Line Level Adapter Making Radio Stay On
Discussion in 'Audio & Video' started by oldschoolcat, Jul 22, 2022.
  1. Jul 22, 2022 at 1:36 PM
    oldschoolcat
    oldschoolcat [OP] New Member
    Howdy All. I have been following the audio forum and have finally decided to upgrade the speakers and install an amp that I've had for a while. 2018 Tundra Crew Max non JBL.
    I bought a DS18 line level converter and installed at the vehicle amp connecting to the power, accessory, and ground. When I turn on the vehicle all powers up as it is supposed to. I even tested with a subwoofer and the speaker connections seem to be correct.
    However when I turn the key off, the adapter AND the radio stay on. I can turn the key back on and off and nothing changes. The radio doesn't turn off until I disconnect the ground wire on the line level adapter. My amp and the radio turn off and on if the adapter is not connected.
    I seem to recall reading this being an issue with another install, so I thought I'd check here first. Does this sound like an adapter issue? Or am I wiring incorrectly?
    Thanks to all in advance.
  2. Jul 22, 2022 at 2:27 PM
    oldschoolcat
    A little more info. I disconnected the speaker leads and the power turns off and on correctly. So there is apparently an issue connecting into the speaker lines coming from the head unit.
  3. Jul 29, 2022 at 11:36 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I dont have an answer for you, but maybe post a pic of the actual install so folks can see what they are commenting on.
  4. Aug 6, 2022 at 4:35 PM
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    Where are you tapping into to get the remote signal for the line out convertor
  5. Aug 6, 2022 at 4:40 PM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    You need to get your remote signal from the front door speakers. Only the front door speakers will work properly; why? I don’t know but that’s how it likes it cause I connected to the rear door speakers and it sounded like crap. Also once you’re connected the amp won’t turn off instantly. You have to wait a few minutes for the door speakers to lose their power before the LOC will power off.
