Limited vs Pro vs Platinum headlights
Discussion in 'Lighting' started by AMRE2ME2, Dec 10, 2015.
  1. Dec 10, 2015 at 7:56 PM
    AMRE2ME2
    AMRE2ME2 [OP] New Member
    2016 DC 4x4 Limited TRD
    What is the difference between the Limited, Pro and Platinum stock headlights?
    Blacked out housings? Bulbs?
  2. Dec 10, 2015 at 8:11 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Pro has black bezel like in my sig, limited all chrome, Platinum all chrome.
    Pro does not have LED DRL.
  3. Dec 10, 2015 at 8:19 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    if i'm not mistaken only the platinum and 1794 have the functional led strip.
  4. Dec 10, 2015 at 8:19 PM
    Correct
  5. Jan 24, 2016 at 6:01 PM
    92lt
    92lt New Member
    Western NY
    2016 Tundra Black LTD
    Can anyone confirm that the 2016 limited has the led daytime running lights? That's what the brochure says.
  6. Jan 24, 2016 at 7:21 PM
    N8Dizzle
    N8Dizzle New Member
    Nate
    Seattle
    2016 Magnetic Gray Tundra Platinum
    Toytec Boss Lift w/AAL, TC UCA's, Fuel Trophy D552, 305/70R18,Cooper STT Pro Tires,Interior/Cargo LED's, 10% Window Tint, Hypertech Speedo Calibrator, anytime fogs, WeatherTech Digital Fit Mats
    Sean266 has confirmed above your post. He has a limited.
  7. Feb 22, 2016 at 6:23 AM
    Texastrav
    Texastrav New Member
    2015 Tundra limited CM 4x4
    Brand spanking new, need mod ideas!
    So how can I get the DTL on my 2015 limited? What are my options?
  8. Feb 22, 2016 at 6:44 AM
    Texastrav
    Do they make a harness? I heard you can't just plug and play.. What are my options? I don't want a total aftermarket headlight. I like the OEM and OEM DTL. I'd use an aftermarket harness if I could go that way. Anyone have any ideas?? Helllp
    FirstGenTundra likes this.
  9. Feb 22, 2016 at 7:42 AM
    Whole new wire setup from what I remember reading.
  10. Feb 22, 2016 at 10:36 AM
    Texastrav
    Surely someone has a set up that's plug and play, right? Why did they make this so difficult ? Pisses me off
  11. Feb 22, 2016 at 1:52 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    If I'm reading this right, you don't have drls and want them without touching your factory headlights, if so here's a couple options. I am doing this on my 08. Didn't get a price on the first one's, but I believe that you can get them already color matched. The second option is get them from eBay or Amazon. $184 on eBay. I got mine from eBay and they are well made, probably more so than the factory panels. So you will have 2 sets of panels, but if you ever want to do a retrofit or aftermarket headlights you can always go back to your factory and sell the other to recoup your money. These lights are plug n play to a extent. You will have to wire them to a source. I am running mine to my ignition fuse via fuse tap, that way they come on when I start my truck. This alleviates splicing into your factory wiring. It also comes with a control box if you want to get creative with installing a toggle switch inside for anytime operation. Note the one's from eBay or Amazon are color specific, so more than likely you will have to get them painted. $60-100 I would say is a good estimate. Hope this helpsuploadfromtaptalk1456177617285.jpguploadfromtaptalk1456177626271.jpguploadfromtaptalk1456177918133.jpg
    040Tundra, Wvmoonshiner and Cubanchem like this.
  12. Feb 22, 2016 at 2:41 PM
    Texastrav
    Thank you so much for the reply. If that's my only option then I'll go that route but essentially I want the exact same headlights that come on the platinum and 1794's with the DTL. I have the limited. I thought about buying the factory platinum factory OEM headlights but I heard you can't just swap them bc of the plugs or extra wires.. Wondering if there is an aftermarket converter so I can just buy the platinum or 1794 headlights.
  13. Feb 22, 2016 at 2:45 PM
    rons23
    Ron
    Kill Devil Hills
    No worries, good luck with your search
  14. Feb 22, 2016 at 2:49 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    There was a member who was making harnesses for adding the Platinum headlights not too long ago. He was doing retrofits for a lot of people, and they wanted to add the LED DRLs from the factory headlamps. I believe his username is AV1597, but don't quote me on that.
  15. Feb 22, 2016 at 3:44 PM
    Texastrav
    Man that would be awesome.. I'll see if I can find him..thanks!
  16. Apr 6, 2016 at 5:23 AM
    BigBlue15
    BigBlue15 New Member
    any luck with this? would be interested also.
  17. Apr 6, 2016 at 5:36 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I wanted to do this to my 14 but it's way to complicated for my taste so I gave up on it. I also really liked the DRL led too. It requires a whole lot of wiring and fabrication. I haven't met anyone on here yet who's done it successfully. :(
  18. Apr 6, 2016 at 10:10 AM
    Texastrav
    Funny you asked.. I just pulled the trigger on some yesterday. I got ahold of AV1597 and he is making mine as we speak. He orders aftermarket replica platinum/1794 headlights, takes them apart, wires them so they fit a limited or an sr5, then reseals them. From what I understand you just have to run the power and ground for the LED strip and that's it. It'll come with everything you need. Oh and you'll cut one wire so that your amber DTL won't stay on, they will just be used as your blinker. I'll post pics when I get mine installed. I probably won't get them for two weeks but I'll post about it when I'm done.
  19. Apr 6, 2016 at 11:16 AM
    BigBlue15
    Nice timing! Cant wait to hear about them.
  20. Apr 12, 2016 at 9:59 PM
    Masterchief
    Masterchief New Member
    Andy
    2016 Tundra DblCab Limited
    Nerfs Bars, lineX, rear sway, tint, window wind visors, 3m vinyl, LED lights.
    Can we get a approx $$$ ?
  21. May 6, 2016 at 11:32 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    any updates on your status? Pics??
  22. Jun 9, 2016 at 6:03 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    Any updates?
  23. Jun 20, 2016 at 8:59 PM
    JKlimek283
    JKlimek283 New Member
    Jake
    2016 tundra limited
    Interested in doing this also, how do I get a hold of av1597 ? Doesn't come up when I search
  24. Jul 16, 2016 at 11:15 AM
    rexxwood
    rexxwood New Member
    REXX
    The Couve Vancouver Wa
    2018 Tundra 4x4 5.7 limited CrewMax with Premium package in Cement
    From the dealer: 305/65/R18 around Black Rhino Armory 18x9.5 Gunmetal 3" lift Linex amp research power steps My pocket: Thinkware F800 PRO front and rear dash cams with Cellink battery matched rear front window tint with visor
    are either one of those blacked out?
  25. Jul 16, 2016 at 12:10 PM
    Roman
    Roman
    Franklin, TN
    No sir. The only blacked out lights are the TRD Pro headlights, which do not come with the LEDs.
  26. Apr 6, 2017 at 10:02 AM
    oleg8888
    oleg8888 New Member
    Oleg
    Tundra LTD 2016
    What I love about forums is that someone already asked that question you are searching to be answered.
    Texastrav, any update in this?
  27. Apr 6, 2017 at 11:00 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    AV1597 isn't a member of this forum; he is on TT. And looking at @Texastrav profile, he hasn't been active here since July 2016
  28. Apr 6, 2017 at 11:40 AM
    Crewmax Chris
    Crewmax Chris Paper Airplane Enthusiast
    Lewiston, ME
    2013 Tundra SR5 DoubleCab
    The 2017 has DRLs. They are the amber front lights. There is no LED or full length of headlight DRL like the Platinum or 1794.
    joonbug likes this.
  29. Apr 6, 2017 at 11:52 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, Toyota's sneaky like that... When you hear DRL, you think LED strips... not amber bulbs. When you hear Keyless entry, you think doors unlock automatically when you get near... not a 90's style remote fob.
    Cat3ILS, Patriot, iHacker and 2 others like this.
