Linex Screwed Up
Discussion in '2.5 Gen Tundras (2014-2021)' started by rrp0968, Sep 20, 2020.
  1. Sep 20, 2020 at 10:23 PM
    rrp0968
    rrp0968 [OP] New Member
    Well.......
    Took my 2 week old Tundra Limited to Linex to have the bed sprayed. I have had a Linex liner in previous trucks and love the product. Does not fade like others including the one from Toyota.
    Well.....this time my experience was not that good. I should have looked the truck over better before I left. When I got home I noticed some overspray between the cab and bed on the passenger side. Called Linex and the person that answered the phone said a little methanol will take it right off. Well....I have a friend that is into racing and being the impatient person that I am.....got a little from him. Well.....it started to remove the overspray, but turned the paint yellow and removed some paint on a ridge between the cab and bed. I was pi$$ed. Truck only has 250 miles on it......I have not even put gas in it yet. I should have left well enough along and let the Linex dealer remove it, but I was a bit too impatient.
    Well.....pretty much accepted the fact that the truck needs to see a body shop to have the paint fixed.
    THEN.....today I decide to go out and give it a wash. Then I find a fine mist of overspray on the passenger rear door just under the previous area mentioned above. I am fairly certain the finer material is the premium UV coating. I am not touching this. Linex will address this.
    Also noticed that at least two bolts for the bed rails are stripped and not fully seated.
    Not sure if I got the new guy or if the person doing my truck was just having a bad day. They were not even busy.....my truck was the only one there when I dropped it and the only one there when I picked it up about 5 hrs later.
    I did not get the quality job I would expect from them. This dealer had been around for years and I have used them on previous trucks.
    There are other things too.....did not cover the latches on the tailgate, centering pin for front header is missing....(this may not be able to go back because of the added thickness of the liner), front header is not completely covered....can still see white paint through the liner. Was definitely a rush job for sure.
    Anyway....I will stop ranting. Looks like my new ride will need to see a body shop for some paint work. I am hoping Linex steps up and covers the cost. I am thinking the bed may have to be pulled to fix the damage done by the methanol.
    Wish me luck.
  2. Sep 20, 2020 at 10:26 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    So sorry to hear your bad experience..got any pics?
    BravoDeltaRomeo likes this.
  3. Sep 20, 2020 at 10:29 PM
    rrp0968
    Not yet.... was so disappointed earlier......just finished washing it and put it back in the garage. I will get pics before I bring it back to Linex.
    saybng likes this.
  4. Sep 20, 2020 at 10:30 PM
    saybng
    Gary
    Ventura CA
    Takes lots of pics of issues and good luck
  5. Sep 21, 2020 at 5:17 AM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    while your at it, get a log from your phone. Cell phone or land line showing you called Line-x, hopefully with a time stamp further proving you called line-x.
  6. Sep 21, 2020 at 5:32 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    What state are you in? Others need to be aware.
  7. Sep 21, 2020 at 6:09 AM
    Rolling Biome
    Rolling Biome New Member
    Denver, CO
    2019 Tundra CM Limited TRD Off Road
    I had a bad experience with Linex on my truck too. There were little lumps in the liner from drips while they sprayed and a couple small spots of over spray. One spot by the tailgate where there was over spray the tech tried to rub off in front of me and took a small chip of paint. I wasn't very happy. Luckily the chip is between the tailgate and bed and you can't see it. They ended up respraying the bed to smooth it all out too. It just amazes me how people don't take any pride in their work.
  8. Sep 21, 2020 at 6:12 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Maybe that is why yours was the only one there?
    Darkness likes this.
  9. Sep 21, 2020 at 6:20 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    It just amazes me how people don't take time to inspect work before leaving the shop.
    The Line-X shop that sprayed the bed on my '07 screwed up, I caught the mistakes before leaving the shop, they corrected what they could and deducted $250.00 from the total.
  10. Sep 21, 2020 at 6:46 AM
    Kung
    KG, VA
    Yeah, I would never have tried to fix it myself; now that you've done as they suggested (and more importantly, since there's no written log of the conversation), they can say you damaged your paint yourself. :/
    I hope you can get them to fix the issues with a minimum of fuss.
  11. Sep 21, 2020 at 6:54 AM
    rrp0968
    Good point, thanks for that heads up, just saved a screenshot of the call on my cell phone.
    Before I start bashing them online, I am going to give them an opportunity to make this right. I will report back with the location and a good or bad outcome.
    Well, this particular Linex Dealer has been around for at least 13-14 years. They sprayed a truck for me in 2008 that was perfect, and another on 2013 that again was fine.
    I did inspect before I left, apparently not good enough. The overspray on the door is a very fine mist, I did not even notice it until I washed the truck. It is not a heavy blotched coating like you would expect. I am thinking it is the UV inhibitor that is part of the premium liner that got out somehow. The bolts on the bed rails that are stripped are also hard to see unless you make it a point to look that close.
    Overall the liner itself looks fine, they just missed the details big time.
  12. Sep 21, 2020 at 6:57 AM
    rrp0968
    Yeah, lesson learned here.....I should have taken it back and let them handle it. I have never been known for my patience.
  13. Sep 21, 2020 at 7:01 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    That sucks. A coworker of mine had his truck sprayed by Line-X and they screwed it up so bad that he had them strip it and spray it again.
  14. Sep 21, 2020 at 7:04 AM
    rrp0968
    How do they even remove this stuff?
    deptrai likes this.
  15. Sep 21, 2020 at 7:29 AM
    Kung
    KG, VA
    Oh hey, me too man; definitely not judging you on this one. I've just learned over time that me being impatient costs me a LOT more than forcing myself to be patient. LOL
    Rex Kramer likes this.
  16. Sep 21, 2020 at 8:00 AM
    CaptainGrumpus
    Maine
    They Sandblasted it and then used an angle grinder with a heavy knot brush for the hard to get spots. The bed was a mess after the removal but they then sprayed it again and all was fine.
  17. Sep 21, 2020 at 8:52 AM
    TTund16
    TTund16 New Member
    Make sure they didn't spray over the drain holes (or access holes?) in the back of the bed.
  18. Sep 21, 2020 at 5:54 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Very sorry to hear that this happened to your new truck. When I bought my 2020, having factory bed spray liner was a big must for me. I do not want to deal with this imperfections from aftermarket spray liner. It would drive me nuts.
  19. Sep 21, 2020 at 6:02 PM
    TTund16
    TTund16 New Member
    Who does the spray for Toyota? Mine came with it when I bought it new. I thought factory did it but someone said the "fleet" people do it. Wonder who they contract with?
  20. Sep 21, 2020 at 6:04 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Mine was outsourced by my dealer to the LineX dealer. I confirmed with my salesman and then contacted the LineX guy to confirm it was Premium, lifetime warranty etc.
    Dropped off at Toyota, picked up at Toyota, work done by LineX dealer.
    TTund16[QUOTED] likes this.
  21. Sep 21, 2020 at 6:17 PM
    rrp0968
    Well....none of the liners are “factory”, they are all applied at the port.
    My brother has a port installed liner in his 2014 Tundra and it has faded to a grey chalky color. The Linex is a superior product by far. I had it in my 2013 F150 that I sold to get this Tundra and it looked like the day it was sprayed. It also spent about 75-80% of the time outside in the sun. Linex was applied in my F150 at this same shop and it was fine.
    Spoke to the owner today, he was very apologetic. I am going by there Friday for him to address these issues. Will report back after that visit.
    It is unfortunate that it happened, but it will be fixed as good as new in the next couple of weeks.
    NewImprovedRon and TTund16 like this.
  22. Sep 21, 2020 at 6:24 PM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
    https://www.tundras.com/threads/bed...dra-sprayed-in-bed-liners.70955/#post-1833675
    This thread gives some insight into the 'factory' bed liner. It is outsourced but I guess it could get screwed up just as easily, except they likely do the Tundra day in day out so their guys know how to like the back of their hands.
    I got Line X and the shop did good. There are a few small spots of overspray but it is so mild I can't find it half the time. They did spray over the drain plugs in the bed. I asked about it and the guy said they have to as once they spray the liner, the plastic plugs rarely fit well, as they are tight to begin with, and if you actually needed them for a drain or hose of some sort, you just drill through it to the size you need. I don't forsee myself doing anything like that, so I would rather them be sprayed over and not pop out and get lost. You can also use a razor knife and score the edges around and push it out from the back, and then replace it if needed. Again, I don't have a need for an extra hole in my bed. Either way, good luck. I like my Line-X. I think they did well with it.
  23. Sep 21, 2020 at 6:25 PM
    Electonicsfanatic
    Electonicsfanatic New Member
    Wesley
    2017 Tundra Crewmax Limited 4x4
    Just for future reference I did Raptor pro and realized I had over spray. I waited until it was overcast, slightly raining, and got out a medium clay bar with plenty of detail spray. It all came off and my paint barely even knew it. I was worried when it first happened and noticed after washing I had fine fibers left on my truck.
  24. Sep 21, 2020 at 6:29 PM
    rrp0968
    This is my 2013 F150 that I just sold to get the Tundra.
    This is my new Tundra.....not much difference in color. Lighting not the greatest in my garage.
  25. Sep 21, 2020 at 6:30 PM
    Electonicsfanatic
    Wesley
  26. Sep 21, 2020 at 6:39 PM
    rrp0968
    Is this a DIY Raptor Liner......looks real nice!!!
  27. Sep 21, 2020 at 6:39 PM
    Saltyhero13 likes this.
  28. Sep 21, 2020 at 6:47 PM
    rrp0968
  29. Sep 21, 2020 at 6:48 PM
    see my link.......
  30. Sep 21, 2020 at 6:48 PM
    Electonicsfanatic
    Wesley
    It is DIY I laid it on pretty thick with a little curing time from start to stop. The key is keeping the Raptor gun at least 24” away, good cleaning ,and sanding. All in $200 we’ll worth it. I had the tape, sandpaper, degreaser, and alcohol.D782EC93-0DDD-4C93-B3FA-60152A15B5F9.jpg
