looking at buying a 2011 tundra platinum. will it tow a 9000lb travel trailer. thanks
Discussion in 'Towing & Hauling' started by 0xman, Mar 16, 2017.
  1. Mar 16, 2017 at 7:57 PM
    0xman
    0xman [OP] New Member
    oxman here. looking at a 2011 tundra platinum to tow a 9000LB everlite travel trailer. Any input would be mighty welcome thanks
  2. Mar 16, 2017 at 7:59 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    What engine? Tow package? Definitely need more info. Is that the dry weight of the trailer? Does it have brakes? Do you have a sway bar or WD hitch? What kind of terrain will you be towing on?
    SouthBoundSteve and Law323 like this.
  3. Mar 16, 2017 at 8:29 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    9000 Lb Dry? Even if that's wet and outfitted, that's more than I would ever do with my 5.7L / tow pkg. Tongue weight and truck rear GAWR are the numbers you need to worry most about. @ColoradoTJ - that's Colorado Towing Jesus for those that don't know - but he can only save you if you believe. :rofl:
    On a side note, what the hell is the letters "lite" doing in the name of a 9K lb travel trailer?:eek:
  4. Mar 16, 2017 at 8:31 PM
    Not taking the podium tonight bud. People will figure it out one way or another.
    It says lite because it could have been 10000 lbs. lmao. I said the same damn thing with my "lite" trailer.
  5. Mar 16, 2017 at 8:31 PM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    With weight distribution... should be fine.
  6. Mar 16, 2017 at 8:33 PM
    Where you located? If your in CO, hell, take mine for a whirl up the mountain passes.
  7. Mar 16, 2017 at 8:34 PM
    Maddsilence
    Maddsilence New Member
    2017 MGM SR5 Tundra
    At that weight either wet or dry, you're in diesel territory. That sounds big for a travel trailer. Any details on it?
    757TUNDRA, zcarpenter92 and landphil like this.
  8. Mar 16, 2017 at 8:36 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Fair enough, you have every right to decline the nomination.:cool:
    Marketing ploys at their finest. Like look how lite this is.:benchpress:
    Law323 and ColoradoTJ[QUOTED] like this.
  9. Mar 16, 2017 at 8:39 PM
    I just don't have time. They can surf through the wasteland of useless posts on this topic.
  10. Mar 16, 2017 at 9:01 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    SOAPBOX! SOAPBOX! SOAPBOX!
  11. Mar 17, 2017 at 7:54 PM
    0xman
    howdy thanks for the replys. travel trailer is 7400 dry 8990 wet. hitch 1050. have husky centerline ts 800-1200lb. trailer brakes. haven't bought the trundra yet. sure is awesome truck. live in Michigan (Traverse City). was cherry capitol of us now its grapes. first travel trailer. not retierd yet so just be towing locally for now. all input is great. the Tundra max towing in manual was 10k I believe thanks
    ColoradoTJ likes this.
  12. Mar 17, 2017 at 10:14 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Theoretically, you could be within the weight limits (GVWR, Tow rating) with that setup. However, in order to stay within the limits it will be difficult. You would only be able to have maybe one other person with you in the truck (that is with a weight distributing hitch), in order to keep the GCWR within its limits. As you can see the Tundra would not be the optimum truck for a trailer that size. Could it pull it around? Sure it could, but you will likely be exceeding the weight ratings. Also the truck's suspension will be sagged substantially, regardless of the hitch (airbags recommended for that load). Some states have laws about weight ratings (that are enforced). In Oklahoma they are not really enforced...
    I mean many people are sticklers about staying within "lawful limits" so if that sounds like you I would go with a larger truck (3/4 ton+). A diesel 1 ton truck would be a very reasonable option for the trailer and load you are describing.
    It is better to have an over-equipped truck than an under-equipped truck. The Tundra is a great truck but you have to understand its limits. The trailer you are describing is definitely at the top of its limits. However I have seen people pull rigs as large as the trailer you are describing with the Tundra. I talked to one guy about the truck's performance when pulling a 9500 pound trailer and he had no complaints. That was on flat land though (Oklahoma and Kansas).
    I would look into the new GMC Sierra 2500/3500s. They are actually rated as more reliable than the Tundra by JDpower, as much as I do not agree with JDpower on may things...
    Law323 and zcarpenter92 like this.
  13. Mar 18, 2017 at 6:12 AM
    Page #5 will tell you everything you need to know.
    https://www.google.com/url?sa=t&rct...LRFAKzmlg&sig2=E8kNjLn_e2SDNSBKO347pQ&cad=rja
  14. Mar 18, 2017 at 9:04 AM
    Short and sweet.
