LineX question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jalzate44, Sep 1, 2020.
  1. Sep 1, 2020 at 1:28 PM
    Jalzate44
    Jalzate44 [OP] New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
    Good afternoon,
    When you got your bed linex, did they also LineX The four tiedowns in each corner?
  2. Sep 1, 2020 at 1:29 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    They did on my truck. You can also have them removed and reinstalled after its coated.
  3. Sep 1, 2020 at 1:30 PM
    Jalzate44
    San Antonio TX
    Mine were linex as well but I’m trying to remove them and I can’t because it’s all filled with LineX.
  4. Sep 1, 2020 at 1:32 PM
    shellshock
    Iowa
    2019 TRD PRO
    Supposedly you can cut it with a utility knife.. thats what they told me anyway when i asked about needing to remove them to put a decked system in.
  5. Sep 1, 2020 at 1:46 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Linex, they removed all tie downs and fasteners and reinstalled for me.
  6. Sep 1, 2020 at 1:51 PM
    Whats sad is most of them charge labor for that.
    Tchase[QUOTED] likes this.
  7. Sep 1, 2020 at 1:53 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Might of been rolled into the cost, but the way he said it, it sounded like standard procedure.
  8. Sep 1, 2020 at 1:55 PM
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    Well I guess I'm not the only one, they line-xed my all the tiedowns without taking them off first. I was planning to buy the AMP bed extender that bolts under the rear tie downs but it looks like I have to cut through the coating to unscrew it.
  9. Sep 1, 2020 at 1:55 PM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    Mine removed them as part of the prepping process.
  10. Sep 1, 2020 at 2:01 PM
    shellshock
    Iowa
    2019 TRD PRO
    They were supposed to remove mine, but decided they were stuck and couldn’t get them out so they just sprayed over top of them..
  11. Sep 1, 2020 at 2:27 PM
    Jalzate44
    San Antonio TX
    I just took my truck to where I got it sprayed and they removed the screws and repainted the tiedowns for me. I was worried about cutting it myself so they did it all. No charge
    cp44[QUOTED] and RobertD like this.
