Line-X - Rhino Liner- or Toyota bed liner
Discussion in '2.5 Gen Tundras (2014-2021)' started by SuperSilverTundra, Oct 4, 2016.
  1. Oct 4, 2016 at 2:46 PM
    SuperSilverTundra
    SuperSilverTundra [OP] i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    ok so I need some help I want to add spray in bedliner to my tundra
    I am debating between the Line-X or the Toyota liner I like the way they stamp Tundra in the liner but what brand do you think will be the best I feel like Line-X is the way to go but im not sure bedliner.jpg
  2. Oct 4, 2016 at 2:49 PM
    TheBeast The Beach
    I have line x Premium. Love it. I did get it added much later. No tundra stamp though :D
  3. Oct 4, 2016 at 3:04 PM
    SuperSilverTundra
    Nick
    I am leaning towards the Line-X but I just like the way Toyotas says Tundra in the bed Liner
    @TheBeast the toyota dealer is asking $595 Line-X is asking $485
  4. Oct 4, 2016 at 3:08 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Another vote here for line x
    SuperSilverTundra[OP] likes this.
  5. Oct 4, 2016 at 3:16 PM
    TheBeast The Beach
    the funny part is my line-x place does line-x for Toyota dealerships around (brand new trucks at the shop)...so they are probably the same bed liner. Just one has stamp and cost more $$ :)
  6. Oct 4, 2016 at 3:18 PM
    15whtrd
    15whtrd Mr. Blonde
    Line-x premium here. Love it. Who cares about the Toyota stamp, the novelty will wear off. Plus line-x will honor the warranty forever. I read a few stories where Toyota would not honor it because it was done at the port. I think they sub it out anyways. I also added the rubber Toyota bed mat so that it is a little easier on the knees and very grippy. Plus you get the Toyota logo right in the middle. Under 100 bucks.
    BlueFalconActual and TheBeast like this.
  7. Oct 4, 2016 at 3:19 PM
    TheBeast The Beach
    I just did the same. Ordered the bed mat as well.
    15whtrd likes this.
  8. Oct 4, 2016 at 3:20 PM
    15whtrd
    15whtrd Mr. Blonde
    If you really want the Toyota logo ask your line-x ask guy if he could do it.
  9. Oct 4, 2016 at 3:42 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I did Line-X as well.
  10. Oct 4, 2016 at 3:46 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    My truck came with the Toyota liner. I don't know if line-x is the same or not, but I lowered my tie down rails so I could put my tonneau cover on it and they didn't spray the liner all the way up. I'm not sure if they sprayed it with the rails on it and just covered them or if they just didn't spray all the way up the sides of the bed. It won't make a difference, just looks unfinished.
    Tundra_power likes this.
  11. Oct 4, 2016 at 4:18 PM
    TheBeast The Beach
    they usually remove the rails, cover the holes and spray up to the top.
  12. Oct 4, 2016 at 4:34 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    I've had 3 trucks with bedmax & Lin-x and they look great for awile, but after sometime they fade, show scratches easy and if you use the bed like a contractor and drop anything heavy it will dent the bed easily and will show them forever. The bedliner from toyota I belive will protect the bed a bit better, yes will scratch and fade too but I think will protect better in the long run. JMO.
  13. Oct 4, 2016 at 4:44 PM
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Wow no love for the rhino :( I like mine :)
    k0diak8o8 and TheBeast like this.
  14. Oct 4, 2016 at 4:48 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    If you're referring to the plastic drop in liner, I'd for sure go with Line-X which I did in my own truck. The stamping Toyota spray in, I've only seen done from factory on the Platinum, but I'm also up here in Canada so it could be very different down past the border.
    15whtrd likes this.
  15. Oct 4, 2016 at 4:52 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Line-X for sure. The Tundra thing is cool, but never having to worry about your bed because of the warranty is cooler IMO
  16. Oct 4, 2016 at 4:52 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I've seen a few factory spray ons and they're usually a lot thinner. Line-x is bulletproof. Line-x all the way.
  17. Oct 4, 2016 at 4:54 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Earlier in the episode, it showed that the brand that they were using was Line-X.
  18. Oct 4, 2016 at 4:57 PM
    15whtrd
    15whtrd Mr. Blonde
    Until rust starts to form between the bed and plastic drop in. Then you're bed is still effed. Full protection would be line-x with a drop in. Lol the Line-x guy offered me a free drop in that the last guy ditched when he got the spray in.
  19. Oct 4, 2016 at 5:00 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Krezz, google Bullet Liner. Supposedly one of the guy's from line-x split off and came up with a better product, or I should say fixed the flaws that line-x had. This is what I read, so I'm not saying that line-x isn't a good product. There's a guy here local that sprays the bullet liner and i've see it applied and it looks great. I'm definitely going this route, especially when the price for bed is $450 out the door. Standard bed on a dc. Hope this helps
  20. Oct 4, 2016 at 5:25 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    Line X Premium is what I recommend. I got a package deal that I could not walk away from; Line X , Undercarriage protection and UnderCover Flex Tonneau Cover.
    woodcan and NewImprovedRon like this.
  21. Oct 4, 2016 at 5:52 PM
    Krezz
    Kevin
    I think my name stuck out to you, but I'm not the OP of the forum regarding bed options. LoL - thank you though, I will also be googling this anyway as learning new things is always interesting.
    @SuperSilverTundra
  22. Oct 4, 2016 at 5:56 PM
    rons23
    Ron
    Kill Devil Hills
    Haha don't ask me how, hopefully Supersilver Tundra will see it. Thanks for getting me straight.
    Krezz[QUOTED] likes this.
  23. Oct 4, 2016 at 5:57 PM
    Krezz
    Kevin
    LMAO - no worries whatsoever!!
  24. Oct 4, 2016 at 8:40 PM
    Mannishboy
    Mannishboy New Member
    Indianapolis, IN
    2015 DC 4x4 Limited, Blue Ribbon Metallic.
    TRD exhaust, TRD cai, TRD rear sway bar, TRD shift knob, Sequoia front sway bar, bed extender, bed step, Weathertech floor mats and window vents, spray in bed liner, Morimoto fogs, Access tonneau bed cover.
    One thing I noticed that was different between Line X and factory spray on, is that the factory spray on covers the bolts in the bed. Don't know whether that's a good or bad thing.
  25. Oct 4, 2016 at 8:46 PM
    TheBeast The Beach
    you can always ask the line-x guys to spray everything. By default they remove the bolts
    15whtrd likes this.
  26. Oct 4, 2016 at 9:48 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    ? Who told you that, lol
    rons23 likes this.
  27. Oct 5, 2016 at 4:09 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    After I got mine LineXd I tried selling and then giving the OEM drop in liner without luck, I finally took the sawsall to it and dumpstered it.
    TheBeast likes this.
  28. Oct 5, 2016 at 7:51 AM
    SuperSilverTundra
    Nick
    thanks @rons23 I will check out bullet liner my first time hearing about them
  29. Oct 5, 2016 at 10:09 AM
    SuperSilverTundra
    Nick
    I just checked out the bullet liner its pretty cool they can actually match your color of the truck the only thing is the only shop is like over an hour away and it takes most the day to have done so its looking like I might go with the line-x the shop is only 10 minutes away
    rons23, NewImprovedRon and TheBeast like this.
  30. Oct 5, 2016 at 10:30 AM
    TheBeast The Beach
    yep line-x been in the business for a long time and they have good warranty plus big network..Bullet sounds good but I never trust disgruntled old partners..
    Disclaimer: I don't own any Line-X stocks...LOL...
    btw getting front bumper done today..:dancingbacon:
