Liking these K03's on my 2024 Limited I-Force Max
Discussion in 'Wheels & Tires' started by jeff614, Jun 6, 2024.
  1. Jun 6, 2024 at 3:05 PM
    jeff614
    jeff614 [OP] New Member
    Jeff blosser
    2024 Tundra i-force MAX
    Having gone with 35's on my 4 Runners I was really not wanting to lose the gas milage and decided to go with the new K03's 305/55R20's. I really like the way it sits with the Westcott leveling kit and 1 inch Spydertrax spacers, just a tiny bit of poke, less than 1 inch. I like the stock wheels and I didn't want to pay $40.00 a piece for center caps, so I painted the stock center caps grey and bought some TRD badges on Etsy, it will work for now.
    I have always had Grapplers, Trail, Mud, and Ridge in the past and I think I am really going to like these K03's, they don't ride like street tires, but the ride is better than the Nitto's so far.
  2. Jun 6, 2024 at 3:07 PM
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    Nice looking rig!
    jeff614[OP] likes this.
  3. Jun 6, 2024 at 3:12 PM
    RobertD
    Robert
    DFW, Texas
    Have you driven in damp or wet conditions yet?
    I loved the look of my K02's but they were dangerous once there was some moisture on the road. Gave them up a year ago and thought I miss the more aggressive look they had over my current tires, I have not missed them when behind the wheel.
    Just hoping the K03's do better since they do look good.
  4. Jun 6, 2024 at 3:16 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    KO3’s addressed poor traction in wet conditions. it has been said all around.
  5. Jun 6, 2024 at 3:33 PM
    RobertD
    Robert
    DFW, Texas
    Awesome, I hadn't seen much about them. Guess I need to read up some.
  6. Jun 6, 2024 at 4:07 PM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Curious if you've noticed a mpg drop with the bigger heavier tires? My '17 Taco took a huge hit when I put Cooper Discoverers' on. It never bothered me too much because the Taco wasn't my daily, the Tundra is.
  7. Jun 6, 2024 at 4:22 PM
    Bnewman077
    Bnewman077 Happy 2023 Owner
    2023 Tundra TRD OR Lunar Rock
    18” Method Wheels, 35x12.5 Toyo AT3, TRD Pro suspension with Westcott preload lift and Icon rear springs
    They look good. I’ve always been a fan of BFG but the KO2s weren’t keeping up and ended up going with Toyos. Will definitely be checking these out when it’s time for new tires
  8. Jun 6, 2024 at 4:23 PM
    jeff614
    Jeff blosser
    Yes, actually I had them in some very heavy rain within a couple days of having them and they did really good, felt planted the entire time. From when I looked into them they widened the channels that divert the water and they now cut across the entire width of the tire.
  9. Jun 6, 2024 at 4:27 PM
    jeff614
    Jeff blosser
    After a couple tanks it looks like I have lost about 1mpg, I am OK with that having 12 inch wide tires planted on the ground, spedo does not have to be adjusted, it's right on for some reason. I know what you mean, 35 killed my mpg, but I had a 392 wrangler I put 37 Mud grapplers on and I was getting 7 city and literally 9mpg on the freeway, granted stock they are 16, but that's too much
    brhodea[QUOTED] likes this.
  10. Jun 6, 2024 at 8:33 PM
    mass-hole
    mass-hole New Member
    Just don’t buy obnoxiously heavy and wide e range tires and you won’t lose mpg.
  11. Jun 7, 2024 at 3:41 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    I’m still skeptical they fixed the wet traction issue, We shall see once 40-60k reports start coming in. I had 2 sets of ko2s on 2 different trucks at the same time and swore I’d never buy them again.
    tundznoff and ZappBrannigan like this.
  12. Jun 7, 2024 at 5:20 AM
    funtruck92
    funtruck92 New Member
    2024 Tundra Platinum TRD Off Road
    TRD 3” Lift, 35” Falken Wildpeak AT4, Method 316
  13. Jun 7, 2024 at 7:09 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    At 40k miles with only a 50k mile warranty, I'd assume they'd be reaching end of life and not perform as well. Am I missing something??Screenshot_20240607-100559.png
    whodatschrome likes this.
  14. Jun 7, 2024 at 9:05 AM
    Elevatorguy
    James
    Warranty doesn’t mean that’s the end of life mileage. Way too many other factors involved. Regardless mine had 32k on them on my 4Runner and they were terrible in the rain.
    Tundrastruck91 likes this.
  15. Jun 7, 2024 at 10:26 AM
    Hella Krusty
    Hella Krusty New Member
    I had 305/55/20 Ko2 on my 2nd gen and had none of these wet traction problems you go on about. I live in Canada and it's wet way more than its dry. Only thing I found isas the KO2 wore down, the road hum went up. You get that with AT tire but this was a little over the top
  16. Jun 7, 2024 at 5:43 PM
    Elevatorguy
    James
    Go on about? Lmao, it’s a well documented issue. Glad you haven’t had it, sorry you live in Canada.
  17. Jun 7, 2024 at 8:54 PM
    j-dubb
    j-dubb New Member
    2024 Supersonic Red Platinum
    Did you happen to mount them before the spacers and see how far they sit outside of the fenders? I know without them is one inch less, but didn't know if you had any pictures of them before the spacers? I'm looking to go with the exact same setup and trying to figure out if I want to run spacers or not? Really just looking for the tires to set just outside of the fenders. Anything more and it throws mud and gravel down the side too much and for what I drive on daily it is a pain. Thanks.
    jeff614[QUOTED][OP] likes this.
  18. Jun 8, 2024 at 8:31 PM
    619mattr
    619mattr New Member
    2024 Tundra HV Limited CrewMax TRD OR
    Fox 2.5 PES LT275/65R20 BFG KO3
    Haven’t have any issues with my KO3’s, I got my set in 275/65/20.
  19. Jun 9, 2024 at 9:01 PM
    Hella Krusty
    Dont worry about us in Canada......life is good.
  20. Jun 9, 2024 at 9:11 PM
    NWPirate
    Zach
    WA
    Banff.. Revy?? Also, elk are required on the golf course up there :D
    OldGuy03 likes this.
  21. Jun 9, 2024 at 9:25 PM
    Hella Krusty
    Banff....pffftttt. Shot that Pic Friday .....
    OldGuy03 and NWPirate like this.
  22. Jun 10, 2024 at 6:35 AM
    wolffresh
    wolffresh New Member
    2024 MG Limited iForceMAX Crewmax
    What were your MPG drop going to these from stock?
  23. Jun 10, 2024 at 6:48 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I haven't experienced the wet traction issues a lot of people like to complain about either. I'm on my 3rd set of bfgs.
    Hella Krusty likes this.
  24. Jun 10, 2024 at 8:20 PM
    tundznoff
    tundznoff New Member
    blk limited tundra
    TRD red axel swap Satin black wrapped fender flares Satin black wrapped bumper insert Icon stage 5 Icon 1.25 rear spring Drkdss panhard bracket Rave trd pro grill & lights 37” K02 17” 0 offset Nomad Sahara
    When dirty seven with white letters ?
  25. Jun 12, 2024 at 3:36 PM
    Two Tall
    Two Tall New Member
    This is EXACTLY the set I’m looking to get, thanks for sharing this pic. @619mattr How does it drive compared to the crappy stock tires?
    619mattr[QUOTED] likes this.
  26. Jun 12, 2024 at 6:50 PM
    jeff614
    Jeff blosser
    This is before
    RealTruck likes this.
  27. Jun 25, 2024 at 2:49 PM
    BigAlMerrill
    BigAlMerrill New Member
    How old were your tires when they started to get louder? I have 305/65r18 on my 2nd gen Tundra and they got loud also. Apparently, the rubber hardens after 2 or 3 years. The new KO3s are supposed to have a new/softer rubber compound to correct this.
    I am looking to replace my KO2s with KO3s and was wondering if others personally saw improvement with the KO3s. I'm also contemplating dropping down to a 285/65r18...will I really notice a difference? The KO3 305s are an F where the the KO2s were an E so concerned the tire will ultimately be too stiff. The KO3 285 are also rated an E. Appreciate any thoughts. Thanks!
  28. Jun 25, 2024 at 4:49 PM
    Hella Krusty
    Probably 3 years but I only ran them April to November ( Canadian winters and they suck in the snow ) I would never buy them again. Look at Nokian Outpost NaT. 85mph and dead silent
    blenton likes this.
  29. Jul 20, 2024 at 12:12 PM
    619mattr
    619mattr New Member
    I'm at about 15.5 -16.5 mpg, mostly to and from work lots of city driving. 15’s when I need to get somewhere fast haha. On longer freeway drives I can get above 18’s.
  30. Jul 20, 2024 at 12:19 PM
    619mattr
    619mattr New Member
    I think they drive great, its getting a bit warmer in the PNW so you can feel the tires gripping the streets. I personally like the drive. They are E rated so a bit heavier, but the car feels more stable. I feel like they should have come stock with 275’s or 285’s from factory. I should probably note I'm also running Fox 2.5 PES Shocks with OEM TRD UCA’s. 2 1/4” lift in the front and stock rear coils for a nice level.
