Looking to lift my tundra with a 3" leveling kit
Discussion in 'Suspension' started by MattyScones, Jan 24, 2018.
  1. Jan 24, 2018 at 12:11 PM
    MattyScones
    MattyScones [OP] New Member
    2014 Tundra 1794
    Flowmaster Outlaw Exhaust
    Can you fit 35's or should I go with a smaller tire like a 275/65 20?
  2. Jan 24, 2018 at 1:14 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Depending on offset, might need CMC. If you haven't picked a lift, check out @ToyTec Lifts
    Black Wolf and T-Rex266 like this.
  3. Jan 24, 2018 at 1:23 PM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    You might be able to squeeze 35s in with a 3” but you’re gonna be doing some trimming.
  4. Jan 24, 2018 at 3:28 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I'm running 305 70 18s on 3" lift, wheels are +18mm offset. I rub at full turn in reverse and forward. Haven't done the bmc yet.
  5. Jan 24, 2018 at 5:48 PM
    I have the same setup. Trim ur skid plate too; or replace it with something else.
    Berdine[QUOTED] likes this.
  6. Jan 24, 2018 at 5:57 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    We have seen a lot of people run a true 35 on their Tundra with our 3'' kits, but the catch is that you are going to have to do trimming, so if you are not wanting to do that we would recommend getting with your local tire shop to do some test fitting on your truck to insure proper size fitting the first time without any issues.
    Let me know if you have any other questions!
    Thanks!
    TXMiamiFan, Black Wolf and T-Rex266 like this.
  7. Jan 25, 2018 at 1:41 PM
    Berdine
    Binghamton, NY
    1 thing to consider is your budget. Yes a spacer lift is cheap and will be quick to install 35s, but you'll sacrifice ride quality.
  8. Jan 25, 2018 at 1:48 PM
    My Tundra came with spacers and I couldn't get rid of them fast enough.....
  9. Jan 25, 2018 at 4:50 PM
    OP... Welcome from Texas!
  10. Jan 25, 2018 at 7:44 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Welcome from eastern CO! I’d recommend a suspension lift w/ coilovers, rather than a leveling kit.
