Load rating?
Discussion in 'Wheels & Tires' started by redryder, Mar 17, 2019.
  1. Mar 17, 2019 at 7:40 AM
    redryder
    redryder [OP] New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    Probably a stupid question, but how do I find the load rating on my Nitto Ridge Grapplers. I'm sure they are LT but I can't find it on the tires.
  2. Mar 17, 2019 at 7:46 AM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    I have KO2’s on my truck, right under the tire size on the tire it says load range E.
  3. Mar 17, 2019 at 7:57 AM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    2016 Tundra CM 4wd TSS
    Tacotunes SQ1 package Bilstein 5100's @ 1.5" plus 2 shims Toyotec Shackles at 1" Firestone Ride Rite Airbags SCS SR8's 285/70r18 Nitto Ridge Grappler's Bed Cover Tow Mirrors Windows Tinted Window Visors Weathertech Floor Mats
    Here's where it should be. Notice the LT is right in front of the tire size too.
    Darkness, OR18TRD and NewImprovedRon like this.
  4. Mar 17, 2019 at 7:59 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    It's on their site.
  5. Mar 17, 2019 at 1:18 PM
    redryder
    Ryder
    Louisiana
    Ok I found it. Apparently it's a 117T XL.
  6. Mar 17, 2019 at 2:48 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Sounds like they are P rated then. 117 is the load index, T should be the speed rating, and the XL denotes the max psi which I believe is 41psi at max load.
  7. Mar 18, 2019 at 7:46 AM
    redryder
    Ryder
    Louisiana
    So as long as I'm not hauling or towing anything crazy heavy I should be good?
  8. Mar 18, 2019 at 4:52 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    A load index of 117 gives the tire a carrying capacity of 2833 lbs. @ the max pressure of the load range XL which is 41psi.
    In other words, yes as long as you're not towing or hauling anything too heavy you'll be fine
