Lights On
Discussion in 'General Tundra Discussion' started by ash1055, Dec 8, 2019.
  1. Dec 8, 2019 at 12:25 PM
    ash1055
    ash1055 [OP] New Member
    Robert
    2010 Toyota Tundra Crewmax
    Fuel Tires and Wheels, Lifted leveled
    Good Day Everyone,
    I am a Newb here. purchased a 2010 Tundra Crewmax 25 days ago. (Graduated from a Tacoma)
    I was backing up, forgot to take off the emergency brake. backed up about 5 feet. now my ABS, traction control light are on along with the 4 Hi and 4Lo lights blinking. Any ideas on what might be going on with the truck? Thanks
    Rob
  2. Dec 8, 2019 at 12:28 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Trucks probably just confused.
    Have you cycled the Ignition already?
    Are the lights still on?
    If they're still on I'd try a battery disconnect and go from there.
  3. Dec 8, 2019 at 8:37 PM
    ash1055
    Robert
    Thanks,
    I did cycle the ignition. Disconnected the battery. the 4WD lights turned off for a few minutes. So I might get brakes looked at tomorrow.
    Thanks
    Rob
  4. Dec 9, 2019 at 9:52 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The E-Brake is just a small drum brake on the inside of the rear rotors operated by a cable. Moving 5 feet with the parking brake on shouldn't have caused any damage. You could always take off the rear rotors and inspect the shoes. Make sure not the have the parking brake on if you do remove the rear rotors. Made that mistake once and won't do that again.
  5. Dec 9, 2019 at 12:12 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    One of my backup lights popped and blew the fuse inside the cab when I was reversing into my driveway with the e-brake on.
    I had similar lights flashing on the dash, too.
    Check your fuses.
