Looking for advice on finding 2.5 with long (6.5) beds
Discussion in '2.5 Gen Tundras (2014-2021)' started by cotalldude, Oct 17, 2024.
  1. Oct 17, 2024 at 2:41 PM
    cotalldude
    cotalldude [OP] New Member
    looking for one
    I'm moving from a Highlander to a Tundra for towing and offroad. I also want to sleep in it, so the short bed is out. Even if I could afford $50-60K for a new one, the reliability of the Gen 3 has scared me off. So I'm looking at 2018 (TPSS) through 2021. I'd like a Limited it possible, an Off Road maybe, and I could handle an SR5. But the long bed is a must have.
    But when I look through the listings I see no long beds on the Limited or OR. Did they make them? Am I forced into an SR5 to get one? Any advice welcome. I'm in Colorado if that matters.
  2. Oct 17, 2024 at 2:47 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Welcome from The Springs! I have a 6.5Ft bed SR5 TRD Offroad. That bed length was only available with the double cab, not the crewmax configuration, not sure if that’s a deal breaker for you.
  3. Oct 17, 2024 at 2:50 PM
    cotalldude
    looking for one
    Double is fine. So I can keep looking for an OR.
  4. Oct 17, 2024 at 2:54 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Solid plan. Wouldn’t trade mine for anything
    pvn.beluga likes this.
  5. Oct 17, 2024 at 2:55 PM
    cotalldude
    looking for one
    White! That's exactly what I want! year?
  6. Oct 17, 2024 at 2:55 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    OP, I've seen double cab (with 6.5' bed) limited trim trucks in that year range, but they're certainly the minority compared to Crewmax trucks of the mid-to-upper trim levels
  7. Oct 17, 2024 at 3:00 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Mine is a 2016, so out of the year range you’re looking for, but still such a killer truck!
  8. Oct 17, 2024 at 3:01 PM
    cotalldude
    looking for one
    When I search cars.com for Tundras 2018-2021 within 100 miles of Boulder, CO I don't see a single OR. Is the TRD Pro my only choice?
  9. Oct 17, 2024 at 3:02 PM
    cotalldude
    looking for one
    I really want the TPSS - AEB and radar cruise control. I'm old and I want the truck to stop if there a problem and I don't stop it.
  10. Oct 17, 2024 at 3:13 PM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    I found tons of extended cabs when I was looking for mine, it was annoying. In every model from stripper deluxe to Platinum. I don't think you should have an issue at all.
  11. Oct 17, 2024 at 3:14 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Understandable. You might just have to wait for the right one to pop up, or travel if you’re willing. There might also be worthy trucks hiding under the SR5 filter that are TRD Offroads as well, I think that label gets missed some times
  12. Oct 17, 2024 at 3:45 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    You might have to expand your search area a little bit to find exactly what you're looking for. The last 2 Tundras I have bought have been from about 400 miles away.
  13. Oct 17, 2024 at 4:06 PM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    I just listed my DC, in PA though..
  14. Oct 17, 2024 at 4:35 PM
    Blast Chamber
    Blast Chamber New Member
    WI
    2020 DC Limited - Cement
    Double cab with 6.5 bed was exactly what I was looking for as well. I also absolutely did not want a sunroof, which the double cabs don't have. I ended up driving 4 hours to buy my certified used 2020 Limited at a Toyota dealer this summer.
    It seemed like 4 out of every 5 trucks were a crew cab/short bed when I was looking. My search was within about a 250 mile radius. Clean, low-mileage DC's are out there but you might have to travel a bit to get one.
    BreyTundy likes this.
  15. Oct 17, 2024 at 4:59 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    How tall are you? I'm 5'10" and manage to sleep on the rear bench in DC. Move the passenger seat forward, and there's enough space to fit legs.
    I have also a bed setup in 6'5" bed, can fit there no problem, of course, but getting in and out of bed is a problem on its own. Especially, in winter.
  16. Oct 17, 2024 at 5:07 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    May I suggest to move to a Sequoia? Same engine/transmission combo, same electronic whistles and bells, two adults can sleep full length inside, in a much more convenient setup than any Tundra can provide. The only 2 downsides are Sequoia is a bit more expensive than Tundra, and it has a smaller gas tank. And independent rear suspension is worse than the solid axle in case you are looking for THAT type of offroading.
  17. Oct 17, 2024 at 5:36 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Check Carvana, they usually have some.
