Long Lumber/ Short Bed
Discussion in 'Towing & Hauling' started by CM2007, Feb 8, 2021.
  1. Feb 8, 2021 at 8:01 AM
    CM2007
    CM2007 [OP] New Member
    Northern California
    2007 CrewMax SR5
    TRD Exhaust, Dark Tint, Bluetooth (2020 or earlier) License Plate Camera (2021) Tyger T1 Roll Up Tonneau (2021) Loncky leather steering wheel wrap (2021) Dechromed with Plasti-Dip (2021) Osram Reverse Bulbs (2021) Bilstein 6112s up front (April 2021) 2022/2023: New Head Unit (Android?) Sliders/concealed running boards
    No lumber rack. No trailer. Plenty of ratchet straps.
    I’ve been hauling 4x6 pressure treated posts 12’ long. Curious what the limits are for my 5.5’ bed with weight on the tailgate when it’s up and when it’s down.
    If I, for instance loaded fifty 12 footers, the tailgate would definitely have too much weight on it in either position. I assume the safer way to load is keeping them flat.
  2. Feb 8, 2021 at 8:11 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Whatever you do, make sure it's clearly marked with a red flag for other people on the road.
    With that many 4x6x12' pressure treated (heavy), I'd consider a one time delivery fee from your supplier.
    Cpl_Punishment likes this.
  3. Feb 8, 2021 at 8:18 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    For 50 4x6x12 I would rent a trailer.
    The only really way to haul long lumber in a short bed is to get a lumber rack. I prefer the type that has a fixed front (headache rack) and a removable read rack. The fixed front rack protects the cab when leaning long lumber, steel, pipe, etc on it and for really long items (20' lengths of steep) put in the back rack. This method is for a few at a time, you don't want to much weight that high up.
  4. Mar 11, 2021 at 2:37 PM
    CM2007
    Northern California
    2007 CrewMax SR5
    I did just get a 20 footer of steel square tubing for a gate and had to cut the stick in half to haul...would be nice not to have to do that!
    I’ve been using a flag for the 12 footers- it’s getting old though. I’m definitely leaning towards the headache rack to avoid having the long load stick out the back.
    Speaking of load limits again- how many 4x6 12 footers could you lean against a good steel headache rack? I figure the weight limit is for loads pushing straight down, but so much would be pushing forward, especially while braking.
  5. Mar 11, 2021 at 4:07 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Rent a 16' tandem axle utility trailer. In my area, costs less than $40/day and no worry about damaging my truck.
    rockmup, Njmike13 and D4x4TRD like this.
  6. Mar 11, 2021 at 6:02 PM
    11SilverPlatinum
    11SilverPlatinum New Member
    Dave
    2011 Platinum Tundra
    Plastidip emblems, Pace Edward bed cover w/lumber rack, remote start, TRD intake and exhaust, TRD front and rear sway bars, color match grill surround, LED headlight upgrade.
    Pace Edward’s lumber rack. In the picture that is a 20ft piece of treated framing. Like what was previously mentioned. Can’t load a lot up high, but I have used it a lot. Red flag is a must, and a red light if you are traveling at night. F1D8FBE7-EBAE-49B5-A55D-496E6CACA1EE.jpg
