper pull (and a 1/2 ton truck). 36' 11" and gvwr 9500 lbs. But it IS a nice rig.
    Right now we like the 2670MK, which is still heavier on the tongue than I'd prefer at 690 (gvwr 8500, 32' 3" total length) and the 2250RK which is a more manageable 515 on the tongue and gvwr of 7500 @ 27' 11".
    Obviously, we don't have kids to tote around, but according to the decal my truck only has 1270 lbs of available payload, and I'm already using 70 of that with my bed cover. Less me and the wife, and we only have about 900 total to spare.
  8. May 26, 2020 at 1:04 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Time for a 3/4 ton.
  9. May 26, 2020 at 1:16 PM
    Jernik
    Jernik New Member
    Jeremy
    If only Toyota made one. *sigh* :pout:
  10. May 26, 2020 at 1:43 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    I had a Nash 26x. The dry hitch weight was 750 lbs. by the time I loaded it for travel, my hitch weight was 1,150 lbs. Even with my 3/4 ton Ford I needed air bags. I would not recommend any travel trailer with a hitch dry weight of over 650 lbs.
    Tundyfundy, jtwags, Jernik and 2 others like this.
  11. May 26, 2020 at 1:50 PM
    Ask one of your friends that have a flatbed trailer, or TT with the approximate weight.
    If you find someone with a flatbed trailer rated at 10k or more...just load their truck on it and hook up and go.
    Enjoy your new truck.
  12. May 26, 2020 at 9:44 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I have a Grand Design 2800BH. It is 6200# dry and 600# hitch. When realistically loaded it pushes my 16 Crewmax to the rated limits, and that is without water or waste. That large of a trailer with a Tundra could be a dangerous combination. Keep in mind the the Equalizer WDH does not increase the capacity of your truck. Please consider a lighter trailer or a 3/4 ton+ truck.
  13. May 30, 2020 at 7:36 PM
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    That sounds like it might be pushing the limits of a Tundra. It could tow it just fine, but you might run into trouble with stopping it in an emergency or controlling the trailer going down the interstate when a storm rolls in. I would vote to look at something a little more manageable with these trucks.
    No fun to have a white knuckle experience every time you take your camper out!
    GODZILLA and Cpl_Punishment like this.
  14. May 30, 2020 at 10:19 PM
    Silver4x4trd
    Silver4x4trd New Member
    2017 Tundra SR5 & 2012 Sequoia SR5
    Jba long tube headers, dirty deeds TRD exhaust (2x24), 19+ Pro lights and grill painted sky silver, TRD rear sway bar, TRD reusable air filter, PnP sliders, pnp full set skid plates, 275/70/18 ko2’s, bully dog bdx (trail setting), c4 hybrid bumper with DD lights(sae fog and driving)
    Calling the payload police!
  15. May 30, 2020 at 11:46 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    If you do buy the trailer just make sure you wear your brown pants when towing.
  16. May 31, 2020 at 12:23 AM
    NHPig
    NHPig Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    Too much for a CrewMax, pushing the limits on a DC or regular cab.
  17. Jun 4, 2020 at 8:40 PM
    cforman61
    cforman61 Pupper
    Chuck
    Highlands Ranch, Colorado
    2019 Tundra SR5 TRD CrewMax
    We have a GD 2670MK that we pull with our Tundra and it pulls it fine. That was the largest I was willing to go with my truck. I have added a rear sway bar and air bags and will be upgrading my tires soon. The Tundra has no issues with towing the trailer but I am careful about how much and where I load things in my trailer.
