locking issues
Discussion in '2nd Gen Tundras (2007-2013)' started by johnbrents, Aug 14, 2017.
  1. Aug 14, 2017 at 8:27 AM
    johnbrents
    johnbrents [OP] New Member
    john
    2008 white 4 door tundra sr5
    what cause my tundra to lock all the doors except the drivers door when i use the key fob?
  2. Aug 14, 2017 at 9:49 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    What happens when you press either lock button on the inner door panel?
  3. Aug 14, 2017 at 10:45 AM
    johnbrents
    john
    when i press the lock button it doesn't lock, you have to manually unlock it or lock it with the key if you are outside, the passenger door lock button will lock the doors except the drivers door.
  4. Aug 14, 2017 at 10:51 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Yup, sounds like the lock actuator motor.
  5. Aug 14, 2017 at 10:54 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    See if it's just sticking first before you replace it.
  6. Aug 14, 2017 at 12:01 PM
    johnbrents
    john
    how do i check it for sticking, and if it is just sticking then why does it respond to the speed and lock itself when i get up around 10/15 miles per hour?
  7. Aug 15, 2017 at 4:41 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
  8. Aug 16, 2017 at 6:25 AM
    johnbrents
    john
    hey joonbug, is it hard to replace an actuator in the drivers door? how do i check it for sticking?
  9. Aug 16, 2017 at 9:32 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Never replaced on my tundra but I have on another car. It's usually pretty simple. I would take the door panel off and just confirm it's a bad actuator and not just a rod that's bent or needs to be greased or something.
  10. Aug 16, 2017 at 11:34 AM
    johnbrents
    john
    thank you for your help.
  11. Nov 23, 2018 at 9:01 AM
    Tundra44
    Tundra44 New Member
    2007 SR5 CrewMax
    King shocks front and rear, Spider trax spacers on Rock Warrior rims, Demello Off-road front bumper with Tuff Stuff 12.5 winch.
    I’ve had my actuators in 3 out of 4 doors replaced twice (2007 Crewmax). Once under warranty, second time out of warranty, but under dealer’s good will. Now, 3 out of 4 are bad again, and the 4th is intermittent. The parts aren't cheap, even if you do it yourself.
