Looking for advice from Tundra folks.
Discussion in '2nd Gen Tundras (2007-2013)' started by TylerJones19, Nov 14, 2021.
  1. Nov 14, 2021 at 2:52 PM
    TylerJones19
    TylerJones19 [OP] New Member
    Tyler
    2007 5.7 Double Cab SR5 TRD
    I just bought a 2007 5.7 Toyota 2WD SR5 TRD with 169,000 miles. It was regularly serviced by a dealership according to the Carfax for the first 130,000 and the guy I bought it from had all his receipts from a local shop. It had undercoating put on from the factory (Toyoguard) which has held up remarkably well. There is basically no surface rust on the frame or anywhere and has a LineX sprayed in. The specific maintenance I 100% know was done - rear diff flush at 132,000 - valve cover gaskets replaced at 158,000 - Brakes and Rotors at 161,000 - New spark plugs and new vapor canister purge solenoid at 165,000 - along regular oil changes. I suspect there was other maintenance done along the way but I can't be completely sure. I want to do everything I can to set this truck up for success and I am willing to spend some money now so save some money and headaches later. This truck will probably be only driven a couple times a week and may be called on to tow a 4,000-5,000 lb farm tractor (depending on what attachments are on) a few times a year. I've done the maintenance on my wife's 2013 highlander according to the Toyota's maintenance schedule so I'm not completely new to Toyotas. My question is what preventive maintenance should I be considering. I'll be changing the oil every 5,000-6,000. I plan on dropping the pan on the transmission and cleaning the magnets and getting some fresh ATF WS in there. Anything else I should be prioritizing? I have absolutely no complaints about how it's running and shifting right now. Everything came back looking good on an OBD II scan as well. Would also appreciate any suggestions on Head Units and Backup cameras that people have had success with.
  2. Nov 14, 2021 at 2:59 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! It sounds like it has been pretty well taken care of. There may be someone that chimes in on something but I don't know what it would be.
    TylerJones19[OP] likes this.
  3. Nov 14, 2021 at 3:06 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Welcome! If the timing chains haven’t been replaced I would do that.
    LLamaguy and TylerJones19[OP] like this.
  4. Nov 14, 2021 at 3:29 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome
  5. Nov 14, 2021 at 4:36 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    If it's a timing belt, yes, but why replace the timing chain?
    2mchfun likes this.
  6. Nov 14, 2021 at 5:10 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Welcome from TX. I’d say you’re on the right track. Seems pretty well maintained, so I’d just keep with the oil changes, the tranny flush and just checking coolant level. Just basic stuff. Maybe get some of the suspension components looked at by a reputable shop?
  7. Nov 14, 2021 at 5:32 PM
    2mchfun
    Thermostat, hoses, belt, injector cleaner, you really shouldn't mess with the tranny pan or filter. Do 3 or 4 drain and fills 50-200 miles apart and call it a decent flush, then leave it alone for 35k then repeat. Wouldn't hurt to clean the throttle body also. Lube all the door, hood, tailgate mechanisms, check the cabin filter.
    TylerJones19[OP] and Danny3737 like this.
  8. Nov 14, 2021 at 9:47 PM
    TylerJones19
    Tyler
    What would be the advantage of multiple drain and fills over dropping the pan, cleaning the magnets, and putting a new strainer in? Thanks again for everyone’s input. Sounds like pretty basic stuff I can do with the help of the internet and YouTube.
  9. Nov 14, 2021 at 9:52 PM
    AZBoatHauler
    So.Arizona
    The pan bolts are notorious for snapping when trying to remove.
  10. Nov 15, 2021 at 4:10 AM
    2mchfun
    Pan bolts break. Others have opened their filters and they had almost nothing in them after many miles. They basically fought broken pan bolts for nothing. Plus you don't want to "shock" your tranny and upset it.
  11. Nov 15, 2021 at 6:37 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I just finished my 3rd of 3 drain and fills. My truck has 175K on it and I could Not find where the previous owner did it. I drove it for about 250 miles and cracked the drain plug a little and let a few drops land on a white paper towel and was amazed how clean it looked. My plan is too do the same again after another 10K to see how it looks. If it still looks good, then I will continue to repeat the process every 25K miles. I can say that it does shift a little smoother. Next up is a new serpentine belt and coolant flush.
  12. Nov 15, 2021 at 6:50 AM
    TylerJones19
    Tyler
    I like that Idea. I already bought a new strainer and gasket but I might sit on them on or send them back.
