Looking for tow mirrors!!!
Discussion in '1st Gen Tundras (2000-2006)' started by itscoreyc, Jul 12, 2020.
  1. Jul 12, 2020 at 4:07 PM
    itscoreyc
    itscoreyc [OP] New Member
    Corey
    QC
    2001 Tundra V8 4WD sr5
    3" lift 33" x 10.5" ko2s
    So i would like to get tow mirrors for my tundra.. really dont like clip on slidy over mirror thingy things. i heard some dodge ram mirrors could fit.. dont know what years anyone have any info on this ?
  2. Jul 13, 2020 at 4:06 AM
    Professional Hand Model
    Hand Protectors
    Whats your thoughts on the little stick on convex bubble mirrors that attach to your OEM mirror surface?
  3. Jul 13, 2020 at 9:59 AM
    itscoreyc
    Corey
    QC
    Bandaids
  4. Jul 13, 2020 at 12:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I also hear that 2005-2015 Tacoma trail ridge towing mirrors may fit with some manipulation as those are the ones I’m going to buy soon and try. They are identical to the dodge mirrors
    04TundraTRD and FrenchToasty like this.
  5. Jul 13, 2020 at 4:58 PM
    04TundraTRD
    04TundraTRD Once upon a time....
    Neil
    Kentucky, near Louisville
    2004 Tundra TRD 4WD AC
    Bilstein 5100's on all four corners, Setting 4 on the fronts, 1" Front Diff Drop Kit, Suspensionmaxx Front Sway bar end links, 1" lift shackles out back, 1.5" wheel spacers all around, 285/75R16 BFG AT TA/KO2's, Front Brush Guard with 20" LED light bar, Kool Vue Dodge style tow mirrors, Yellow Box Speedo Corrrecter by Yellr, Volant CAI, Banks Monster 3” Catback Exhaust, LED's on the interior, LED Headlamps and LED Back Up Bulbs
    I did the dodge mirrors about 5 or so years ago. I’m pretty sure the thread I used was on TS but it looks like all the pics are gone.
  6. Jul 13, 2020 at 5:02 PM
    04TundraTRD
    Neil
    Looks like these may be an even better adaptation than the dodge mirrors due to having the Toyota mount plate. I’d love to see install pics if you decide to get them.
    CodyP[QUOTED] likes this.
  7. Jul 13, 2020 at 8:31 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I would love a set of tow mirrors if anyone found a good solution that doesn’t look like a square peg in a round hole.
  8. Jul 14, 2020 at 12:26 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Problem is that the trail ridge get quite a bit of bad reviews. I may go with another cheaper option off Amazon for the same model Tacoma and see about figment
  9. Jul 14, 2020 at 4:39 AM
    Hand Protectors
    Yeah. Plus tow mirrors look like butt anyways. I’d never put any Dodge or Ram crap (except my sweet tailgate assist:D) on my truck, either.
    Per the overall conversation, I’m not sure why we need a large tow mirror on our trucks as they can only tow such a light load. I done mucho towing with the regular OEM mirror with the convex mirror stickies on both sides. Work really well. I don’t need to see behind my trailer when driving forward. Just need that side blind spot opened up thats always there tow or not.
    Anyways, when backing up just make sure you sight the spot before backing up into it. I’ve had 18 years of success without incident except that one time I backed into a Fords tow mirror and ripped it off. :rofl:
    Edit: Spellings. True Stories.
    D4x4TRD and FrenchToasty like this.
  10. Jul 14, 2020 at 5:36 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Tow mirrors are required for loads wider than the truck. Doesn’t matter how heavy it is.
    zingvs, JustJake, FirstGenVol and 3 others like this.
  11. Jul 14, 2020 at 1:54 PM
    04TundraTRD
    Neil
    I tow a 27’ TT and you can’t beat a good set of tow mirrors.
  12. Jul 14, 2020 at 3:49 PM
    Hand Protectors
    Yeah I don’t have that problem as what I tow is not wider than the truck.
    Good info on the requirements for tow mirrors, as I did not know this.
  13. Jul 14, 2020 at 6:44 PM
    04TundraTRD
    Neil
    I don't know that its necessarily a requirement but when you cant see whats next to your trailer it makes towing that much more difficult. I have used the clip ons and they just flat suck, the next thing i tried was a set that seemed promising - they had a housing that slid over the stock mirror but they were too small for my liking, after a lot of thread searching I found the "Dodge Tow Mirror Upgrade." I have been very pleased with my mirrors, they have been installed for 5+ years now. I still have my stock mirrors boxed up. The best part about the tow mirrors is that I was able to get power and heated ones. They do buffet but are far better that any other option I could find. The brand I ended up using are Kool Vue. I hope this helps in the decision making process.
  14. Jul 15, 2020 at 4:48 AM
    Hand Protectors
    Put up some pics.
    04TundraTRD[QUOTED] likes this.
  15. Jul 15, 2020 at 5:05 AM
    Hand Protectors
    I know these aren’t tow mirrors, but they’ve helped me tow or not. No need to twist your neck (taking eye off front road) to see the blind spot. Allows you to keep facing forward. The mirror lets you see almost up to your perpendicular where then your peripheral takes over.
    I’ve used these pictured round ones before and liked them. Had to replace them as a drunk backed into my pass side mirror and knocked it off. Ended up trying the oblong type mirror and it works well, but critical placement on the body mirror is key. Might switch back to the round ones. Been using both styles for about 15 years. Well worth $5-10 cost.
  16. Jul 15, 2020 at 7:32 AM
    04TundraTRD
    Neil
    I’ll try to get some up this afternoon.
    P.S. The passenger side is in my profile pic.
  17. Jul 15, 2020 at 3:07 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Too small PHM. I did just order some Akkon Tacoma dodge style mirrors so I’ll see how they fit and work at speed once they get here AND I actually have the time to install at least one of them
  18. Jul 15, 2020 at 6:05 PM
    04TundraTRD
    Neil
    Here are some pictures of my tow mirrors, folded in and out.
    Kevbev 7, Tundra2, T4RFL and 5 others like this.
  19. Jul 15, 2020 at 10:23 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    thanks. Can you give some better pictures of the mounting plate? Did you do anything with the wiring so the heat works?
  20. Jul 16, 2020 at 6:06 AM
    itscoreyc
    Corey
    QC
    Awesome they look great. Definitely the next thing I'll be searching for.
  21. Jul 16, 2020 at 6:31 AM
    04TundraTRD
    Neil
    If I can get some free time this weekend I’ll pull off the inner door panel and get picture of the mounts and harness. My truck already had heated mirrors so it was just plug and play for the heat. I had to cut the power harness off of my factory mirrors and do some testing to get the mirror adjustment directions right.
  22. Jul 16, 2020 at 1:31 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    No need to pull them off. Just a closer shot of the mirror and door coming together was all I wanted to see.
  23. Jul 16, 2020 at 2:02 PM
    Hand Protectors
    Those tow mirrors look nice for tow mirrors in standard mode. When they go big ear’d its a deal killer. I get the reasons for them being large. Standard mode they look pretty good. Thanks for the pics.
    04TundraTRD likes this.
  24. Jul 16, 2020 at 5:48 PM
    04TundraTRD
    Neil
    Yeah, they don’t go “big eared” unless I’m towing my TT or an enclosed trailer that I can’t see around. One of my pet peeves is the Dodge guys that think they need to leave them up all the time. Side note on the size. I didn’t realize just how much of a difference they made for me until I drove my dads ‘06 that has the dinky little Toyota mirrors.
  25. Jul 16, 2020 at 5:50 PM
    04TundraTRD
    Neil
    I don’t mind to do it. Plus it will give me a chance to do a full write up on the install with pictures.
    Jake92 and CodyP[QUOTED] like this.
  26. Jul 16, 2020 at 10:05 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Im wondering if I wanna mess with trying to get the heat to work as I only have powered mirrors but the heat would come in handy for the winter time
    Tundra2 likes this.
  27. Jul 17, 2020 at 5:09 AM
    Hand Protectors
    I’ve looked into doing this for those occasional St. Bart freezes. Requires lots of work with special relay and timer/etc. Doable, but not worth it unless wiring is already there or you are in on the North Pole.
  28. Jul 17, 2020 at 7:13 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Those were my thoughts too. Being an SR5 I’m sure I don’t have the wiring anyways
  29. Jul 17, 2020 at 1:27 PM
    04TundraTRD
    Neil
    Mines an SR5, do you have rear window defogger? I’ve heard of the mirrors being tied into that circuit.
  30. Jul 17, 2020 at 2:27 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    oh interesting. I do as well. Hmm.... I guess I'll see how many wires are on the body side of the plug. I think the mirrors I ordered have a separate plug for the heat but I'll have to do some testing to see what wire controls what
