Load lifter 5000 ultimate
Discussion in '2.5 Gen Tundras (2014-2021)' started by Abdul98, Nov 20, 2020.
  1. Nov 20, 2020 at 8:08 PM
    Abdul98
    Abdul98 [OP] New Member
    Abdul
    2020 Toyota Tundra limited double cab
    Looking to add the loadLifter 5000 ultimate to my tundra. Does anyone have these installed and their tundra that could give me some feedback? I've tried looking for reviews, specifically on the tundra with no luck. I load my truck daily and she squats pretty good. Been looking at these airbags for a while now and wanted my fellow tundra owners to give me some insight.
    saybng likes this.
  2. Nov 20, 2020 at 10:22 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I run the firestone ride rites and have been for 170k miles now with no issues with my own rigged up compressor.
    Air bags are great I tow alot and they're great for different sized trailers I pull. Especially since my stock leafs are pretty worn out now.
    The load.lifters have an internal jounce which will ride rough from what I've read.
    I'd recommend the firestones over the load lifters. That's my 2 cents.
    szabo101 and saybng like this.
  3. Nov 20, 2020 at 10:29 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I have a set on order myself.
    I had a set in a 2014 ram 1500 for work and they were perfect for 4 years till the truck was miled out and sold.
  4. Nov 20, 2020 at 10:50 PM
    Maadcaap
    Maadcaap White Tundys
    Rancho Cucamonga, Ca.
    2019 Trd Pro
    275/70/18 KO2
    I have had those bags on for about a year now... they do the job, leveling my truck when towing...
    i went with airlift because you do not have to relocate the brake bias box... if you look at etrailer.com website they have detailed install videos.. on airlift and firestone
    you will have to cut your stock bumpstops...
    i also installed the daystar cradles so the bags wont limit articulation in the rear...
    These have a built in bumpstop so you can run them without air.. but you might feel it when hitting large bumps....
    saybng likes this.
  5. Nov 20, 2020 at 11:02 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
