Long start ONLY after truck sits for a few hours
Discussion in '2nd Gen Tundras (2007-2013)' started by Benlee, Apr 4, 2025.
  1. Apr 4, 2025 at 12:51 PM
    Benlee
    Benlee [OP] New Member
    Ben
    2008 Toyota Sequoia (Limited)
    I have a 2008 Tundra with 145k miles and it has a long start only after it has been sitting for more than an hour or so. If it has been sitting for a long time or especially sitting overnight then it will restart perfectly every time. If I make a quick stop at a store for a few minutes, or even if it sits for 30+ minutes, it will restart perfectly.
    The truck runs great, so it does not seem like a fuel pressure or pump issue, and the battery and starter are strong.
    What could the issue be?
  2. Apr 4, 2025 at 6:27 PM
    82nd Airborne
    82nd Airborne New Member
    2012 SR5 DC
    Operator error o_O
  3. Apr 5, 2025 at 4:33 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Corroded batt cables/connections, poor grounds.
  4. Apr 5, 2025 at 6:37 AM
    koditten
    Kirk
    Midland of the Mitten
    Does the exhaust smell like raw gasoline when it finally starts?
    Could be leaky injectors. Pretty common on 1st gen trucks, but I've not read of it being an issue on second gens.
    All I can offer.
  5. Apr 5, 2025 at 6:49 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Your post says its a Tundra, but truck info says it's a Sequoia. Either way, it's still a 2UZ, correct?
    Here's what I would in the Field Service manual.
    DI-374 STARTS ON PAGE 644 OF THE FSM
    DI-266 STARTS ON PAGE 536 OF THE FSM
  6. Apr 6, 2025 at 9:05 PM
    Benlee
    Ben
    Correct, it's a Sequoia, but I figured that since it is the same engine as a Tundra, more people might weigh-in if I just referred to it as a Tundra. Engine is 3URFE
    Would the guides that you posted above still apply?
  7. Apr 7, 2025 at 8:58 AM
    Outlander 1000R
    Outlander 1000R New Member
    08 Tundra SR5 TRD
    I have an 08 tundra and it's doing the same thing driving me crazy. What's strange is it doesn't throw a code/ check engine. I've cleaned the throttle body, replaced plugs, and just recently replaced all injectors with Denso. I'm at wits end. One of these days it will not start. Seems like a possible throttle position sensor or possibly maybe the whole throttle body needs to be replaced. I've got 181k and runs like day 1. Anybody help??????
  8. Apr 8, 2025 at 9:10 AM
    Benlee
    Ben
    No codes for me either. I'm really dragging my feet on replacing the injectors since they are around $150 each for OEM injectors, so I'm trying to rule out all other possibilities first.
