Looking for something better than bungees
Discussion in 'General Tundra Discussion' started by TommyTundra, Aug 12, 2021.
  1. Aug 12, 2021 at 3:59 PM
    TommyTundra
    TommyTundra [OP] Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Im looking for some kind of system to use with my new Charvonia Design tie downs in the bed. Bungees always stretch out and are generally a bad option imo. I was looking at Nite Ize carabiners with a locking cam. So you clip the carabiner onto the tie down then feed some 3/8 paracord through the cam and just pull it as tight as you need to. Anybody using anything like this or am I just overthinking this???
  2. Aug 12, 2021 at 4:02 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    solid rubber bungee?
  3. Aug 12, 2021 at 4:07 PM
    TommyTundra
    Long Island NY
    2019 PRO
    Just looking for something with a little more solid holding strength but not as much as a wratcheting strap
  4. Aug 12, 2021 at 4:17 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
  5. Aug 12, 2021 at 4:39 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    ARMYGREEN likes this.
  6. Aug 12, 2021 at 6:44 PM
    TommyTundra
    Long Island NY
    2019 PRO
    Thanks guys. Looking at these options
  7. Aug 12, 2021 at 6:51 PM
    CallsignKodiak
    CallsignKodiak New Member
    Bear
    Iowegia
    2021 CrewMax SR5 4x4 Barcelona Red
    Bone stock
    Friction straps. Like ratchet straps in design, but no "locking" ratchet. They hold by friction. Sold about everywhere under different names. Almost as reliable as ratchet straps, which can't be beat.
    Barrett50 and Sunnier like this.
  8. Aug 12, 2021 at 7:14 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    My friend is a fan of "the perfect bungee" which is an all rubber alternative and seem pretty good.
  9. Aug 12, 2021 at 7:18 PM
    Anohibian
    Anohibian New Member
    Anchorage, AK
    2018 Inferno Crewmax
    I use the nite-ize cars you are talking about to secure my kayaks. The work great. Most of the time I use a gladiator cargo net for stuff in the bed of my truck.
  10. Aug 12, 2021 at 7:24 PM
    EglSctAndy
    EglSctAndy MGM Crüe
    Andrew
    Arizona
    2019 MGM Crewmax TRD Sport
    Icon Stage 5 17” Icon Rebound Wheels TOYO Open Country A/T 35 12.5 RCI Heavy Duty Side Step Weathertech Mats 4” Stubby Antenna Fyre Flys Interior LED Lights Plastic Dipped Badges Decked tool box Baja Designs Squadron Sport fog lights
    Check out Stratchits by Front Runner. I think they perfectly blend aspects of bungees and ratchet straps. Very easy to use and store.
  11. Aug 12, 2021 at 8:39 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Damn this site. Yet another thing I never knew existed and now must acquire…
    :spending:
  12. Aug 13, 2021 at 4:06 AM
    EglSctAndy
    EglSctAndy MGM Crüe
    Andrew
    Arizona
    You’re gonna love them!
  13. Aug 18, 2021 at 7:13 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    https://www.rollercam.com/
    Used these a ton over the last week while moving. Quick and easy, and the different end options give you lots of different ways to secure stuff. I've used all sorts of straps over the years and these are probably the best all-around option I've found. I have six 9-footers, four with standard hooks and two with the loop ends. They come in all sizes for just about anything, even a 40 footer if needed.
  14. Aug 19, 2021 at 5:37 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Check out Rok straps. They have a short "bungee" type section along with a long strap section. very easy to use, and secure loads well.
    I've been using straps of this type for close to 20 years, and they are by far my favorite.
  15. Aug 19, 2021 at 10:31 AM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    One nice thing about all simple cam straps (including these) is that you can roll them up into a self-secured puck when not in use
    https://youtu.be/F2_tbVG1ssk
    Cam straps can also be found with hooks sewn into the ends. I keep 6-8 cam straps in my rig for routine use, along with 4 heavy duty ratchets, depending on the need.
