Looking for suggestions for tires
Discussion in 'Wheels & Tires' started by eddiefast, Feb 21, 2023.
  1. Feb 21, 2023 at 10:20 AM
    eddiefast
    eddiefast [OP] New Member
    Ed
    Oklahoma
    2022 TRD Pro
    ARE Cap
    Hello.
    I have a 2022 TRD Pro, with the original Falken Wildpeak A/T3Ws: 285/65 R18 SL @ 2601 max load & 51 psi max. (I am generally happy with these tires after 12,000 miles, for multi-use application: 70% highway + 30% mild 4WD off-roading. I run them at 35psi.)
    I plan to soon be pulling my 4500lb (loaded wt) ATC trailer on long trips out west. Including tongue weight I will be maxed out at my allowable truck payload of 1,600 lbs.
    I do not want to change my BBS rims. What tires would you recommend? I am leaning towards the Falken Wildpeak LT285/65R18 10 plys @ 3640 max load & 80 psi max. I figure I could ride them at 50psi when not towing the trailer and 80psi when towing. (I tow a lot of heavy loads with a 1 ton pickup and have found that Michelin 80 psi E-series tires are very dependable. I use Michelin LTX A/T2s.)
    Thanks for any opinions & advice, Ed
    texasrho83 likes this.
  2. Feb 23, 2023 at 5:41 AM
    Boston-Ridgeback
    Boston-Ridgeback New Member
    Chazz
    2014 Oklahoma edition
    Farm truck scratches, dings, and mud. Lots of mud.
    I run cooper discoverer ten plys. They've handled great and lasted longer than my last two sets of tires. My rig is a farm truck that gets beat on down miles of hand made forest and highway contract roads. That's not coynting the super twisty Boston Mountain 2-lane highways.
    That being said. My wife has had toyos on her suburu, and They've out-performed her last set of Coopers. Though they weren't 10 ply I'm still eyeballing them for my next set.
    eddiefast[OP] likes this.
  3. Feb 23, 2023 at 5:54 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I wouldn't run any tires at 50 psi unloaded (that's a ROUGH ride). I have Wildpeak AT3s 305/65-18 and keep them at 30 psi all around and 35-40 psi when I have dirt bikes in the back and tow my utility trailer with three more dirt bikes in it. Towing your 4500lb trailer is heavier but I still wouldn't air up to 80 psi. That's just my two cents worth.
    eddiefast[QUOTED][OP] likes this.
  4. Feb 23, 2023 at 5:58 AM
    Why are you changing tires? Your current tires have plenty of load carrying capacity for your truck and payload configuration. 5200# for the rear axle. Exceeds the rear axle rating by a good bit.
    frichco228 and eddiefast[OP] like this.
  5. Feb 25, 2023 at 1:36 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    this ^ tires on your truck now can handle all the loads and towing that your truck can.
  6. Feb 26, 2023 at 11:17 AM
    Boston-Ridgeback
    Chazz
    I'm more concerned with them holding up to my roads than I am the load. I rarely tow anything extremely heavier than my 2500 lb tractor. I've ran 6 ply of several brands that didn't last more than a few months. My coopers are rumored to cause steering wheel shaking at highway speeds. I've been trying to figure out that issue for a while now. That's why.
  7. Feb 26, 2023 at 11:32 AM
    For your use, you bet. For the OP that I was responding to, maybe not.
  8. Feb 26, 2023 at 2:14 PM
    Boston-Ridgeback
    Chazz
    I misread this in my emails as a response to my ha! In my my defense your answer kind of fits my question as well.
  9. Feb 28, 2023 at 6:37 AM
    Zizyang
    Zizyang New Member
    2020 tundra pro army green
    A little off subject, but can you answer this question for me. I see you running 305/65/18. With the wildpeak. I assume your rims size are 18x8.5
    I have the trd pro rims from a 2020 pro i want to put on my 2014 tundra sr5, have you ran into any issues at all? Discount tire wont put them on, saying the rims is not wide enough. I do have a 3 inch lift with 20 inch rims, but i want to run the trd pro rims at 305/65/18.
  10. Feb 28, 2023 at 6:39 AM
