Looking for more bass
Discussion in 'Audio & Video' started by Boatmoney, Mar 25, 2019.
  1. Mar 25, 2019 at 7:16 PM
    Boatmoney
    Boatmoney [OP] New Member
    Mark
    2019 black platnum tundra
    looking for a little more bass from my factory JBL system 2019 platnum. Is replacing the sub and enclosure really worth it? Any good mods for getting more from my factory sub? Or should it just be replaced and get a new amp?
  2. Mar 25, 2019 at 7:59 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    @T-Rex266 made some changes to his I believe. He might have some insight.
    BTW, @ARamirez73 makes a cameo in this video :D
  3. Mar 25, 2019 at 8:04 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    the general consensus is to pull the factory one out and dropping in a new 10 in its place
    T-Rex266 and Buildn like this.
  4. Mar 25, 2019 at 8:10 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    first, welcome!
    second, i too have a '19 limited CM with "jbl premium system". it sucks!
    i participated in the jbl sub replacement group buy a couple months back. upgraded to a custom box and 10" sub for $180.
    i've noticed a decent difference in bass, but not anything to brag about. was is worth $180 (GB price) or $200 (full retail) (from james at tech12volts)? yes.
    would it be worth $200+, probably not.
    i'm overall satisfied, however, i still consider a full replacement (by tech12 and self install, or turnkey by others).
    my dilemma, i hear "others" around my neighborhood "bumping bass", and i think, "i dont want that crap in my neighborhood". trying NOT to be that guy. i'll live with what i have for a while.
    Boatmoney[OP] likes this.
  5. Mar 25, 2019 at 8:17 PM
    .:rofl:
    Trooper2 and TXMiamiFan[QUOTED] like this.
  6. Mar 25, 2019 at 8:24 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Mark,
    Welcome!
    I had stock speakers swapped out with Alpines and kept the head unit.
    Added a Alpine power pack to run the door speakers.
    Added a Pioneer low profile 10” sub that fit in my double cab cargo box and had a Pioneer amp run it.
    A kicker wire harness 50 amp fuse kit that feeds the thump under the hood off the battery.
    All installed from Geek Squad at my local Best Buy for $900.00
    Oh and it has plenty of bass
    15whtrd, Boatmoney[OP] and TXMiamiFan like this.
  7. Mar 25, 2019 at 8:24 PM
    Boatmoney
    Mark
    TXMiamiFan[QUOTED] likes this.
  8. Mar 25, 2019 at 8:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    There is nothing you can do to improve the factory sub.
    The custom box with 10" 2 ohm JBL sub from Tech12volts will make a significant difference for $200. You may find yourself wanting to do additional upgrades after that but if it's just bass you want then for $200 you won't find a better bang for your buck.
    If you want to keep your headunit you could add a Rockford dsr1 and amp for that sub. But that's another $400+, and at that point you might as well add new speakers everywhere to get full sound quality improvement. And then you'll realize you would like a better head unit and then.... well and then you'll be like me and be balls deep in a full audio build.
    So be careful is my advice. The tech12volts sub is your best bet but things may snowball on you.
    Trooper2 likes this.
  9. Mar 25, 2019 at 8:41 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
  10. Mar 28, 2019 at 9:56 AM
    Lakerat
    Lakerat New Member
    Conor
    Montgomery Texas
    2015 Tundra TSS
    I have a 15 Tundra Crew Max, and I've gone through a few different options for audio, especially bass tones.
    For the absolute best in tone quality, Focal is beautiful. It's a bit above normal in price, but the sound is superb. They have shallow mount 10 and 12" subs that will blow out 90% of anything else, and with a lower wattage l at that.
    JL has the TW3 13" sub, that is a shallow mount. Also great for mid to heavy bass, a bit cheaper than Focal, but every bit as good.
    My personal setup is 2 Focal 12" subs in a custom box, with Focal componants. McIntosh amps and Kenwood up top for head unit. I have absolutely zero complaints.
    TundraLuv and Boatmoney[OP] like this.
  11. Apr 29, 2019 at 1:10 PM
    cygan1008
    cygan1008 New Member
    “RIP” 2013 Tundra TRD Rock Warrior, 2018 TRD SPORT CM 4x4 SUPER WHITE Eibach Pro 2.0 275/65/20 Recon Grapplers
    How do you like the Power Pack? I'm debating between that and the Kicker Key. The Alpine is about $70 cheaper but the Kicker has some functions that are interesting.
  12. Apr 29, 2019 at 1:14 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    yes he did. hope she is recovering well.
  13. Apr 29, 2019 at 6:53 PM
    Buildn
    Medina, Ohio
    Matt,
    The Alpine power pack works fine, it rocks my Alpine R series just fine. I put it in the dead space under the console rather than under the passenger seat.
    I like the small design to be able to fit it into small spaces.
    cygan1008 and Trooper2 like this.
  14. May 1, 2019 at 5:20 PM
    tundraal
    tundraal New Member
    Are you using the power pack for all 4 doors or just for the front? I am debating on going that route with the power pack. Thanks
  15. May 1, 2019 at 7:07 PM
    Buildn
    Medina, Ohio
    Matt,
    Yes for all four doors. I went with Alpine R Series 6.5 component for front doors with 1” tweeters in the dash. The rear door speakers are 6.5 Alpine R Series as well and are all ran by the Alpine Power Pack.
