Lockable tonneau cover options for the 6 foot bed
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spielightdude, Jan 29, 2022.
  1. Jan 29, 2022 at 6:08 AM
    Spielightdude
    Spielightdude [OP] New Member
    Joseph
    2019 Tundra TRD off road and towing package
    Hi everybody,
    Looking for options on tonnoue covers that have a locking ability but also easy to remove ifni neednto get a load of hay or things bigger than the tonneau cover can cover. I have the bed rail system
    On mi e of that makes a difference
    Thanks everyone
  2. Jan 29, 2022 at 6:12 AM
    TH1776
    TH1776 New Member
    FL
    040 PRO
    Look at Diamondback. You can remove it or just put the hay on top.
  3. Jan 29, 2022 at 6:21 AM
    I have this one on mine.
    https://undercoverinfo.com/undercover-se/2017/toyota/tundra
  4. Jan 29, 2022 at 6:27 AM
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
    I’m ordering the Bak Revolver X4s soon. Rolls up for full bed use without blocking the rear window, locks with tailgate closed and can put 400lbs on top of the cover is ever desired.
  5. Jan 29, 2022 at 6:29 AM
    Willard
    Willard New Member
    2024 F250
    As a diamondback owner I’ll say it’s not the most convenient cover to remove since the panels are 50 lbs apiece, and it requires tools. I even use this as an excuse when neighbors bug me about picking up appliances or taking large items to the dump for them.
    However, I do haul stuff on top quite a bit, so there is that option. And it’s both secure and weatherproof.
  6. Jan 29, 2022 at 6:35 AM
    racerex
    racerex New Member
    Will
    Westchester County, NY
    2021 Limited CM TRD Off-Road
    Another vote for the Diamondback HD….fully lockable, water tight and no real need to remove it. You can stack hay on the cover. I’ve yet to fully remove mine to carry anything in the bed….I just removed the back panel once to transport a tall object in the bed. Yeah, they’re not cheap….once you get over the sticker shock, it’s totally worth the investment if you plan on keeping your truck for awhile.
  7. Jan 29, 2022 at 7:12 AM
    hANNAbONE
    hANNAbONE T U N D R A M A
    Des Moines / Dull Moan, Iowa
    still lookin' for my first one
    Diamond Back....don't look back
  8. Jan 29, 2022 at 8:06 AM
    daw5spd
    daw5spd New Member
    Dave
    Eastern Oregon (Greater Idaho)
    2019 Cement Off Road DC
    Undercover SE tonneau TRD Rear Sway Bar AJT trim pieces Console wireless charger Drivers side grab handle Meso lights
  9. Jan 29, 2022 at 8:24 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I had a Retrax on my 2005.
    Worked well, but I could hear it rattle with the rear window down.
    I hear they might have fixed it.
    It locked into any position.
    The can takes up a lot of space but it can be removed with tools.
    The entire thing comes off, rails and all.
    Retraxopen_9d1b1f25e865c114040bf8de2f4e35bc8b7ca95d.jpg Bedrug4_2ba35858a58bbe75de78319bc6daf9e91ee46364.jpg
    I considered a Diamondback for my 2014, but it just seemed overkill for my needs.
    I have an Undercover Flex now.
    Not sure if I'd call it lockable, it locks down and the tailgate needs to be open to open.
    But it doesn't have an external lock on it.
    Been happy with the Flex.
    I wouldn't say it is waterproof, but it keeps most of the rain out.
    It opens up for almost a full bed, but if needed it comes off without tools.
    The rails stay on, they are attached to your bed rails, the top comes off pretty easy.
    I added the extra tie-downs.
    The black clamps were after I bought the bed rail system, the silver clamps were before I had the bed rail system.
    7xupm161_4097a811ab429bf0099536d3b378fb684177b4f7.jpg 6i7o312u_7fe4167765c73656caa1ef82c164e5af6b3c281c.jpg
    79999485-1BF1-47BD-BE7A-392B4B48BCED_zps_901fe110956e4ce9426df6b56163791119740297.jpg BDCCBD99-9D85-4185-9EFA-FED2EAA37381_zps_e4d3c8a6b3091a9a05b4e5cfec7d1445def77f00.jpg
    E56C2A52-CB37-4473-BA4A-B034B228A760_zps_502eb92db0716579cf47540ed62f91eb57e1d310.jpg
    It came with cheap drain tubes but I customized mine a little..
    E355DC48-7966-4544-ADAD-18E9F2EFB8F2_zps_e92daa3e773b904f1a007a76b913a8bee749e935.jpg C53E03AA-7462-4102-9DC9-BA6292984014_zps_5e2976ed3ad235188897ceda57e2e8d4470f817d.jpg
    Toyota Fan Boy likes this.
