Lockers
Discussion in 'Performance and Tuning' started by joelmatson1991, Oct 3, 2021.
  1. Oct 3, 2021 at 10:57 AM
    joelmatson1991
    joelmatson1991 [OP] New Member
    Joel
    2006 tundra 2wd v8
    I got a 2wd 06 tundra V8 I Wana put lockers in the back. Don't know alot trying to learn need some direction on where to start to look and what not to get and such. Any help would be amazing thanks
  2. Oct 3, 2021 at 11:05 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Look at justdifferentials.com
    I plan on doing a Elocker from Eaton soon.
    ARB have a good reputation, but also have a reputation for being crap from bad installs and leaking airlines inside the diff
    joonbug likes this.
  3. Oct 3, 2021 at 11:09 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    My first tundra was a 2000, and I had a Powertrax No-Slip in the rear and I loved it. Pretty decent road manners and it was fairly cheap and locked up reliably. Granted I am not an avid off-roader, but the times I needed it, it worked great.
  4. Oct 3, 2021 at 11:35 AM
    WhyW8
    WhyW8 “It’s ALWAYS Loaded”
    HB
    Sunny AZ
    2017 Super White SR5 CM
    Level Kit, DiamonBack Tonneau, Step Boards, Alpine Amp, Cerwin Vega powered Sub
    Had ARB's front and rear in my old Jeep - only problem I ever had was a solenoid went out, but hey I had an extra one in my trail box -- expensive units but if set up correctly they work awesome.
  5. Oct 3, 2021 at 11:52 AM
    NorthWoodsTundra
    NorthWoodsTundra Hehehe, you said 'member'...hehehe
    2021 GMC 3500 SRW Gasser
    Another vote for Powertrax.
    Never used it in a Tundra but did install in a 2000 Jeep WJ and another in a '93 3500 woods truck and was very happy with it both times. Easy install and decent road manners but you did have to learn it's nuisances so it didnt lock up on you when you didnt want it to.
    HulkSmurf14 likes this.
  6. Oct 4, 2021 at 8:19 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Can you elaborate on the nuances? Or point me in the right direction for reading?
  7. Oct 17, 2021 at 6:06 PM
    NorthWoodsTundra
    Like pulling out into traffic and needing to stand on the skinny pedal because you miss-judged it, causing the locker to lock up halfway through the turn.
    Nothing like listening to the inside BFG KO screaming on dry pavement praying that the stock Jeep axle doesn't snap.
