Looking for a place to mount bluetooth mic...
Discussion in 'Audio & Video' started by tundraal, Jun 27, 2019.
  1. Jun 27, 2019 at 6:33 PM
    tundraal
    tundraal [OP] New Member
    Most aftermarket head units do not retain the factory mic. I wanted to remove the factory mic and replace it with the mic from my Kenwood head unit. Buttttt... It seemed like more trouble than it was worth. Plus, I wasn't sure if the cord was going to be long enough. So, I came up with another solution... Mounting it on the underneath side of the center speaker grill. It works perfectly and it is easy location to access when you have the factory radio out.
    https://imgur.com/a/5mn6PZY
  2. Jul 4, 2019 at 12:15 AM
    mmartin768
    mmartin768 New Member
    Michael
    San Antonio
    2019 MGM CMax
    Zone 5" lift. Fuel Vapor 18X9 +1 wrapped in 35X12.5.
    I always went with the shroud for the steering wheel column. That's a great idea though. I may explore that the next time I pull everything out!
  3. Aug 8, 2019 at 6:07 AM
    New_DoorDing
    New_DoorDing New Member
    2016 TRD Pro DoubleCab
    Any regrets? Anyone ever complain about it any background noise? Im getting installed today and Im leaning towards having mic located above rear view mirror. I HATE that it will be visible though. Any suggestions will help. Thanks
  4. Aug 8, 2019 at 6:45 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    If you have enough slack to get to the rearview, just drop the overhead console and put it where the factory mic is. It works great for me and is totally hidden. What brand head unit are you going with though? My Pioneer had plenty of slack, but I've heard Kenwood comes up a little short.
    New_DoorDing[QUOTED] likes this.
  5. Aug 8, 2019 at 6:52 AM
    tundraal
    None so far. I don't do much bluetooth calling though. I do have to "speak up" a little, but that is usually the case with any aftermarket mic. If you have enough slack, you could have them run it to the factory mic spot in the overhead. My Kenwood mic did not have enough slack to reach, so I went with this location under the center channel speaker.
  6. Aug 8, 2019 at 7:03 AM
    New_DoorDing
    Thanks for the quick response guys. It just so happens I am getting a Kenwood as well. Looks like i’ll be doing the same location on the dash then. Thanks again guys
  7. Aug 8, 2019 at 8:17 AM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    that's where i put mine to... lol i had removed the center stage speaker cause i was not using it anymore and just clipped it to the side of the mounting hole for the speaker. works perfectly nice and clean on the receiving end.
    New_DoorDing likes this.
  8. Aug 8, 2019 at 10:29 AM
    New_DoorDing
    58C698F9-7F7F-438D-BAE6-E956BB0502B9.jpg So the supplied 3 meter microphone cable which came with the Kenwood Dnx996xr was actually long enough to make it to the rear view mirror. Take a look at picture. It hides well on the angled upward ceiling liner.
    dak13, DaBoro54 and TRDFerguson like this.
  9. Aug 11, 2019 at 8:33 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    That’s exactly where I have mine for the alpine 309.
  10. Aug 11, 2019 at 10:05 AM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    Back when I used to do car audio professionally, we had a rep from Parrot give a workshop. He said that the headliner (like where you have placed your mic) was found to be the clearest, least noisy spot for bluetooth microphones. I've placed them there ever since.
    New_DoorDing[QUOTED] and dak13 like this.
  11. Aug 11, 2019 at 5:29 PM
    New_DoorDing
    The wife has had nothing but good things to say about the clarity of our phone calls. I also speak at a normal volume. Sooo much better than my old Pioneer where I had to speak up/yell and clearly pronounce everything. I like the fact that Kenwood gives you the option to fine tune your microphone, echo, and noise levels. My old Pioneer 4100 NEX didnt give you any options. Stuck with what you got. The wife did complain about the quality of those calls.
  12. Aug 11, 2019 at 6:07 PM
    codygs83
    codygs83 New Member
    Cody
    TX
    2019 Tundra TSS
    Did you have to remove the headliner to run the wire for this setup? I'm getting my headunit this week and would like to try this, however I'm worried I'll have to pull the entire headliner.
    2truckornot2truck likes this.
  13. Aug 11, 2019 at 6:32 PM
    New_DoorDing
    No not at all. Along the edge the headliner has a little give and allows for the cable to tuck in there. I suggest you clip mic to desired location first, then start working your way back, tucking in headliner until reaching pillar. That you will have to remove
  14. Aug 11, 2019 at 6:33 PM
    codygs83
    codygs83 New Member
    Cody
    TX
    2019 Tundra TSS
    Awesome. Thank you!
  15. Aug 14, 2019 at 12:16 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I've got a Kenwood and that's exactly where mine is. Works really well and easy to hide the wire. :thumbsup:
  16. Feb 18, 2020 at 10:59 AM
    JayCO
    JayCO New Member
    I know this is an older thread, but I wanted to reiterate what @New_DoorDing said above. With my new Kenwood, I did *not* start from the mic and work my way back. I'm pretty certain that (like an idiot) I pulled all the slack out of the cable to try and get it to reach the rearview mirror - not leaving any slack to pull the HU out if I needed (which as it turns out, I do)... so I have undo it all and work the slack back to the HU.
  17. Feb 18, 2020 at 11:17 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I've definitely pulled the mic plug out on accident once or twice when putting the dash back together. They don't click in very well.
  18. Feb 19, 2020 at 8:54 AM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    I mounted mine above the rear view. I have tucked away all the wires since I took the image.
  19. May 11, 2020 at 10:31 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    How did you tuck the clip holding the mic in? Did you pull down the headliner and slide it in?
  20. May 11, 2020 at 10:50 AM
    SiberianTundra
    Greg
    War Machine
    Yes I used plastic pry tool for interior and pulled a bit on the headliner near windshield and tucked in all the wiring.
  21. Dec 9, 2020 at 4:24 AM
    Most aftermarket radios are proprietary to their own mics. (if that is what you're referring to.)
