Long time reader first time posting
Discussion in '1st Gen Tundras (2000-2006)' started by FastEddie05Tundra, Oct 16, 2018.
  1. Oct 16, 2018 at 8:52 PM
    FastEddie05Tundra
    FastEddie05Tundra [OP] New Member
    Eddie
    05 Tundra TRD 4x4
    Toy Tec coil overs Flowmaster exhaust K&N Intake 285/70/18 Nitto Ridge Grapplers
    After reading posts for a while, I thought I would try to get some advice.
    Just recently bought the ToyTec Suspension system for my Tundra needed an upgrade over my Bilstein adjustables that didn’t break the bank. Felt like I got more bang for my buck upgrading to the 700lb spring and going with the added leaf for the rear, almost forgot to mention the SPC UCA. Compared to some other suspension systems.
    Has any one attempted to put on a set of 285/70/18 Ridge Grapplers on after the lift system with out cutting fenders? Do I need spacers?
    I’m installing lift tomorrow.
    I’m sure this is not the first time this had been asked but can’t find anything about this subject on the forum.
    Any advice would be great.
    Black Wolf likes this.
  2. Oct 16, 2018 at 8:58 PM
    Welcome from CO. Can't help with your situation but plenty of 1st gen members here that can!
  3. Oct 16, 2018 at 8:58 PM
    Marty McFly
    Morty McBoonJug
    Welcome from SoCal sir :hattip:
    I’m running the same size toyo MTs on Pro suspension. I don’t think you should have any issues. Could depend on if your running stock wheels or aftermarket.
    Edit: you have a first gen. Maybe a 1st gen member can chime in.
  4. Oct 16, 2018 at 9:00 PM
    Casper421
    In the woods
    06 DC
    You will need a body mount chop(bmc) and a lot of trimming. My plans are for 285/75r17’s(34x11) and I already know I will need to trim and cut a ton to stuff them without contact. I ran this size on my 4runner with 4” lift and still had to trim and cut a lot. I’ll only be running 2-2.5” on the tundra.
  5. Oct 16, 2018 at 9:03 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Eddie.
  6. Oct 16, 2018 at 9:20 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    285/70/18 is almost a 34x11.25
    The answer depends on wheel backspacing. If you are at 4" backspace you'll not have to trim much, just the very corner of your front bumper and a bit of plastic near the pinch weld and see where that gets you. If you find that you are hitting body in front of the door you may need to hammer the punch weld area inward to flatten it. This isn't an extensive procedure at all.
    If you have more than 4", like 4.5", you'll hit frame at full lock but it wont be too bad. Not sure if you'll hit the upper arm l, I dont have experience with SPC arms. If you are running stock wheels you may need spacers to clear the upper arm, I know this would be the case with stock upper arms but not sure with SPC arms.
    If you have less than 4", like 3.5", you will avoid frame but will likely hit that pinch weld area previously mentioned.
    Welcome to the forum, good model of the truck. Post pics when you can.
  7. Oct 16, 2018 at 9:29 PM
    FastEddie05Tundra
    Eddie
    05 Tundra TRD 4x4
    Thanks for the reply’s and the salutations. Didn’t think I would have to do so many mod’s for that tire size even for a few inches. Especially if I’m already running 285/65/18 with aftermarket rims on basically bilstien adjustables with no issues. I’ll try to post before and after soon.
  8. Oct 17, 2018 at 3:54 AM
    Professional Hand Model
    Hand Protectors
    Post pics and tell us how it goes. Lets others know what can be done.
  9. Oct 17, 2018 at 3:56 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  10. Oct 17, 2018 at 3:58 AM
    Welcome from NY.
  11. Oct 17, 2018 at 6:13 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  12. Oct 17, 2018 at 6:36 AM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  13. Oct 17, 2018 at 11:34 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Do you have a winch and/or aftermarket front bumper? I hear the the 700lb coils can be rough if you don't. But I've also heard they're fine on a DC. I have an AC and would like to lift it in the next month or two, but won't be able to afford a winch and bumper for a while and was thinking about buying the 700lb coils instead of the 650 so I don't have to pull it apart to upgrade later. Let us know how it turns out! :)
  14. Oct 18, 2018 at 8:44 AM
    FastEddie05Tundra
    Eddie
    05 Tundra TRD 4x4
    No wench or aftermarket bumper yet. Possibly bumper for front end in the near future. And yes my baby is a DC, after reading the reviews and suggestions I went that route. Definitely will post pics upon completion.
  15. Oct 18, 2018 at 8:14 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Completion? Hell, we wanna see it now!
    because_wumbo-truck likes this.
