Looking for better light output
Discussion in 'Lighting' started by jDaGr8, Sep 17, 2020.
  1. Sep 17, 2020 at 7:02 PM
    jDaGr8
    jDaGr8 [OP] New Member
    is there anything I can do with my 2014 stock headlights to get better light output or am I stuck with what I got
  2. Sep 17, 2020 at 7:03 PM
    jDaGr8
    Looking for better light output but not quite banking the bank, any advice?
  3. Sep 17, 2020 at 7:11 PM
    TheBeast The Beach
    morimotos or oem LED headlights
    HulkSmurf14 likes this.
  4. Sep 19, 2020 at 7:01 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Buy the iHacker harness and OEM LED Headlights..OEM LEDS have the best low-beam output and even the high beams are phenomenal over the 2014 OEM halogens...
    Morimotto are also good, not as good on low beams but slightly better on highbeams... they look different too in how they work (sequential turns)...
    I went with OEM LEDs and they have blown my expectations away! Best upgrade I've done to the truck by far!
  5. Sep 19, 2020 at 7:02 AM
    HulkSmurf14
    2014 Tundra Limited
    OEM LEDs from 2018+ trucks or Morimitos...
  6. Sep 19, 2020 at 3:28 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
  7. Sep 19, 2020 at 3:28 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
  8. Sep 19, 2020 at 3:32 PM
    What year?
  9. Sep 19, 2020 at 3:34 PM
    jDaGr8
    I was looking at just trying to get new bulbs or something for my stock 2014 headlights but have seen most people say I should just upgrade them all together
  10. Sep 19, 2020 at 3:35 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I swapped bulbs in Headlights and Fogs with 6500K LED.
    Cost me $100 Canadian and made a world of difference. The stock ones sucked and sometimes I couldn't even tell if they were on.
    You need to remove the entire grille and side front panels to gain access to H/L. Fogs just pop out from front.
    Some don't agree with it, I didn't let that stop me. There are a few threads on the topic and show that the cutoff light line is fine and won't blind traffic with scattered light etc.
  11. Sep 20, 2020 at 6:48 PM
    bft305
    bft305 New Member
    2016 tundra limited
  12. Sep 20, 2020 at 6:57 PM
    biebs96
    PA
    Upgraded halogens.. swapped the headlights and the fogs for just under $100
    tsinajinii likes this.
  13. Sep 23, 2020 at 9:34 PM
    salmonator
    salmonator New Member
    Tigard, OR
    2019 Tundra SR5 4x4 DC
  14. Sep 23, 2020 at 10:39 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    For an immediate cheap quick fix;
    Buy some regular Silverstar halogen bulbs, not the Ultras, they are too blue and don't last very long.
    SYLVANIA - 9003 SilverStar
    https://www.amazon.com/gp/product/B000CO93RA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Brighter and whiter light than the stock bulbs.
    I'm going back and forth on the iHacker harness and OEM LED Headlights.
    I really like my amber DRLs and I'd lose them with that mod..
  15. Sep 24, 2020 at 7:38 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Amber DRL delete is optional with @iHacker harnesses. If you don't de-pin or cut the gray wire, they automatically work as they always did without affecting LED DRL operation. I kept the amber DRL when I converted using the dimming harness.
    1lowlife[QUOTED] likes this.
  16. Sep 24, 2020 at 8:19 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    But isn't the amber turn signal in the new headlight a single filament?
    How does retain use as a DRL?
    If I can keep the amber DRL I'll rally have to consider doing this..
    I'd like to have the white LED DLRS dim all the time and still have the amber DLR.
  17. Sep 24, 2020 at 9:46 AM
    JohnLakeman
    Now, you're going to get me to speculating, postulating, and bs-ing. :D
    @iHacker would have to explain how it works, but basically the ECU controls the DRL brightness (maybe by voltage?). There are two brightnesses for the DRL: one for 100% bright DRL (headlights off), one at 60% brightness (headlights on), and then (I'm guessing here), but maybe a third lower voltage for the park/turn signal when "park lights" on?
    Edit: No, italics above incorrect. I just checked...the amber 7444NA bulb in my LED headlight was a two filament bulb. I replaced the amber bulbs with LED when I did my conversion.
    The gray wire is the DRL. Leave the gray wire intact, tap-in the @iHacker black wire (assumes dimming harness), and you have both.
