Looking a 2000 Tundra limited
Discussion in '1st Gen Tundras (2000-2006)' started by willieb, Nov 27, 2019.
  1. Nov 27, 2019 at 6:09 AM
    willieb
    willieb [OP] New Member
    2000 Green Tundra Limited
    Hello. My first post. I am looking at purchasing a 2000 Tundra limited. I have not seen it but I'm going this weekend. It has 115,000 miles frame was replaced in 2011 by Toyota. no accidents, 2 owners and decent service records. What should I look for? Thanks. I'm excited.
  2. Nov 27, 2019 at 6:19 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Normal stuff. Take for an extended test drive at various speeds.
    Also, check or verify timing belt replacement - was due at 90 or 100k miles. If not done already it is a costly maint. item around $1k. If not done, factor that in on price.
    And Welcome from TX!
  3. Nov 27, 2019 at 6:19 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Even a new frame can rust after 8 years so check thoroughly.
    Other then that I would check for timing belt replacement as it should be done every 90k miles.
    Check the condition of the transmission fluid (just pull the dipstick and check the color). Red is good. Dark red is okay but due for changing. Black is bad and could spell transmission damage.
    Also see if the lower ball joints were replaced when they did the frame swap.
    willieb[OP] and speedtre like this.
  4. Nov 27, 2019 at 7:03 AM
    willieb
    Awesome. Thank you! much appreciated.
