Looking for advise- mechanic recommendation
Discussion in 'New Member Introductions' started by Pj2007tundra, Apr 13, 2024.
  1. Apr 13, 2024 at 12:06 PM
    Pj2007tundra
    Pj2007tundra [OP] New Member
    2007 tundra v8 5.7 sr5 trd
    Hi Tundra Community,
    I am a new member and look forward to be part of this forum!
    I have a 2007 sr5 v8 5.7 sr5. Now has 248k miles. I own it for 9 months. Replaced most of suspension, tires, belts, did headgasket and plugs, and 2 oil changes.
    I got ticking sound that started 1 week ago and I found yellow sludge in oil cap. I am looking for reliable independent mechanic that has toyota experience to get it checked out to diagnose to find source, tensioner/timing chain, pvc valve, whatever the issues are. I am located on Long Island, New York.
    Thank you for input/referrals.
    Leo's first likes this.
  2. Apr 13, 2024 at 12:34 PM
    2mchfun
    Welcome from OKC! Head gasket or valve cover gasket? Big difference. How far do you drive it? It needs to burn off condensation in the crankcase. Pour in a quart of ATF and drive it for 20 minutes, then change the oil using 5W-30. Might need to repeat a few times to hopefully eliminate the ticking.
  3. Apr 13, 2024 at 12:37 PM
    Pj2007tundra
    My bet, valve cover gasket.
    Leo's first and 2mchfun like this.
  4. Apr 13, 2024 at 12:44 PM
    2mchfun
    Read my post again, I added a suggestion.
  5. Apr 13, 2024 at 12:47 PM
    2mchfun
    You can also remove the belt and then start it to verify that none of the ticking is coming from the external components.
  6. Apr 13, 2024 at 12:50 PM
    Pj2007tundra
    Thank you very much .Are you saying ATF / quart transmission fluid to mix with oil? Replacing with 5w30 synthetic or regular?
  7. Apr 13, 2024 at 12:53 PM
    2mchfun
    Yes, automatic transmission fluid has strong detergents that will help clean varnish. I would use 5w-30 synthetic.
  8. Apr 13, 2024 at 12:54 PM
    Pj2007tundra
    Thank you again. Much appreciated.
    2mchfun likes this.
  9. Apr 13, 2024 at 1:18 PM
    Welcome from NY.
  10. Apr 13, 2024 at 1:52 PM
    Pj2007tundra
    Thanks Jim.
  11. Apr 13, 2024 at 2:49 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I never knew this stuff. I learn something new at least every week on this site!
