lights out again
Discussion in '1st Gen Tundras (2000-2006)' started by 3bears, Oct 5, 2024.
  1. Oct 5, 2024 at 1:17 PM
    3bears
    3bears [OP] New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    so when i bought this rig...no brake lights...replaced bulbs...then no brake light on driver side...thought I fixed that. now no tail lights and license plate lights. it all worked weeks ago..thanks to cop giving me a warning...can it be the box behind driver tail light.. is this what i need Amazon.com: Draw-Tite Tekonsha 118378 T-One® T-Connector Harness, 4-Way Flat, w/Circuit Protected ModuLite® Module, Compatable with 2001-2002 Toyota Tundra : Automotive
    but I have the round 7? plug in
    fuse ok and replaced anyway for one listed tail light at inside fuse box by knee
  2. Oct 5, 2024 at 6:55 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Give us some more information. Are they stock light assemblies and stock bulbs? Or aftermarket, upgraded, etc…? Are there any added connections (for a topper, backup camera, auxiliary lights) that either you or the previous owner did? Has there been any accessories that might have been added to the wiring harness for taillights or tow hitch? Was the 7-pin hitch from the factory or from previous owner?
    There are plenty of instances where someone did shoddy wiring or connections, or even removed connections and screwed something up.
    If you replaced bulbs with LED bulbs, sometimes the aftermarket ones bounce loose or are not sitting the right way and either don’t work or wiggle loose. Let us know.
    ATBAV8 likes this.
  3. Oct 5, 2024 at 7:55 PM
    3bears
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    to be honest...wish i had not bought this rig...bought from a friend who i thought was an honest guy...its been a money pit since and things he said were done are a fantasy.
    but to try to answer your above questions. yes stock tail light housings and new bulbs about 2 months ago as brake lights did not work...standard bulbs not led....trailer light socket does not work...when i replaced brake bulbs i also did one license plate light. thought all was good until a state trooper pulled me over the other night at 11pm ish to tell me no tail lights...talk about oh sheep and butt tucker
  4. Oct 5, 2024 at 7:55 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Yeah, you definitely don't need to be adding any more shit to it at this point. I'm suspicious of whatever the box is behind the driver tail light. You might need to rip out any add-ons and start from scratch. I 100% agree with @Kimosabe that we need more information.
    JakeJake likes this.
  5. Oct 5, 2024 at 8:13 PM
    ATBAV8
    Tempe, AZ
    Do you feel you have the skills to do any electrical work other than changing out bulbs?
  6. Oct 6, 2024 at 5:21 AM
    That box is part of tow package, IIRC, but only on the earlier models. It's what feeds lights, maybe trailer brakes etc?
    Once simple way to diagnose would be to look at EWD and bypass the box, feed the lights directly.
  7. Oct 6, 2024 at 6:32 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    My 2000 AC has a box like that under the left taillight housing. It also has a trans cooler and a 4 wire trailer plug next to the hitch all factory
  8. Oct 6, 2024 at 9:39 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Pretty sure the box is a tail light/stop light converter. Had one on an older truck. Mine shorted out internally and I replaced it. After I got it out, it even smelled fried.
  9. Oct 6, 2024 at 9:48 AM
    3bears
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    so yes mine has the box behind drivers tail light. months ago when I bought it had no brake lights, replaced bulbs and still none, someone suggested that the box was bad and goes bad age. that they replaced theirs to fix their problem. I did find out also...at that time that the box was not even wired to battery, so wired it , then all seemed good till a few days ago.
    many years ago on one of my 4 runners I had a Kurt brand converter go bad and had no lights
    2002 ac 4x4 factory/dealer tow package
  10. Oct 6, 2024 at 11:50 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I’d start with looking at the taillight harness and looking for any wire taps and see what the condition of the wires are around the box that’s in there and the taillights. There’s power being directed (since you had lights at one point) but it’s making it to where it should be. Leads me to think a wire is cut, tapped wrong, or something.
  11. Oct 6, 2024 at 11:51 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    And by the way, might need to downgrade that friend
