Looking for new Tools
Discussion in 'Home Improvement' started by Moon Puppy, Jul 26, 2021.
  1. Jul 26, 2021 at 7:00 AM
    Moon Puppy
    Moon Puppy [OP] I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Since I got myself into a bunch of new home repair projects when we bought this 120 year old house I thought about getting a new set of tools for the job. I got most corded things I've needed over the years but the property being much bigger I think I need portability of cordless.
    Thinking about the Milwaukee Fuel line.
    Thinking about this.
    https://www.homedepot.com/p/Milwauk...eries-Charger-and-Tool-Bag-2695-27S/312422229
    What's y'alls thoughts?
  2. Jul 26, 2021 at 7:25 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Fuel stuff is great and pretty rugged too!
    If this set does what you need then not a bad deal but you are going to need more battery too!
    Always!
    BenAZ, D4x4TRD and Moon Puppy[OP] like this.
  3. Jul 26, 2021 at 7:27 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    It's got two batteries. I can't work but one tool at a time...(insert easy joke here).
    The only item I don't think I'll need is the flash light but you never know.
  4. Jul 26, 2021 at 7:52 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Nice little combo. Good bang for the buck it seems. Just an FYI: that drill and impact are not the fuel ones and are less powerful. I’ve never used them so I can’t speak to their power. They may be powerful enough to meet your needs, though
    Moon Puppy[OP] likes this.
  5. Jul 26, 2021 at 7:56 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I ended up with ryobi stuff and it’s fine for most household repair stuff but I wouldn’t count on it for daily use on constant or large projects.
    Two batteries won’t be enough. Not if you keep expanding. I have like 8 batteries and you’d be surprised how fast you can drain them with a miter saw or leaf blower.
  6. Jul 26, 2021 at 7:57 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Thanks for that, so they have a lower powered line that looks the same?
    It'll probably be ok for my needs, around the house stuff. Not like I'm making a living on them.
  7. Jul 26, 2021 at 7:58 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Thanks, for the leaves I have a Stihl gas blower.
  8. Jul 26, 2021 at 8:02 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I started with Ryobi stuff with our first home. Perfectly fine for diy projects around the home. Bonus is they have quite a few 18v lawn equipment and LED lighting options. You really need to step up to the 40v for any powerful lawn equipment.
    I converted over to the M18/M12 equipment for working on the cars (impacts, ratchet, grinder, Sawzall)
    BenAZ and Moon Puppy[OP] like this.
  9. Jul 26, 2021 at 8:08 AM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    I used to buy cheaper consumer grade (e.g., Ryobi) and a few years ago I switched to Milwaukee Fuel. I’ll never go back.
    Note that the “Fuel” line are their upgraded brushless tools. They last longer, use less battery, and are more powerful. None of the tools in the kit linked above are “Fuel” tools.
    I actually prefer the M12 Fuel line for most applications. It is a great combination of power to size/weight ratio. Only 12V, but they pack a punch.
  10. Jul 26, 2021 at 8:11 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I always buy Ridgid for the Lifetime battery replacement.
    I've used it many times. Walk in to authorized place, give them your old ones, wait for verification they are dead and a week later....new batteries.
    Some of my drills are 10y old and I was able to get new batteries for them. Just have to make sure to register them within the give timeframe (90 days I think).
    Tundratoofun likes this.
  11. Jul 26, 2021 at 8:11 AM
    eick
    eick New Member
    If I have to upgrade tools I’d look at the fuel line or just go air. Air wins for garage stuff if you have the compressor for it but not everyone has that. If you got your compressor at Home Depot or Lowe’s then stick to battery powered tools or electric
  12. Jul 26, 2021 at 8:11 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Yeah, tough to tell the difference sometime. You can tell the lower power impact because it has a silver nose piece where the fuel is black. I bought a combo kit with the fuel drill/impact with a 5ah and 2ah battery. Later on purchased the mid torque impact and a light. Occasionally I wish I had another battery but usually the two I have is enough. The 2ah primarily stays in the light and the 5ah gets rotated through the tools on an as needed basis. The fuel impact i have is enough for light automotive work/small engine repair but not quite powerful enough for suspension work. Not sure the ratings on the non-fuel version but I wouldn’t purchase it expecting to put a 6” lag into a railroad tie. A drill is a drill. 90% of the time you’re putting 1-2.5” screws in a board. If you’re trying to put a 2” hole in a piece of hardwood you should get a drill press. No sense in breaking your wrist.
    I say go for it
  13. Jul 26, 2021 at 8:12 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Thanks for this. I may just go spec out my on "Kit" with the fuel line stuff.
  14. Jul 26, 2021 at 8:17 AM
    swallace
    Steven
    Tri-Cities, WA
    I started with this kit and didn’t look back. If you wait for a sale, you will usually get a free add on worth $100, like their XC6.0 battery.
  15. Jul 26, 2021 at 8:40 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Good battery management will help alot. For me, when i get a battery down to half charge, i will put it on the charger and grab a new one, that way you always have one charging and dont wait until its fully drained and takes longer to charge. You would be surprised how long 2 batteries will last doing this.
  16. Jul 26, 2021 at 8:44 AM
    swallace
    Steven
    Tri-Cities, WA
    If you get a high capacity battery with 3x capacity, it lasts 3x longer ;)
  17. Jul 26, 2021 at 9:07 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Just get the kit, it’ll take years before you need to replace a tool. And when you need to replace the tool, get the brushless. You have to add another battery with any kit. Most likely you gonna use 2 tool at once and a third battery on charger.
  18. Jul 26, 2021 at 9:09 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Flashlight is very useful when you do plumbing under sink, anything in attic or crawl space.
  19. Jul 26, 2021 at 9:17 AM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I had the old Milwaukee brushed hammer drill and I put that thing through the ringer. MIxed counties batches of joint compound, cement, paint and put that that hammer drill to work. A few times I thought I burned out the motor, after 6 years of abuse the chuck started to lose its grip on the bits. My kids bought me a new Fuel hammer drill for Fathers day and there is a night and day difference on power. You cant go wrong with either one.
    Edit: I just saw that kit has the drill/driver, me personally I would get a kit with the hammer drill/driver.
  20. Jul 26, 2021 at 9:20 AM
    Outbound
    Aaron
    Northern Alberta
    Milwaukee is the best. Great choice. Drop @War Machine a line before you buy. He sells the stuff and might be able to hook you up.
  21. Jul 26, 2021 at 9:38 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
  22. Jul 26, 2021 at 9:45 AM
    swallace
    Steven
    Tri-Cities, WA
  23. Jul 26, 2021 at 9:47 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Unless u make a living and need the production I would get more tools then going brushless
  24. Jul 26, 2021 at 10:01 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Those should work out just fine.
  25. Jul 26, 2021 at 1:13 PM
    War Machine
    War Machine SSEM # 5 3MW
  26. Jul 27, 2021 at 9:46 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    It's confirmed. Going with the Milwaukee stuff.
    @War Machine you had time to take a look?
  27. Jul 27, 2021 at 10:54 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    My Grandfather's old saying: "Buy the cheapest tool you can find. If you find out down the road that you broke the tool, replace it with the most reliable and professional tool you can afford because that's a tool you actually use."
    Take it or leave it as I did. My Grandpa was a frugal carpenter, but he'd spend $1,000 on a circular saw if that's what he needed to get the job done.
  28. Jul 27, 2021 at 2:58 PM
    eick
    eick New Member
    Ha that’s pretty good advice
    Bikeric[QUOTED] likes this.
  29. Jul 27, 2021 at 3:11 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I use my muti tool more then my circular saw and sawsall combined.
  30. Jul 27, 2021 at 3:12 PM
    ArcticEd
    ArcticEd New Member
    Jacksonville
    '24 Plat Hybrid Crewmax 6.5 CSM
    Great advice! Did this with my first chain saw, bought a cheap one from home depot. Lasted 2 trips where I volunteer, so I've had a stihl ms362 for the last 8 years.
