Lights Wiring Question
Discussion in '1st Gen Tundras (2000-2006)' started by itsWarrior, Nov 3, 2023.
  1. Nov 3, 2023 at 9:08 AM
    itsWarrior
    itsWarrior [OP] TEQ_Toothless
    Luke
    North Georgia
    Toothless the 06 Tundra SR5 DC RWD
    Bilstein 4600s, Leveled, LT265/70R17 A/T Tires, Lighting, Cosmetic stuff, Stickers and Morale Patches, Recovery Gear
    Hey everyone,
    I'm going to be replacing my OEM fog lights with LED light pods on my 2006 Tundra DC and I just need some help on wiring these safely. The light pods draw 0.6a each and I'll be powering 2. Would I be able to wire the light pods to the factory fog lights harness or will that be too much for the factory wiring? I have a LED headlight resistor on one side since I already have LED bulbs. Should I add a resistor to the other side if the pods wont draw enough power? Am I on the right track or should I take a completely different route?
    I'm not the greatest at explaining things at first so please ask questions if you have any. I'm completely open to any suggestions and feedback.
    Thanks!
    -Luke
  2. Nov 3, 2023 at 1:07 PM
    OverSquareEng
    OverSquareEng New Member
    2006 Sequoia Limited 4WD
    The stock halogen bulbs draw WAY more power than the LED lights you are putting in. The stock bulbs draw 55W or ~4.6 amps. You are safe using the factory wiring for the LEDs.
