Looking at a 2000 with a bad trans.. questions
Discussion in '1st Gen Tundras (2000-2006)' started by Deezil, Mar 1, 2018.
  1. Mar 1, 2018 at 7:59 AM
    Deezil
    Deezil [OP] New Member
    Hello! As stated, bad auto trans, Im new to these so looking to see if its worth buying to fix. He said it has rust under, the rear bumper is rusted out, but it has no rust holes or anything like that....
    So, what do I all look out for, and anyone rebuilt the trans? What typically fails on these?
    Thanks
  2. Mar 1, 2018 at 9:20 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    The frames are known for rotting out. I would triple check the frame for rust-throughs. The steering is known for having problem with looseness. My guess is that the transmission fluid was never changed, which could also indicate other maintenance was skipped. The motors are known for being very reliable, so that is not too much of an issue as long as it is running well and not burning oil. A certified refurbished transmission will run around $1500, not including installation. A rebuild honestly will not save much money, unless you are doing the rebuild yourself.
  3. Mar 1, 2018 at 9:28 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Buy a 03-04 Transmission and swap it in, has the upgraded internals and you can normally get them for under $600 used.
    kenomouth64 likes this.
  4. Mar 1, 2018 at 9:58 AM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    This is truly your cheapest and best upgrade if you are going to swap it out. What symptoms are you experiencing with the trans? Toyota does a drain, filter change, new gasket and fill for around $200. If its a shudder, can be fixed with new fluid in the rear diff. You can also do all the fluids at home. Just make sure you can open the fill plug before opening the drain plug.
  5. Mar 1, 2018 at 10:21 AM
    Deezil
    Not sure what happened to the trans yet, Ill find out more. I would do the work myself. The 03-04 trans idea sounds good. Can those guts be put into the older cases do you know?
  6. Mar 1, 2018 at 11:35 AM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    The 03-04 trans will bolt on with no mods needed.
  7. Mar 1, 2018 at 11:52 AM
    Filthyphil
    Phil
    I would imagine so but don’t think it would be worth the effort.
  8. Mar 1, 2018 at 12:17 PM
    Deezil
    Just thinking out loud, if I bought a few of the upgraded guts and put them in the trans thats in it now, so I was wondering.
  9. Jul 23, 2018 at 9:36 PM
    Somemedic
    Somemedic New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    http://www.car-part.com/cgi-bin/search.cgi
    They have a trans w/ 35k on it for 150 plus shipping out of Fairmont Indiana.
    I got mine with 50k on it for 350 plus 150 delivered to my fire station out of Kenosha WI.
  10. Aug 18, 2018 at 8:27 AM
    TGattis
    TGattis New Member
    Troy
    02 Limited x-cab
    The 2000-2002 have a known issue with the OD planetary gears imploding, my '02 went at 83K miles (a lot of boat towing), picked up a complete unit from LKQ with 60K miles on it from an '04...supposedly a direct swap..It wasn't. I had to remove the tailpiece and swap them out, not a big deal, used some gray gasket maker in place of the factory paper one, that was about 190K miles ago and still no leaks.
