Longer wheel studs or different lugs?
Discussion in 'Wheels & Tires' started by white offroad, Mar 2, 2018.
  1. Mar 2, 2018 at 6:45 PM
    white offroad
    white offroad [OP] New Member
    Anthony
    North Carolina
    Well went to pick the truck up with the new lift, wheels and tires.And the guys at the shop told me they wouldn’t recommend driving it. When they put the new wheels and tires on the lug nuts only went down about 5 full turns on the front and 7 turns on the back. He said it should go down 12-13 turns. So looks like I have to wait until Monday when I can fins longer wheels studs. Does anyone have a recommendation or ran into similar issue? Wheels are Hostile Alpha 20x10 -19 offset.
  2. Mar 2, 2018 at 6:58 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    kind of odd, new one on me. Did the new wheels come with new lugs? If not your old lugs may not be engaging on threads like they need to. 12-13 turns sounds on the high end to me. I have heard 6-7 turns min. before but bigger rims nay require more.
  3. Mar 2, 2018 at 7:05 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I know you can't use the OEM lugs on the new wheels. Did you get new lugs? If you did then I think you're gonna need longer studs.
  4. Mar 2, 2018 at 7:22 PM
    white offroad
    Anthony
    North Carolina
    They were shipped with new lugs. But from I’ve been reading a lot of aftermarket wheels may require extended thread lug nuts. I guess I’m gonna run by the local discount tire tomorrow and see if they have any. If I could get a few more rotation turns out of them I think I would be alright.
    The guy at the shop kinda scared my wife when he showed her and started with the whole your wheels may fall off stories.
    831Tun likes this.
  5. Mar 2, 2018 at 7:27 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Interested to see how this turns out. GL
  6. Mar 2, 2018 at 7:31 PM
    Damn that is going to be spendy.
  7. Mar 2, 2018 at 7:32 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    I personally dont use them but you have the option of spacers with longer studs.
  8. Mar 2, 2018 at 7:32 PM
    n2deep
    n2deep Pavement Princess
    Extended thread lugs or the correct way is longer studs
    ColoradoTJ likes this.
  9. Mar 2, 2018 at 7:55 PM
    white offroad
    Anthony
    North Carolina
    Anyone got a part number or recommend a longer wheel stud for a 2014?
  10. Mar 2, 2018 at 8:10 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    You need to make sure your wheels take ET lugs.
  11. Mar 2, 2018 at 8:18 PM
    TheBeast The Beach
  12. Oct 20, 2018 at 9:14 PM
    Marty101865
    Marty101865 New Member
    MD
    2015 Tundra SR5
    I'm in the process of swapping out my 2015 Tundra SR5 steel 18 inch wheels for a set of alloy 20's off of a Platinum, I've run into the same issue. Shorter studs used for the steelies so now the alloy/aluminum rims wont bolt up. (Why the swap...3 of 4 bent rims and won't balance)
    I've replaced studs before but I'm afraid the axle shaft will have to come out to swap the rear.
    Anyone done wheel stud replacement on the rear axle, 2015 Tundra?????
  13. Oct 23, 2018 at 6:20 AM
    white offroad
    Anthony
    North Carolina
    I ended up going with with extended thread lug nuts. Much easier and cheaper than all new studs were. I haven't had any trouble at all and I picked up the new lugs at discount tire for like $30 or so.
  14. Oct 23, 2018 at 6:44 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    +1 ET lugs have more thread (bottom row)
    dandailey and white offroad[OP] like this.
  15. Oct 23, 2018 at 7:26 AM
    agentcox000
    agentcox000 "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
  16. Oct 23, 2018 at 7:45 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Gorilla Lugs 26143ETBC. Extended thread. They look sharp.
    Installed last week. Got over 8 turns with Enkei Commanders, YMMV.
  17. Oct 23, 2018 at 8:07 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You need a different style lug nut with stock wheels. Should be Toyota #90942-A1001.
    The SCS/Gorilla nuts listed above are a cone seat style nut while you need a mag style for stock wheels.
  18. Oct 24, 2018 at 4:10 AM
    Marty101865
    MD
    2015 Tundra SR5
    Thanks for the replies! After a couple hours of thinking about it, I went to the Camburg site that was recommended and noticed the Lug Nuts with a bayonet type of thread. Seems to be what I need. I ordered a set of Venom lug nuts that should work. Sorta felt dumb for thinking of changing the lugs, just ruling out the hard stuff first!
    Thanks everyone!
  19. Oct 24, 2018 at 4:33 AM
    Professional Hand Model
    Hand Protectors
    Gotta love an easy fix!
  20. Jun 22, 2020 at 12:08 AM
    Guti94
    Guti94 New Member
    2012 Toyota tundra
  21. Jun 22, 2020 at 12:08 AM
    Guti94
    Guti94 New Member
    2012 Toyota tundra
    Can some one tell me why our studs are only this long
