Limited slip rear differential for 2005 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by frank2005sr5, Jan 5, 2022.
  1. Jan 5, 2022 at 9:32 PM
    frank2005sr5
    frank2005sr5 [OP] New Member
    2005 Tundra sr5 4x4 4.7L AT
    I'm panning to get a new limited slip rear differential carrier assembly for my 2005 Tundra. I have located a new OEM unit at a Toyota parts reseller. The part number is 41110-34420. What I need to know is if it will need adjustment or if it is ready to install and use. The reseller so far has not provided any data. All replies appreciated. Thanks
  2. Jan 6, 2022 at 2:26 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Don't forget the gasket 42181-34011
  3. Jan 6, 2022 at 7:02 AM
    frank2005sr5
    Thanks for the note about the gasket. I have assumed that there is one supplied with the unit. I'll play safe and get one just in case. I'm hoping someone will advise me whether or not I will have rto shim the assembly.
  4. Jan 6, 2022 at 12:52 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Yes, it will need to be shimmed to set backlash.
    You'll also need new carrier bearings.
  5. Jan 7, 2022 at 3:03 AM
    bmwahba
    bmwahba New Member
    Are you sure? I am pretty sure a new diff pumpkin can be bolted right up without messing with backlash but I could be wrong?
  6. Jan 7, 2022 at 4:13 AM
    frank2005sr5
    The circumstantial eveidence is building that it is shimmed. I saw a quote from a dealer to replace a pumpkin for a 2005 Tundra and it had 3 hours in the budget for everything and the only way that could work is no shimming. Also what good is a new pumpkin if you have to take it apart and put it back together again? May as well send a set of parts in a box. It would be good to find someone who has done this before. Good discussion. Anyone else have any input here?
  7. Jan 7, 2022 at 5:33 AM
    bmwahba
    bmwahba New Member
    Yeah I mean that makes no sense. The diff should be plug and play im 99% sure.
  8. Jan 7, 2022 at 6:52 AM
    w666
    Maryland
  9. Jan 7, 2022 at 6:57 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Just a drop in and go with a whole assembly
    w666 likes this.
  10. Jan 7, 2022 at 7:48 AM
    frank2005sr5
    I'll have more info next week. The plan is to start the plug and play swap on Monday. Hope the axels are good. Have a great weekend.
    dbittle likes this.
  11. Jan 7, 2022 at 8:29 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Have a read
    http://gearinstalls.com/Kazumatyson.htm
    Or this
    http://gearinstalls.com/kazumaeric.htm
    Your results may not change as much as these since you are keeping the same ring and pinion, but there will very likely be a need to adjust the shims. You can buy a shim kit from JustDifferentials.com as well as quality bearing kits.
    Check through Zuk's site, maybe he installed an LSD for somebody who kept stock gears. That will be the real answer. @assassin10000 has swapped his diff recently and he said use shims.
    bmf4069 likes this.
  12. Jan 7, 2022 at 9:17 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Ohhh. If its a whole 3rd member assembly, then it should be completed. Just need a diff gasket.
    If it's the LSD carrier (center section that goes into the 3rd) then it needs bearings and possibly shims.
  13. Jan 7, 2022 at 9:19 AM
    As expensive as this part is, as much stress as this part handles, as catastrophic to usability as a failure of this part is, I would have this installed and setup by someone knowledgeable in the procedure. I myself am not, I would have a gear shop do the install to make sure it was done properly. I know it’s not rocket science, but I don’t have the tools or the time to invest in making sure I do it right myself. I would not be afraid to research the process and tackle it myself, but I would not just drop and go.
    Tundra2 and Darkness like this.
  14. Jan 7, 2022 at 9:21 AM
    w666
    Maryland
  15. Jan 7, 2022 at 9:23 AM
    If a gear shop does this install, do they trust it out of the box? Or do they always check for mesh and backlash?
  16. Jan 7, 2022 at 9:31 AM
    frank2005sr5
    It is a new whole third member assembly.
  17. Jan 7, 2022 at 10:38 AM
    gascap
    gascap New Member
    2002 Tundra
    When you buy a completed build of a new or rebuilt engine or transmission from Toyota do do they require you to take it apart and put it back together again, not! The area in the box #7 is what your buying. It's assembled and ready to be bolted in with a guarantee to work properly for a year if they haven't changed the warranty. It's an uncomplicated easy job, but your question suggest you might need help from a mechanically inclined friend while installing this. Have the few tools and torque requirements ready before starting. Ask the parts department or the service dept your question here, and the cost to do the replacement. If anyone says it's not plug and play, then stop talking and leave.
  18. Jan 7, 2022 at 10:40 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Damn. That's quite a bit of precision work. I'd fubar that in a heartbeat.
    shifty` likes this.
  19. Jan 7, 2022 at 11:24 AM
    Sounds like the answer is it will be plug and play. Good luck with the install.
  20. Jan 7, 2022 at 11:41 AM
    frank2005sr5
    Thanks to all for your contributions
  21. Jan 7, 2022 at 11:42 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @frank2005sr5 I think the confusion here is from the terms used. "Carrier" is just the part the ring bolts to, the open diff or LSD variety. That complete assembly which seems to be what you're getting is commonly called a 3rd member. That is a drop in, you should be good to go.
    Pretty cool to see that the full assembly is available that way. That's not priced badly either.
  22. Jan 7, 2022 at 12:52 PM
    frank2005sr5
    I'm learning the vocabulary, 3rd member it is. Thanks.
  23. Jan 8, 2022 at 2:25 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Zuk is on Hiatus by the way. I've been researching lockers today. I did not realize you can order a complete built 3rd member with pretty much whatever you want in there. Hmmm
  24. Jan 9, 2022 at 7:30 AM
    frank2005sr5
    Yes you can and I have new one still in the box and ready to install starting tomorrow. With limited slip for 00-06 the Toyota P/N is 41110-34420. I got it thru a Toyota parts reseller in Canada who brought it in from USA and shipped it to my shop. Good talking with you.
    Darkness likes this.
  25. Jan 9, 2022 at 4:05 PM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    I just googled that up. Whew! $2100 at McGeorge. It would be a highly cool upgrade, but I think I'll be soldiering on with the tire chains for a while longer.
