Looking for TRD OR front struts
Discussion in '2nd Gen Tundra Parts Marketplace (2007-2013)' started by TechWrench, Nov 2, 2020.
Thread Status:
Not open for further replies.
  1. Nov 2, 2020 at 10:05 AM
    TechWrench
    TechWrench [OP] New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    I have an '08 DC 5.7 4wd with the TRD Off Road package, and am looking for a set of used take-offs to replace mine. I have both front springs broken, and am looking for an economical replacement set. I live in North East PA, so if someone near by has a set they are willing to part with, please PM me.
    Thanks
  2. Nov 2, 2020 at 11:10 AM
    biebs96
    PA
    I have the shocks only with 33k on them if you are able to locate springs
  3. Nov 2, 2020 at 11:19 AM
    TechWrench
    Gary
    Hawley, PA
    Thanks for the reply, but that seems to be my problem. Very few options for springs. OEM springs are $160 + per side, and not much available aftermarket less than that, that I would trust. And then I would need to remove shocks, disassemble to remove/replace springs, and reinstall. I was hoping for an easier option.
  4. Nov 2, 2020 at 9:52 PM
    TechWrench
    Gary
    Hawley, PA
    OK, I need a bit of clarification if someone knows. I was under the assumption, since I see them listed that way, that the front struts were specific for each side, L/R. On the Toyota parts sites, there are two different parts numbers for L/R, and there are two different part numbers for the L/R side coil springs. I had an online salvage yard just tell me that the front struts are interchangeable between sides when I tried to get them to clarify the description on a TRD Off Road strut they were offering for sale. Were they giving me a line, or is there a way to reconfigure a strut to fit either side of the vehicle?
  5. Nov 2, 2020 at 10:04 PM
    The only thing I could think of being different would be if they were calibrated to account for the Tundra lean.
    I think you should also be able to use 3rd gen parts for these, because the basics of the truck haven't really changed since 2007. Hell, Toyota still considers current tundras to officially be 2nd gen. If you can use them that would greatly increase your market for take offs. You might even be able to contact local shops and dealerships to see if they have any take offs they'd let go for cheap.
    Full disclosure: I could be wrong about the parts being interchangeable left to right, and even between model years.
    Tundyfundy likes this.
  6. Nov 3, 2020 at 12:06 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I may be wrong but our truck doesn’t have struts. We have could over shocks. Maybe semantics but it may help you narrow your search. If you broke both springs maybe get something a bit tougher. I upgraded to the 6112’s and love them.
  7. Nov 3, 2020 at 6:16 AM
    TechWrench
    Gary
    Hawley, PA
    The front suspension support device in my truck is a coil spring mounted around the front shock. I have always called this type of combined suspension component a strut. If one has a coil spring mounted around the rear shock, it is usually (IMHO) called a coil over shock. When looking for these front suspension components on most parts sites, the unit without the coil spring attached is usually called just a shock while the combined component is usually listed as a strut. In any case, I am looking for the entire assembly, the shock, with the coil sprint mounted to it and a bearing top mount (So the entire device can rotate with the knuckle when the steering system turns the front wheels).
    I don't know why both font springs broke in the same place, but I am beginning to suspect the struts (shocks) are not the original equipment. All of the TRD front shocks I have seen listed are yellow in color with black coil spring. The shocks on my truck are black with a black spring. I haven't yet, but I intend to take a closer look at them to see if there are any identifying markings on them. I have only owned this truck for a year, and the original owner may have replaced the original equipment with aftermarket parts.
    In any case, whatever one calls them, I am looking for the entire front shock/coil suspension unit.
  8. Nov 3, 2020 at 7:06 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Our trucks have front coilovers (coil over shock) and upper control arms. Struts are used in place of a coilover and UCA combination. The strut bolts directly to the knuckle.
    Leo's first and Tundyfundy like this.
  9. Nov 3, 2020 at 9:16 AM
    TechWrench
    Gary
    Hawley, PA
    OK, thanks for the clarification. As I said earlier, many parts sites, for whatever reason tend to call these components 'struts', so I just went with it. I have always believed you are never too old to learn something new. And today was one of those days.
    Thanks. Now if I can just find a pair of coil over shocks for my truck..............
  10. Nov 3, 2020 at 10:42 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    The original TRD off road package shocks on mine were yellow, made by bilstein. If yours are black, it may not be the original TRD OR package shocks.
  11. Nov 3, 2020 at 5:56 PM
    Tundyfundy
    Bay Area, CA
    Original TRD shocks are bilstein 4600’s
  12. Nov 22, 2020 at 11:29 AM
    TechWrench
    Gary
    Hawley, PA
    Thanks to a member, I have a great used set of TRD Off Road coilovers, and finished installing them yesterday. Now onto the crossmember replacement.
Thread Status:
