Line X the box soon I have few question how to have it done.
Discussion in '2.5 Gen Tundras (2014-2021)' started by CanTundra, Nov 18, 2021.
  1. Nov 18, 2021 at 6:50 PM
    CanTundra
    CanTundra [OP] New Member
    2021 Tundra TRD Off Road
    Hi Guys, My 2021 is going in soon for premium Line-x. Now I noticed our trucks have the rail system. For those of you with oem spray in. Can you share some pictures.
    Is the oem way to tape around the rails? or do they remove them then spray then re install?
    My understanding is the line x is 1/4" thick I don't like the idea of re installing rails onto that thick of rubber.
    Any help would be great so I can advise installer how I want it done.
    I would also like to know how the oem does the tail gate? I think the access panel is done on its own then re installed.
  2. Nov 18, 2021 at 7:01 PM
    Welcome from NY.
    I would remove the rails and get some screws from Home Depot or Lowes and put them in half way in and let them coat the whole bed. Then after it's done remove them and throw them away and reinstall the original hardware.
  3. Nov 18, 2021 at 7:04 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    This is what I did to my dad's truck. Worked just fine.
  4. Nov 18, 2021 at 7:10 PM
    CanTundra
    I thought about something like that or just cap them off but instead of oem hardware would i not need longer ones to compensate for thickness of the line x?
    I think line x removes box bed bolts too
  5. Nov 18, 2021 at 7:18 PM
    Installing the rails over the line-x is not an issue. Remove the rails yourself. They will charge you if they remove them (at least the shops here do). I would remove the tailgate panel and have it sprayed separately so that the screws aren't covered.
    panicman and Ely010606 like this.
  6. Nov 18, 2021 at 7:31 PM
    CanTundra
    ok thank you . Yes I was just watching some videos so I will remove them my self and tell installer to plug holes or I will trying to find some plugs.
  7. Nov 18, 2021 at 7:37 PM
    CanTundra
    I think I will also remove the lower hooks too. I am just not sure about the bed box bolts to frame. I am worried if they remove them and the box get shifted
  8. Nov 18, 2021 at 8:33 PM
    Windsor
    Homeless in Oregon
    Some.
    Do not remove bed bolts before taking it to the shop. I removed rails and tie downs. Put cheap bolts in place of factory bolts. Shop removed bed bolts, sanded and cleaned bed, taped what needed to be taped, sprayed, let it cure for a few hours, put the bed bolts back in place, took the tape off, then took the money and said get out.
    CanTundra[OP] and Ely010606 like this.
  9. Nov 18, 2021 at 9:28 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Definitely a Good advise.
  10. Nov 19, 2021 at 2:31 AM
    Mike59
    Mike59 Kentucky Traveller
    Central Kentucky
    2021 Tundra DC Limited 4x4 SSM
    They didn't remove mine.
  11. Nov 19, 2021 at 4:08 AM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    Or mine. I'd think you'd want to have the bed bolts covered in Line-x, since they're almost never removed and it'll keep them from corroding.
    Actually, I think the only thing they removed on mine was the plastic rail caps. Either that or they just taped them off. It came out great regardless.
    If I ever need to install rails I'll just run a tap into the screw holes before installation.
    Ely010606 and Mike59[QUOTED] like this.
  12. Nov 19, 2021 at 4:56 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I am not sure how they did mine but none of the bolt heads have Linex on them. I assume they removed the smaller ones on the tailgate.
    Mike59[QUOTED] likes this.
  13. Nov 19, 2021 at 5:05 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    I would recommend having them pull the bed bolts, and not covering them with liner. That way if the bed ever has to come off again, it wont need another layer of bedliner to cover the bolt heads. Say like someone rear ends you, and you have to replace the bedside. The only place my bedliner is peeling is on a bolt head, after having something drag across it. Down side is, the bed bolts are one time use, so you'll have to buy 6 new bed bolts.
    Normally they will remove the tailgate to do the liner. They will also remove the insert panel on the tailgate and spray that separately, saving those little bolts from getting filled in with liner.
    My truck didn't come with the rails from the factory, I added some from a member on here. I was able to use the factory bolts with the liner. I just pre screwed a bolt into every hole, before installing the rails.
    And I like the suggestion of removing the bolt in tie down hooks. I would do that if I had a chance. Then install after the liner was installed.
    And that's my .02$.
    Ely010606 likes this.
  14. Nov 19, 2021 at 5:20 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    My bed bolts and tailgate access bolts were removed for Line X.
    Mike59 likes this.
  15. Nov 21, 2021 at 9:13 AM
    CanTundra
    Thanks for all your help guys. I have called the shop and they said they would remove the rails for me . But what I think I will do since I am very OCD.I will remove them all my self and the tie downs used other bolts to cap off the holes like you guys suggested that way I can re install and torque things down to spec instead of them zapping everything thing back together with impact gun.
    I think the plastic top caps I will leave them alone and they can tape up to them.
