Looking for pics of your 3rd gen Tundra with just a leveling kit, wheels, and tires. Thanks.
Discussion in '2.5 Gen Tundras (2014-2021)' started by TOYTUNDRA18, Dec 30, 2019.
  1. Dec 30, 2019 at 9:56 AM
    TOYTUNDRA18
    TOYTUNDRA18 [OP] New Member
    Looking for pics of your 3rd gen Tundra with just a leveling kit, wheels, and tires. Especially trying to see how big I can go on the wheels and tires with just a leveling kit. Thanks.
  2. Dec 30, 2019 at 10:13 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    275.65.18 18x9 +12mm, Level kit 2/0
    295.70.18 AT3 XLT
    whodini12, tbutler, yoshi82 and 3 others like this.
  3. Dec 30, 2019 at 10:26 AM
    ptat
    ptat New Member
    Nice! What's your wheels and tires setup?
  4. Dec 30, 2019 at 10:43 AM
    SprinterAE86
    Ian
    18x9 +12
    275.65.18
    ptat[QUOTED] likes this.
  5. Dec 30, 2019 at 10:55 AM
    TOYTUNDRA18
    Planning on just a 2" leveling kit for the front. I'd like to go 35's but I doubt they'd fit. Minimum 33's though.
  6. Dec 30, 2019 at 11:06 AM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    Bilstein 5100’s on mid setting.
    Falken Wildpeaks 275/70
    Vision Nemisis 18x9 +18 offset
    Meanjoe, yoshi82, jpod and 2 others like this.
  7. Dec 30, 2019 at 11:59 AM
    NOLA Tundra
    NOLA Tundra Sandbagging
    Jesse
    2019 Quicksand CM
    3” level leds all around Morimoto headlight and fog light bulbs Flowmaster American Thunder
    Still running factory rims and tires, but have a 3/2 lift level. I left one spacer out on the fronts so it’s still has a small rake to the front. It’s an inch difference from front to back.upload_2019-12-30_13-59-23.jpg
  8. Dec 30, 2019 at 1:44 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    I’m running 33s with no lift at all. So you should be able to fit bigger with a leveling kit.
  9. Dec 30, 2019 at 6:46 PM
    Seafus
    Seafus New Member
    Jeff
    Michigan
    2019 Tundra CM
    Bilstein’s, Vision Fury, 275/70 BFG
    8DE59071-070D-4E7B-B522-D45024C079D1.jpg I went with Bilstein 5100’s middle setting up front only. Vision Fury 8.5x18 wheels +25 offset on BFG 275/70/18. No issues.
    Lextech, Haggis777, yoshi82 and 4 others like this.
  10. Dec 30, 2019 at 6:57 PM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    6112/5100 @ top setting, +3 CB shackles, Firestone Airbags, 275/65/20 Cooper AT3 XLT on stock wheels. I have a 0.75” rake. Tires rubs on front sway bar at full lock.
  11. Dec 30, 2019 at 7:08 PM
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    Readylift 3/1 level kit
    ReadyLift 69-5175 Lift Kit https://www.amazon.com/dp/B00IOYREIK/ref=cm_sw_r_cp_apip_GX5AP6d1FaAH5
    35x11.5 ridge grapplers
    Barely misses cab mount but no cutting of metal
    Slight trim to fender liner behind bumper, could probably use a heat gun and massage it instead
    +20 wheel offset on 20 inch wheels
  12. Dec 31, 2019 at 6:45 PM
    BehindenemylinesCali
    BehindenemylinesCali New Member
    Rick
    NORCAL
    2018 Tundra Platinum
    Locker Down console safe Bakflip MX4 Spray in bed Bilstein 6112 Bilstein 5160 2019 TRD Pro wheels
    Bilstein 612's up front on second to highest setting which I believe is 1.9 inches. Bilstein 5160's in the rear set the same as stock. 2019 TRD Pro wheels.
  13. Dec 31, 2019 at 6:49 PM
    CavBlueTexan
    CavBlueTexan New Member
    Justin
    Tyler Texas
    2019 TRD Sport 4X4 Crew Max
    2.5 leveling kit up front. 33 inch tires were the biggest I could fit with the +18mm offset wheels.
  14. Dec 31, 2019 at 8:18 PM
    mjiminez
    mjiminez New Member
    2019 Cement Tundra TRD
    Installed ADS suspension with total chaos upper control arms Coach Builder shackles running 35x12.50x18 BGF KO2 and SCS RAY 10 wheels
    35 inch tires no rubbing with just a leveling kit
  15. Jan 8, 2020 at 2:04 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100, middle setting
    Ray 10s with 295 70 r18
    gabewhite, yoshi82, tundra_20 and 2 others like this.
  16. Jan 8, 2020 at 2:28 PM
    DRP82
    DRP82 New Member
    Austin, TX
    2015 MGM CrewMax
  17. Jan 8, 2020 at 2:30 PM
    JJcksn12
    JJcksn12 New Member
    Jay
    2025 MBM Limited TRD OR
    3” TRD Suspension Lift
    Toytec Boss, Toytec Shackle on the top setting, SCS Ray 10, 28570R18 Ridge Grappler
  18. Jan 8, 2020 at 2:52 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I leveled mine by hanging the leaf packs under the axle, and I plan to run 33" tires this fall. Pictured here with 32" tires.
    jewsNbrews and JJcksn12 like this.
  19. Jan 8, 2020 at 6:49 PM
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    2019 platinum 4x4 magnetic gray
    Leveled with 6112’s at 2.5”. Rear 5160’s. No shackles yet, but my front is 1” higher than rear. Running Icon 17” with 315/70/r17 with no BMC, just front mud flaps removed. No rubbing, but I am also running a RCI skid plate.
  20. Jan 8, 2020 at 7:02 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    5100's front on middle setting along with coach builder shim. 5100's rear with 1" rear block, rding on stock wheels and tires.IMG_1642.jpg
    Mr_Kane, Taco2aTundra, Jonas and 3 others like this.
  21. Jan 8, 2020 at 7:22 PM
    Mike19
    Mike19 New Member
    Chi town
    17” fit on those? what’s the offset?
  22. Jan 8, 2020 at 7:32 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Your bumper- the middle part- is it finished in something other than plastic? It looks almost like dark gray, and shiny like paint..?
  23. Jan 8, 2020 at 7:35 PM
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    Icon rebound 17” has 25mm offset.
  24. Jan 8, 2020 at 7:39 PM
    Tundra_Dawg
    Tundra_Dawg Boss Moss
    Arizona
    2017 MGM Platinum
    PPE headers, TRD exhaust, ICON 3" lift, Raceline wheels, Powertrax Tonneau cover; 2019 TRD Pro headlights and fogs; TRD pro grille; Victory 4x4 sliders.
    Here's a shot of my former 2014. Leveling kit only, with tires and rims.
  25. Jan 8, 2020 at 8:00 PM
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    6112s set at 1.9 front, 5100s rear no lift running 285/70/18 Yoko’s MTs on Methods +25.
    kidrman, weirdbeard, yoshi82 and 3 others like this.
  26. Jan 8, 2020 at 8:05 PM
    CPdaddy
    CPdaddy Why am I so tired
    Tom
    Denver
    16 Tundra CrewMax Limited
    Boss 3" Lift, TRD Dual Exhaust, S&B Intake, TRD Rear Sway, 285/75r18 Nitto Ridge Grapplers on Fuel Beast Wheels, SPC upper control arm, Rough Country front bumper with LED bar and dual lights on each side, Rear bumper blackout covers, Go Rhino running boards, Morimoto XB Headlights, HIRev LED Tail Lights
    Boss kit at full 3", 285/75r18 Nitto Terra's on stock rims. I had to cut away part of the bumper and use spacers to make it work. Also had to add the UCA's. I would have done wheels, but my budget manager cut my funds
    emdcksn, Cement4WD, yoshi82 and 5 others like this.
  27. Jan 8, 2020 at 8:38 PM
    CamR
    CamR 19 Tundra Limited
    Al
    Fayetteville, Ga
    What offset did you go with on the wheels?
  28. Jan 9, 2020 at 5:30 PM
    IntheGreatWetNW
    IntheGreatWetNW New Member
    Drew
    2014 Silver CM Limited
    leveled with 5100s, wheels and tires
    285/55/20s. -1mm offset IIRC. I'd like a bit more sidewall sometimes but for a mainly street ride it isn't important. Leveled with Bilstein 5100s. Ground is off level in the pic, but truck sits level on flat ground. Later I had to remove short front of tire mud flaps, one side rubbed hard. Tires stick out an inch or so. I can get you a getter shot of it's stance if you want.20190525_141426.jpg
    YsoSeRiouS! likes this.
  29. Jan 9, 2020 at 6:16 PM
    XPTUNDRA
    XPTUNDRA New Member
    North MS
    2016 Tundra Limited
    4" Pro Comp Lift 35x12.50x20 Toyo RT's 20x9 +20 Fuel Mavericks Rough Country soft tri-fold bed cover LED headlight and Fogs with LEDs throughout the cab as well
    20190807_045455.jpg 2" spacer lift . Stock rear
    295/70/18 Nitto Ridge Grapplers on factory 18' . Sorry I know you wanted after market wheels but I liked my stock wheels and therefore able to run a larger tire
  30. Jan 9, 2020 at 6:19 PM
    XPTUNDRA
    XPTUNDRA New Member
    North MS
    2016 Tundra Limited
    Previous Tundra with 3/1 and 295's on Method 18x9's
