Looking for Input on 2008 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by ND123, Mar 12, 2019.
  1. Mar 12, 2019 at 7:20 AM
    ND123
    ND123 [OP] New Member
    Hey everyone,
    New member here looking at a 2008 SR5 with the 5.7 V8. Most important to me is reliability which is what led me to Tundras in the first place. This particular one has 54k miles on it and has been in MA,CA, and AL primarily. Main concerns are rust and the cam tower leak with the 5.7 V8. Truck looks pretty clean to me, should know for sure when I take a look at it next week but if anyone with experience with the 2008 year range could chime in with more things to look out for or thoughts on this particular truck I'd really appreciate it. I tried to attach some pictures so hopefully those work!
    Thanks in advance!
    Mnorris1206 likes this.
  2. Mar 12, 2019 at 10:26 AM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    Certainly looks nice, really like the color. Low miles too.
    Mr Badwrench likes this.
  3. Mar 12, 2019 at 10:35 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Some low miles for sure.
    Got our 2007 DC with 130K miles on it. Runs like new, reliability not a question out at all.
    Rust concerns, you need to get underneath or have someone inspect frame and maybe body parts as well. Rust will depend on amount or salt exposed to if any from road applications during icy/snowy winters.
  4. Mar 12, 2019 at 12:14 PM
    ND123
    Thanks for the responses guys. I had the dealer check for rust but will be sure to look closely when I see it in person as well. Are there areas that tend to rust first on these trucks? Under the bed, wheel wells...? I’m hoping that since it’s spent most of it’s life in CA/AL it’ll be clean underneath.
    Thanks again!
  5. Mar 16, 2019 at 11:20 AM
    Medicius
    Medicius New Member
    2008 Black CM
    On my 2008 CM I'm starting to see rust pockets on the crease at the bottom of the tailgate. In Minnesota, that seems pretty standard for trucks (I see a lot of them as I live in the sticks). I did recently have a recall spray done on the frame in the last year, so undercarriage rust may be a moot point.
    As a side note for reliability, the truck has been a godsend. I think I'm hitting 180k mileage and have only had to replace normal wear/tear plus water pump seal was leaking.
  6. Mar 17, 2019 at 5:39 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    That is a great looking truck....looks like mine ;). Hope it works out for you. I got mine with 106,000 and now has 129,000. No troubles at all.
  7. Mar 17, 2019 at 7:32 AM
    FXFormat
    FXFormat New Member
    180K miles here, drives like new, not a single drop of fluid leak anywhere, cam towers bone dry. I believe the 2010+ had more issues with the cam tower leaks than the earlier ones.
    TheBeast likes this.
  8. Mar 17, 2019 at 12:07 PM
    art64
    art64 New Member
    When I bought my 2010 Crewmax 4x4 it has surface rust on some suspension bolts, differential housing and axle. Nothing on the frame or bed. Previous owner sprayed the frame with Fluid Film which I'm really thankful for. Check 4 hi, 4lo for proper operation and unusual noises from transfer case. Make sure transfer case engages/disengages smoothly. Feel for clunks in driveline from stop to go and vice versa. Of course check history for accidents or damages.
  9. Mar 18, 2019 at 12:23 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I honestly feel the first 2-3 years of the 2nd gen's were the best. New design and new powertrain for Toyota meant they were taking extra care to make them be as good as they could be I feel. I bought my 08 w/104k miles on the clock and without hesitation. Jump on it NOW, that's a great truck. I do have some bed rust issue but that's a KNOWN problem with Tundras, and I'm just gonna live with it. Not really that big a deal. Other than that, it's solid!
  10. Mar 18, 2019 at 12:33 PM
    ND123
    Thanks everyone for the replies and insight! I have it reserved and will be taking a look at it within the week and hopefully taking it home if all looks good. Thanks again!
  11. Mar 18, 2019 at 1:30 PM
    phabej
    phabej New Member
    2018 Platnium
    why not look for a Tundra outside the rust belt? I'm sure you'll be happier. I know if I lived in the salt belt or areas they use salt, i'd be buying trucks from the west coast. Worth the trip IMO.
  12. Mar 18, 2019 at 1:32 PM
    TheBeast The Beach
    yep, 2008 good year. check rust and cam tower (less likely on a 2008). You also have the line x in the bed so that's a plus too as far as protection.
    ND123[OP] likes this.
  13. Mar 18, 2019 at 1:38 PM
    ND123
    From what I can tell from CarFax and the like the truck has spent most of its life outside the rust belt in CA and Alabama and I’m having it brought up to Minneapolis from GA to look at then I’ll be driving it back home to North Dakota. Hopefully since it hasn’t spent much time in the rust belt it’ll be pretty clean. Luckily ND isn’t as ridiculous about salting as some states (I lived in Ohio and it was pretty bad). Thanks!
    Black Wolf and TheBeast like this.
  14. Mar 18, 2019 at 2:32 PM
    Mnorris1206
    08 tundra
    I love my 08. Only issue with rust.is the rust comes from under into the top side. Some people on here has had it even with a nice liner make sure to check under it for rust on the bed supports. Other then that get it you will love it. Here is my 08 with 82k miles .
    Welcome from Indiana!
    ND123[OP] and Trooper2 like this.
  15. Mar 18, 2019 at 3:18 PM
    First year 07's too. 96K....no rust...no leaks...although I recently replaced a $20 power steering pressure sensor....
    kparrow[QUOTED] and Mnorris1206 like this.
  16. Mar 18, 2019 at 3:26 PM
    Mnorris1206
    08 tundra
    Curiosity if you don't mind me asking what are they asking for it?
  17. Mar 18, 2019 at 8:20 PM
    ND123
    Asking just under $23k. It's Carmax so probably paying a bit more for the convince but I've had good experiences with them in the past.
    Mnorris1206[QUOTED] likes this.
  18. Mar 18, 2019 at 8:22 PM
    Welcome from NY.
    Good luck with your search.
  19. Mar 18, 2019 at 8:38 PM
    Trooper2
    JR
    Bought one vehicle there, great ecperience but paid a premium for that experience.
    Also sold s truck to them and got premium price. :thumbsup:
  20. Mar 19, 2019 at 9:36 AM
    ND123
    Ya I'm hoping a get at least something for my old Ranger. If it can even make it the 4 hours down to Minneapolis to trade it in haha.
  21. Mar 20, 2019 at 4:27 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    That's a good looking truck. Only other thing I can think of is the AIP issues, but that's one that you can't control. They make bypass kits for it as well, I just installed one on mine last fall. Other than that and what was listed before, I would say it looks good!! I have an 08, 4.7L with 144k miles and it runs great!
  22. Mar 22, 2019 at 9:19 AM
    csfuser
    csfuser New Member
    2009 Silver DC
    working on upgrading the audio..
    Recently bought a Silver '09 DC base w/ 98k on it.
    Stock audio, no JBL, no SWC. Single owner had added Bluetooth which I removed when upgrading the stock HU - as it came with it - and I wired in a backup cam and dash cam:)
    Price? <$13K
    PS: Runs great !!
  23. Mar 24, 2019 at 7:24 AM
    ND123
    Took a look at the truck yesterday and it's in very good shape. No rust and seems to have been very well cared for. Bought it and drove it five hours back home and it did great! Thanks for the help everyone!
    kparrow likes this.
  24. Mar 24, 2019 at 7:35 AM
    Trooper2
    JR
    Glad it worked out. Time to enjoy!
    and :spending:for mods, lol.
  25. Mar 24, 2019 at 7:44 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    When I had my 2008 the only two issues I had were:
    1. Bed rust around the bed bolts. It came from underneath and it was so bad that I had the bed removed and rust areas cut out and new pieces were welded back in before I had a Line X sprayed on.
    2. The air pumps were also replaced not once but twice by Toyota.
    I would ask if the pumps were replaced and check for the rust around the bed bolts.
    Good luck!
  26. Mar 24, 2019 at 7:52 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
  27. Mar 29, 2019 at 11:46 AM
    Tonym9
    Tonym9 New Member
    Tony
    07 5.7 SR5 DC 2wd Blue Streak Metallic 83500 miles
    20" Ultra Motorsports Mavericks with 30mm backspace, 305-55-20 Goodyears, ET8 painted grill surround, tube step bar, anodized horns grill emblem, weathertechs...planned mods: true duals since they stole my cats/pipes, bedliner, bed 110v, interior 110v.
    Bought mine from them too, paid too much but worth it to avoid flood etc. Mine was like new underneath...multiple friends with hi mileage/no issues 07-09 5.7 tundras sold me on it. Get the warranty for starter, aip, water pump. I bought a true 100k warranty from them, im good to 154k. Not too late, u can do an after purchase warranty buy. Enjoy it
