Looking to see how much to make it 4x4
Discussion in '2nd Gen Tundras (2007-2013)' started by Thetundra775, Oct 26, 2019.
  1. Oct 26, 2019 at 11:03 AM
    Thetundra775
    Thetundra775 [OP] New Member
    David
    2008 gray tundra
    None
    New here and on this truck just wondering what I need to make it 4x4 if you have any pics they are welcome thanks
    roy2015 likes this.
  2. Oct 26, 2019 at 11:18 AM
    15whtrd
    15whtrd Mr. Blonde
    I think it would probably be cheaper to find a 4 x 4 truck that you like. Otherwise you’ll need a donor for sure. Sorry to be that guy LOL
    Welcome from SoCal
    Rica25, Pinay, NewImprovedRon and 2 others like this.
  3. Oct 26, 2019 at 11:21 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Just off the top of my non mechanic head:
    New transmission, front driveshaft, transfer case, axels, ecu, and a whole lotta other stuff + labor.
    Rica25, Prostar 190 and 15whtrd like this.
  4. Oct 26, 2019 at 11:22 AM
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    Hate to say this, but if you have to ask you probably aren't prepared to undertake something like a 4x2 to 4x4 conversion. No offense intended, its pretty complicated.
    Rica25, Pinay and JohnLakeman like this.
  5. Oct 26, 2019 at 11:27 AM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    Sell truck buy 4x4.
  6. Oct 26, 2019 at 11:35 AM
    AZTundra
    Paul
    Phoenix, AZ
    A job, some cash, and about 3-4 hours at a dealership and you can drive one home. :burnrubber:
    Sorry, but that's going to be an easy swap. As others mentioned, probably not worth the hassle to convert. Sorry for the bad news.
  7. Oct 26, 2019 at 12:04 PM
    Not worth the time sorry. Oh welcome from Ohio.
  8. Oct 27, 2019 at 10:53 AM
    Dr_Al
    Dr_Al New Member
    Al
    I would doubt the frame is the same. That alone would be a massive job to swap. Maybe the mounts could be removed and the correct ones bought from Toyota but mounting them in the correct spot but not without plenty of work and having a 4wd frame to measure off of. Then there's the hit on value. I don't see many people wanting to buy a home converted 4wd vs a factory one for the same money. So that really means trying to find a wrecked one in a junk yard that has all the parts you need. A rolled over Tundra that runs and drives would be your best option. Then you could remove your cab and bed and put it on that truck. A lot of work.
  9. Oct 27, 2019 at 11:20 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The parts list is pretty long. Not worth the work unless you get all the parts for near free
    Transmission
    New drive shafts front and rear
    Trans case plus cross member I believe
    Front diff
    Spindles
    Cv shafts
    Wiring
    New ecu
    Many more little little parts
    Ive thought about it many times as my truck is in prime mechanical condition. It doesn’t make sense to swap transmissions as that is half of the reason to keep my current truck. If im willing to gamble on a used transmission, I should just gamble on it in another entire vehicle
  10. Oct 27, 2019 at 11:46 AM
    15whtrd
    15whtrd Mr. Blonde
    The amount of money you will probably have to spend on the conversion could just get you into a 4 x 4 truck with trading yours in. Or you spend the money on a real 4 x 4 rig made for hitting the trails. A small Toyota 4 x 4 pick up would be my choice.
    Rica25, NewImprovedRon and Hbjeff like this.
  11. Oct 27, 2019 at 11:49 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Or buy a utv if that would work for you
    Rica25 and 15whtrd like this.
  12. Oct 27, 2019 at 11:51 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm planning to do it on my first gen, but planning to gather parts over the next 2 or 3 years and do it if (when) my trans goes out. I'll do it by myself though so labor is free.
    I figure parts will put me back around 3k. The average joe will pay that for a shop to swap a trans so doesn't sound painful.
    15whtrd likes this.
  13. Oct 27, 2019 at 11:59 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    First gen should be much simpler due to parts availability and less tech to deal with
    Darkness and 15whtrd like this.
  14. Nov 4, 2019 at 6:50 PM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    It's expensive to convert a 2WD to a 4x4. Sure it can be done, but like everyone else has said... sell yours and buy a 4x4.
