Looking a brand new Tundra for plowing
Discussion in 'General Tundra Discussion' started by jayman1967, Apr 15, 2019.
  1. Apr 15, 2019 at 10:23 AM
    jayman1967
    jayman1967 [OP] New Member
    Want to buy a brand new Tundra and Minnesota is a Ford 150 state, so I may have to go out of state to buy one, because I need a 8 foot bed. Tundra seems like the best buy for the money compared to Ford, Chevy and Dodge. The dealer by me is a Ford, Nissan and Toyota dealer, and they have over 100 F-150's, but only 2 Tundra's.
    My question is, can a Tundra be used for plowing without cracking or twisting the frame, because I thought you needed a 3/4 or 1 ton to plow? I live on a farm and my driveway is a 3 block long asphalt and only want to use it for that. been using a tractor and it sucks! Lol
  2. Apr 15, 2019 at 11:09 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome and yes you can. There are some members on here that have a plow on their Tundras. I don't recall their names, sorry.
    Blueknights75 and 15whtrd like this.
  3. Apr 15, 2019 at 11:23 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    It's doable with plenty of vehicles, I plowed commercially for a few years with a 98 Cherokee.
    There won't be any damage to anything as long as you realize the limitations of plowing with a truck vs heavy equipment.
  4. Apr 15, 2019 at 11:34 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I am in Florida so I don't know anything about snow, but my brother-in-law in Maryland does commercial snow removal and he has done a lot of research. He uses F-250s for his business, but he said that for occasional or personal use the Tundra would be just fine. He actually had a 1st Gen Tundra, his personal vehicle, that he had a small plow on to help out the F-250 crews when needed.
  5. Apr 15, 2019 at 12:01 PM
    jayman1967
    Thanks! I am sure I don't need a high end plow. Was thinking of just getting a $1500 personal plow.
    Boerseun and TXMiamiFan like this.
  6. Apr 15, 2019 at 12:57 PM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
    You might have to beef up the front suspension on the tundra, before adding a plow, as those are pretty heavy:curls:
  7. Apr 15, 2019 at 1:11 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    The guy that plows my driveway both for business and my home has a 2007 Tundra and has been going for a long time.
    He uses that for his beater truck and it looks like any other 2007 Tundra.
    Not sure if he beefed it up or not but that thing can push some snow.
  8. Apr 15, 2019 at 1:21 PM
    jayman1967
    Only going to plow up to 4 inches of snow with it. Anything more then that I will use the blower on the tractor. The plow I am looking at is only $1400, it is just a light weight home plow. Don't need anything more.
    Pudge and Boerseun like this.
  9. Apr 15, 2019 at 1:24 PM
    jayman1967
    Someone also told me to go out and buy a beater $2,000 plow truck, instead using a brand new $50K truck to plow with?
    Pudge likes this.
  10. Apr 15, 2019 at 1:39 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I just bought a brand new truck and wouldnt put a plow on it.
    I just dont want all the crap in front of it when I go off road.
    Look at the cost of what is being done.
    For example:
    Mowing a lawn my size cost 30.00 a week to mow.
    A zero turn costs around 5000.00 for a good one
    How many times would it cost to pay to have it mowed compared to buying a mower?
    Include gas, blades etc over the course of owning it.
    That is why I bought a 7500.00 mower.
    Cant really justify what you are using a 50,000 truck for because the cost is absurd.
    You do it because you want a nice truck
    jayman1967[OP] likes this.
  11. Apr 15, 2019 at 2:14 PM
    davescarp
    davescarp New Member
    Massachusetts
    '18 DC TRD OR
    I plow a few driveways with my tundra and it plows very well. Stock suspension is fine if the plow is correctly matched to it. I wouldn't buy a lightweight plow, but a standard duty plow like a Fisher SD or HT. I spent $3k for my setup used. New they are closer to $5k
  12. Apr 15, 2019 at 2:29 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Given what you're looking at plowing a road basically you won't be happy with a $1500 plow, if it was a standard double wide driveway you'd be fine. Even at 4 inches you're going to be traveling 15-20mph to clear it well and the homeowner type plows aren't built for that.
    The beater truck is an ok idea but another piece of equipment to service. A better option IMO would be to get a cab for the tractor.
  13. Apr 15, 2019 at 5:00 PM
    jayman1967
    Thanks! My driveway is only 6 feet wide. Probably just stick with the tractor. I live on a farm and don’t have a truck since my 99 Suburban died, so looking forward to it.
  14. Apr 15, 2019 at 5:54 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Believe it or not being narrower makes it worse. At full angle a 7.5' plow is about 6.5' wide. You can't really go any narrower on a Tundra since you want it wider than the track width.
    So even angled you're wider than the drive which means you're grabbing turf on each side stressing the plow even more.
    Tractor seems like the best plan for sure.
  15. Apr 15, 2019 at 6:21 PM
    jayman1967
    Ah! Thanks for the advice!
  16. Apr 15, 2019 at 8:20 PM
    BlueDream
    This might be best idea. A friend of mine in No. idaho has a real nice tacoma, but uses an old beater Ford 4wd truck just for plowing his long driveway to the road. Why risk the good truck?
  17. Jun 10, 2019 at 4:28 PM
    2004lb7
    2004lb7 New Member
    Ian
    Boss plow. Tows trailers everyday.
    I've used my Tundra for plowing for 6 years with a Boss plow. I also tow my landscaping equipment every day. Close to and over 10,000 every week! Now that I'm at 160,000 I can say that I have plowed in up to a 40 inch storm and many others with no damage. I plow 4 HOA roads with a total of about 5 miles of road and plow about 38 driveways every storm. All Ive done is one set of pads on the front brakes and two sets on the back.
  18. Sep 14, 2019 at 7:34 PM
    whiskeyjack
    whiskeyjack New Member
    ________________
    A little late to the thread, but since winter is coming up fast in northern Minnesota I thought I'd add a post.
    I've got a gravel 450' driveway and large park space in front of a garage. Commercial plow guys didn't show up when I needed them. So, about 5 years ago I bought a new Meyer plow for my Gen 1, 2003 Tundra. After considerable research, it was the lightest plow I could find with all the robotics I wanted at about $5k installed. I did install a leveling kit on the truck which made things more stable - it really wasn't 'needed'. The more important thing is to have recommended tire size: that'd be 265's. I've gotten along with 245's ok but mounting and dismounting is more difficult with smaller (lower, shorter) tires. That one inch or so makes a huge difference.
    Meyer makes a really nice plow with the longest warranty among plows: 5 years. That said, every plow I've ever owned was a pain in the ass to mount and dismount regardless of advertising.
  19. Sep 16, 2019 at 4:26 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Use a beat up Dodge for plowing. Take the Tundra out on dates....
    T-Rex266 likes this.
