Line-x undercarriage - to do or not to do
Discussion in 'General Tundra Discussion' started by TundraNC, Aug 13, 2021.
  1. Aug 13, 2021 at 4:03 PM
    TundraNC
    TundraNC [OP] New Member
    Joel
    North Carolina
    18 Tundra Limited 4x4 SW
    Has anyone Line-x’ed their undercarriage and what are your thoughts? Good idea or caused issues for repairs or modifications? I don’t deal with much salt but want to protect it from mud and rust on my 18 limited for hunting
  2. Aug 13, 2021 at 4:06 PM
    I would be afraid it would mask problems the way that zeibart coating crap does. Look up Fluid Film or Wool Wax if you want to protect your undercarriage. Any of the "permanent solutions" run a huge risk of trapping things underneath and hiding the issues until you are totally screwed.
  3. Aug 13, 2021 at 4:14 PM
    TundraNC
    Joel
    North Carolina
    What issues are you referring to? Having to fix something and unable to break loose from the Line-x? Issues the Line-x could cause from protection?
  4. Aug 13, 2021 at 4:14 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    No. Bad idea. I'll go with fluid film.
    GODZILLA likes this.
  5. Aug 13, 2021 at 4:21 PM
    https://youtu.be/H2VD5fM6pto
    Plus, anything you spray it on it is not coming off. All your wires, sensors, connectors, etc are gonna be a bitch to do anything with.
  6. Aug 13, 2021 at 4:37 PM
    TundraNC
    Joel
    North Carolina
    Gotcha! Thanks for the help. Looks like the truck in the video was a person that applied it a little late or at least when it was wet. Trapped the moisture and rust. Was hoping to protect it before that happens. It stays in the garage when not in use. But I agree the rubberized coating would trap wires and gas lines for any future changes. That’s why I’m inquiring. Looking for first hand issues. Had not heard of the fluid film before now. Will research that now as well for the best options to keep it protected for longevity
  7. Aug 13, 2021 at 5:08 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I had fluid film done on my 2020 4runner Pro. I’m having my 21 tundra pro done before winter time with fluid film. Some recommend every year if you are anal. Lol. I’m doing mine every other year.
    mech_engineer09 likes this.
  8. Aug 13, 2021 at 5:16 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    How would you ever repair anything, replace parts etc?
    Sounds like a terrible idea to me. I would hope the Line-X dealer would advise against it and not do it.
  9. Aug 13, 2021 at 5:48 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    I replaced my bed as it had the infamous rust spots through the mounting points. The new bed was shipped to a local line x shop and sprayed the underside, front and the bed of course. I fluid film the truck every year. It’s been three years and looks like new underneath. Depends on how determined you are (or crazy)
    woods likes this.
  10. Aug 13, 2021 at 6:47 PM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    Yuppers. Linex is great as a bedliner, but not something I’d apply to a frame and underbody.
    NewImprovedRon likes this.
  11. Aug 13, 2021 at 7:50 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
  12. Aug 13, 2021 at 8:25 PM
    DoublePro
    DoublePro New Member
    I have 196k on the clock, when purchased new, I crawled under with regular high temp spray paint from Home Depot, sprayed anything I think would be rusted. Control arms, leaf, all the nuts and bolts. Today it still looks the same and virtually no rust and the painted surfaces still in tact.
  13. Aug 13, 2021 at 9:19 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2 ^^, this is what I use its been great for two years. Probably do another spray in 3 months
  14. Aug 16, 2021 at 7:41 AM
    LILFEAR1
    LILFEAR1 New Member
    2015 Black Tundra SR5
    7" BDS lift, 37" tires on 22" rims, S&E Airbox and more
    the problem with bedliner in undercarriage is future repairs of your truck...the mechanic will have to deal with all that bedliner when trying to fix your truck...This will add cost to your repairs, and the thicker liner like LineX would make it nearly impossible and some shops won't touch it.
  15. Aug 16, 2021 at 7:54 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    +1 I've lived in the rust belt for 30 years. The cars that rot out fastest are the ones with rubberized undercoatings. 2nd fastest are untreated. 3rd are fluid filmed.
    My cousin-in-law runs a landscaping business and uses fluid film on his mower decks (in addition to his trucks for the salt). So that's a unique use-case more fitting to the OP's concerns about mud.
    TL;DR Fluid film or bust!
  16. Aug 16, 2021 at 7:54 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Pardon the noob question, but is the fluid film applied at a vendor, or is it something you can do yourself with a rattle can? Is it simply just going to town on anything metal under the truck?
  17. Aug 16, 2021 at 8:01 AM
    You can pick it up on Amazon and in stores. Keep it off stuff that gets hot (exhaust) and away from your brakes. It can cause some rubbers to swell, so avoid bushings and such.
  18. Aug 16, 2021 at 8:06 AM
    MadMaxCanon
    Do you have to clean the metal surfaces before application?
  19. Aug 16, 2021 at 8:10 AM
    You want it clean, yes. That way it adheres to the metal. Still, if you power wash your undercarriage or go through a carwash with an undercarriage spray it will strip off the fluid film.
    If you search "Fluid Film" on the forum you will get tons of results, and I am sure there will be guides or videos in there somewhere.
  20. Aug 16, 2021 at 8:14 AM
    RusPro21
    Don
    Pa.
    Have someone do it. Try to find someone in your area. Does not cost that much and a lot easier for someone else.
  21. Aug 16, 2021 at 8:17 AM
    Only if you trust them to do it right. I'd hate to take it somewhere and have them half ass it, or just spray everything and wind up cooking it on my exhaust or getting my brakes coated in it. Only way to be sure is to do it yourself, and it isn't difficult.
    BravoDeltaRomeo likes this.
  22. Aug 16, 2021 at 8:41 AM
    RusPro21
    Don
    Pa.
    I agree. I found someone that’s does it a lot. He did a great job on my 2020 4Runner Pro.
  23. Aug 16, 2021 at 8:44 AM
    That's a bonus for sure. It's messy and it smells, but if they get the inside of the frame and keep it off stuff it shouldn't be on, I'd probably do the same. I'm just in the middle of nowhere and nobody does it.
  24. Aug 16, 2021 at 8:48 AM
    RusPro21
    Don
    Pa.
    Yeah that’s what usually happens to me when i need something done.
  25. Aug 16, 2021 at 9:10 AM
    MadMaxCanon
    Thanks guys, i will look around to see if anyone does it near me, chances are I will do it myself because i dont trust anyone and i am cheap lol
    BravoDeltaRomeo and GODZILLA like this.
  26. Aug 16, 2021 at 9:47 AM
    TundraNC
    Joel
    North Carolina
    Good information guys. Definitely going to lean more toward fluid film. Now gotta find someone who applies it locally
  27. Aug 17, 2021 at 6:46 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    During the winter, I would hope you spray your undercarriage off every few weeks, especially after a good snow dump with even more salt added to the roads. Which brings me to my point, why use FF if you will have to have it reapplied with your first wash. OP, give this video a look before you decide.
    https://www.youtube.com/watch?v=oXlhmbvdKBo&t=236s
    TundraNC[OP] likes this.
  28. Aug 17, 2021 at 6:53 PM
    I apply it myself. It stays on all winter, and acts as a barrier to the salt and repels water. Go look at the pics of guys that have used it for years. You don't peal off paint protection FIM just because it got stuff on it. Same for fluid film. You only spray it off after it's done its job for the season.
  29. Aug 17, 2021 at 7:07 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Yeah, it's great for home application and seen a lot of success stories with it. I watched a few of these videos and did some surface level (punny) research and concluded with the amsoil product. Easy application (can spray literally everything), doesn't come off when you spray/wash it, can stay on year-round and it doesn't collect road debris and dirt. Only downside is applying the 2nd coat. Takes me usually 3-4 cans, $55 total.
    The thing is, throughout the winter months I wash regularly to get any salt that may be harboring. I don't want to take the risk any of my protection coming off. Just my two cents.
    TILLY likes this.
  30. Aug 19, 2021 at 7:43 AM
    TundraNC
    Joel
    North Carolina
    Thanks for the video research and input. We don’t get much snow or salt in NC in my area. I used/sprayed the rubberized coating on my 98 Tacoma years ago and it held up well over the years, but like the video says you have to protect stuff you want to access laser like connectors. That’s why I was inquiring about Line-x. I figured it was quite a bit more aggressive spray than out of the can and didn’t know if someone had it done and had issues afterwards. The rubberized out the can is probably best for my area and longevity but application is not fun and very tedious.
