CLOSED - Coachbuilder Shackle and Steering Kit GB
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by memario1214, Mar 2, 2022.
Thread Status:
Not open for further replies.
  1. Mar 2, 2022 at 10:47 AM
    memario1214
    memario1214 [OP] Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Here it is! The ANNUAL Coachbuilder Shackle Sale is now CLOSED - 2022 Edition
    Sign-ups will run from March 2 - March 16 (I've got some Irish blood in me so I couldn't run it thru the 17th)
    https://shop-coachbuilder.myshopify.com/ <-- Use this link to the CB website to assist your research.
    Group Buy / Sale info -
    • Prices will be 15% off of already advertised prices on Coachbuilder Shackle Kits or Steering Kits.
    • Shackle Pricing After Discount will be:
      • +1" Shackle - $259.25
      • +2" Shackle - $267.75
      • +3" Shackle - $289
    • Steering Kit Pricing After Discount will be:
      • OE Replacement - $354.37
      • BDS/Bulletproof kits are also eligible
    • Shipping will be FREE ONLY IF 50 orders are achieved for a respective product type (Ex: 50 shackle orders will unlock free shipping for shackles only).
      • You will be charged shipping when ordering, and applicable shipping charges will be refunded after order is processed by CB (to avoid non-eligible products added at same time getting free shipping as well).
    • Sale rate applies ONLY to Coachbuilder Shackles and steering kits.
    • This pricing will only be able to be captured via discount code for those who indicate they are in.
    • Taxes will need to be captured for Utah residents.
    ORDER-TO-DELIVERY ESTIMATES -
      • Steering Kits - Approx 4 weeks order to delivery
      • Shackles - Approx 6-8 weeks order to delivery (Bushing availability delays)
    SHACKLE SPECS -
    • Precision... CNC Machined from T6 6061 Billet Aluminum
    • Engineered To Be The Strongest Shackles Available For Your Tundra
    • Designed To Improve Ride Quality And Reduce Bed Bounce
    • Eliminates any side to side flex.
    • Improves Strength While Towing
    • Finished In Hard Black Anodize
    • Made In The USA
    • MFG Ekstrom Design & Fabrication Corporation
    • Works With TRD Dual Exhaust
    • Works with your OE or Any Aftermarket Leaf Pack
    • Still allows full sized spare to be used
    • Installs in 45-60 mins
    • Compatible With ADS, Bilstein 5100/5160, Fox, Icon, King, OME, TRD Pro
    STEERING KIT SPECS -
    • Improved strength and increase travel at the steering by up to 30%.
    • Greatly reduce bumpsteer and uneven tire wear.
    • Clean bolt on with no modification.
    • 7075 Billet W/Hard Anodized Finish, 7/8″ Forged 4130 chromoly rod end, PTFE inserts, 303 stainless misalignment spacers, rubber grease boots and hardened hardware.
    • Installs in 45-60 Mins
    • Please Note: When using OE Spindles and installing joint on under side of steering knuckle you MUST be running at least a 17" wheel with +25mm or less offset. 18″ wheel with a +35 mm offset or less, 20″ or larger wheels work with any offset.
    • When using Aftermarket Spindles with applications installing joint on the top side of steering knuckle you MUST being running 18" wheels with 0mm offset or less. 20" Wheels require +25mm offset or less.
    FINE PRINT - READ ME
    • David Ekstrom aka Coachbuilder will have access and visibility to this thread. He will likely pop in from time to time to answer questions, but no promises on timelines for his availability. He is busy making goodies for your race truck! You can forward your questions to me and I will make sure he gets them, and I will make a Q&A down below here for common questions as they arise. Trying to keep as many calls/texts off of his plate as possible.
    • The discount code will be sent to you via PM on March 16th or 17th if you are on the list that will be maintained in post #2. If you don't see your name and want to be on the list please let me know!
    • As it stands right now there will be no shipping of product or releasing of discount code before March 17. Ekstrom Design reserves the right to open the ordering process early and start doing some shipments if he feels comfortable doing so. That said... If you definitely want in I recommend that you don't wait around.
    • INTERNATIONAL CUSTOMERS - Please reach out to Ekstrom Design directly at (801)-635-4872 for custom quotes. He'll ship anywhere though!
    SO YOU WANT SOME BA SHACKLES OR A STEERING KIT (OR BOTH)?
    Sign up by simply replying "In" or something of the sort in this thread AS WELL AS YOUR ORDER. Pricing has already been announced and revealed so there is no mystery. Please be committed to the sale if you indicate so. It will help David gauge build needs, and make sure he has what we need.
    There will be a list in post #2 that will contain usernames.
    MAKE SURE YOUR NAME IS ON IT OR YOU WON'T GET A CODE!
    **Disclaimer: Hotshot Offroad is not being compensated in any way nor are we directly affiliated with Ekstrom Designs. We're running this GB because we are passionate about the Coachbuilder brand and are looking at picking up the steering kit for our '21 Tundra build at the discounted GB rate.**
    Chowdah, batman900, Patch999 and 3 others like this.
  2. Mar 2, 2022 at 10:47 AM
    memario1214
    Colton
    Missoula, MT
    THE LIST - MAKE SURE YOUR NAME IS HERE
    Shackles -
    1) @Elduder +1
    2) @Nbab23 +2
    3) @motoryder +3
    4) @JonnyT +1
    5) @SoJersey +1
    6) @Tundra18overland
    7) @Brypro91 +1
    8) @happyb +3
    9) @te37_daniel +2
    10) @CCarr +2
    11) @Aswongsc +1
    12) @FISHN43 +3
    13) @baron +3
    14) @SnowSquach +3
    15) @TRDPRONYC +3
    16) @TucsonTundra1794 +1
    17) @SHAKA U F4KA +2
    18) @bmw345 +1
    19) @Kenny1794 +3
    20) @808Tunderer +2
    21) @mr2icky +2
    22) @COElkHunter +2
    23) @BasicAverageTruck +3
    24) @FredB32 +1
    25) @Chowdah OE Kit
    26) @mtlmlta182 +2
    27) @Jamyers13183 +1
    28) @TFTundra +1
    29) @MyActualName +1
    30) @danno266 +1
    31) @Fugis281 +3
    32) @AGSport +1
    33) @DETN8R +3
    34) @InfernoBoyz +1
    35) @Jude +1
    36) @Talon7 +2
    37) @ptat +3
    38) @Fish River Tundra +2
    39) @Kajunxplorn +2
    40) @TundraFRD +2
    41) @blakeakt +1
    Steering Kit -
    1) @Anelson1 OE Kit
    2) @4.6LBenchCrewMax4x4 OE Kit
    3) @happyb OE Kit
    4) @Aswongsc OE Kit
    5) @TucsonTundra1794 OE Kit
    6) @AZTundra OE Kit
    7) @Netmonkey OE Kit
    8) @RaginTxn OE Kit
    9) @LifeCycle OE Kit
    10) @KENNY OE Kit
    11) @mr2icky OE Kit
    12) @SAGE63 OE Kit
    13) @Chowdah OE Kit
    14) @fullofbs OE Kit
    15) @RegGex OE Kit
    16) @Spvrtan OE Kit
    17) @DW707 BDS Steering Kit
    18) @Kiddnapped Tundra OE Kit
    19) @Fish River Tundra OE Kit
    20) @memario1214 OE Kit
    21) @tightywhitey OE Kit
    22) @meinbomb OE Kit
  3. Mar 2, 2022 at 11:13 AM
    Elduder
    Elduder New Member
    memario1214[OP] likes this.
  4. Mar 2, 2022 at 11:14 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    In for a +2 Shackle
    memario1214[OP] and Elduder like this.
  5. Mar 2, 2022 at 11:24 AM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Literally just night a steering kit yesterday :(
  6. Mar 2, 2022 at 11:25 AM
    motoryder
    motoryder ^^ I probably crashed after that pic
    Rancho Cucamonga, CA
    2500HD AT4
    In for +3 shackles.
  7. Mar 2, 2022 at 11:29 AM
    JonnyT
    JonnyT New Member
    Jonny
    2015 Tundra SR5 Dc
    In for +1 Shackles
  8. Mar 2, 2022 at 11:35 AM
    SoJersey
    SoJersey New Member
    In for +1 shackles
    Trying to talk my father and buddy into a set also.
  9. Mar 2, 2022 at 11:35 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    @memario1214 Can I share the link and/or details on a local FB page? I know a few people that may be interested as well.
    I can have them contact me directly if you'd rather. Just lmk
  10. Mar 2, 2022 at 11:39 AM
    a_double
    a_double New Member
    Regarding this point:
    • Please Note: When using OE Spindles and installing joint on under side of steering knuckle. you MUST be running at least a 17" wheel with +25mm or less offset. 18″ wheel with a +35 mm offset or less, 20″ or larger wheels work with any offset.
    In what case would you mount the steering kit below the knuckle?
  11. Mar 2, 2022 at 11:41 AM
    memario1214
    Colton
    Missoula, MT
    You should know better by now to not purchase ANYTHING without asking me first :rofl:
    Ross - Please do! I'll be posting up probably this evening or tomorrow on other FB groups that I am a part of a well to try to drum up some more folks. I would say either have them make an account/post here, you can conglomerate the list on your side, or have them reach out to us at Hotshot Offroad (email, messenger, etc) and we can maintain the list from our end. The choice is yours as long as we get the information in a timely manner and it's in a consumable format.
    GODZILLA likes this.
  12. Mar 2, 2022 at 11:42 AM
    memario1214
    Colton
    Missoula, MT
    Aftermarket Spindles - Here's the associated note on the CB site:
  13. Mar 2, 2022 at 11:51 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    perfect. I’ll direct them to the post first. Thanks for organizing this!
  14. Mar 2, 2022 at 11:58 AM
    Anelson1
    Anelson1 New Member
    2020 Super White Crew Max
    Tint
    IN for a OE replacement steering kit!
    Thank you for setting this up.
  15. Mar 2, 2022 at 12:03 PM
    CornbreadTRd
    CornbreadTRd New Member
    PDX
    2020 Tundra Quicksand
    In for +3 Shackles
  16. Mar 2, 2022 at 12:14 PM
    a_double
    a_double New Member
    But the note in OP refers to OE spindles.
  17. Mar 2, 2022 at 12:22 PM
    memario1214
    Colton
    Missoula, MT
    I apparently didn't read the question entirely. If your truck has an OE spindle right now the joint of the outer tie rod should be entering from underneath.
    OP updated to add aftermarket spindle verbiage as well.
    a_double[QUOTED] likes this.
  18. Mar 2, 2022 at 12:46 PM
    4.6LBenchCrewMax4x4
    4.6LBenchCrewMax4x4 New Member
    Put me down for a STEERING KIT.
  19. Mar 2, 2022 at 1:10 PM
    a_double
    a_double New Member
    Gotcha. So this is where the hub spacer requirement comes in with OEM 18" wheels...
  20. Mar 2, 2022 at 1:16 PM
    Brypro91
    Brypro91 New Member
    2019 tundra trd or cement
    In for +1 Shackles
  21. Mar 2, 2022 at 1:25 PM
    happyb
    happyb New Member
    IN FOR +3" SHACKLES AND OEM STEERING KIT
  22. Mar 2, 2022 at 3:06 PM
    te37_daniel
    te37_daniel New Member
    Lunar Rock TRD Pro
    18 TE37 large PCD, KM3s
    In for shackles- still researching if I want +2 or +3. will update shortly.
    Update: in for +2's
  23. Mar 2, 2022 at 3:12 PM
    CCarr
    CCarr New Member
    In for +2 shackles
  24. Mar 2, 2022 at 4:57 PM
    Aswongsc
    Aswongsc New Member
    In for +1 shackles and oem steering kit
  25. Mar 2, 2022 at 6:06 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    We getting a group buy for the roof racks too?!
    AZTundra likes this.
  26. Mar 3, 2022 at 10:10 AM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    In for +3 shackles!
  27. Mar 3, 2022 at 10:18 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    In for steering kit
  28. Mar 3, 2022 at 10:43 AM
    baron
    baron New Member
    Brett
    2021 TRD Pro
    In for +3 shackles.
  29. Mar 3, 2022 at 12:07 PM
    AZTundra
    Paul
    Phoenix, AZ
    In for Steering Kit
    TucsonTundra1794 likes this.
  30. Mar 3, 2022 at 12:51 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    In for OE replacement steering kit.
Thread Status:
