Lights on the cluster blinking like a Christmas tree
Discussion in '2nd Gen Tundras (2007-2013)' started by winemule, Oct 19, 2017.
  1. Oct 19, 2017 at 11:11 AM
    winemule
    winemule [OP] New Member
    Jerry
    Cincinnati OH
    14 Tundra Crew Max
    Helpping a friend with his 2011 double cab. 4HI & 4LO flashing back and forth, ABS and Anti skid light on. Pulled the code and said bad rt rear speed sensor. Changed it and still flashing. Has anyone else had this issue. Dealer wants to change harness from the engine compartment to the rear of the truck at $3900. But said that may not fix it.
  2. Oct 19, 2017 at 11:22 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    isn't that when you need to do a zero point calibration? What happened before he got the flashing lights - did he happen to plug in techstream or something?
  3. Oct 19, 2017 at 11:25 AM
    winemule
    Jerry
    Cincinnati OH
    14 Tundra Crew Max
    no, it started with the 4hi-lo flashing back and forth, within a couple of days the abs and anti skid came on. He took it to the dealer. they charged him $400 just to check it and came back with the hi estimate
  4. Oct 19, 2017 at 11:27 AM
    tomsinamerica
    Tom
    Wilmington, NC
    i'd do a ZPC to be sure...
  5. Oct 19, 2017 at 11:28 AM
    winemule
    Jerry
    Cincinnati OH
    14 Tundra Crew Max
    thanks we will try that
  6. Oct 19, 2017 at 11:32 AM
    tomsinamerica
    Tom
    Wilmington, NC
    my 4R lights up like a christmas tree if it loses ZPC
  7. Oct 19, 2017 at 12:07 PM
    theboy12
    theboy12 New Member
    Jon
    2013 Sequoia
    I had this issue in my tacoma. Check the kick panel on the driver's side and see if water got down into where the connector is and gummed it up.
  8. Oct 19, 2017 at 12:08 PM
    theboy12
    theboy12 New Member
    Jon
    2013 Sequoia
    Dealer wanted 1800 to redo the harness. It ended up costing me a can of electrical cleaner 20 minutes and some dialectical grease. -Jon
    Wynnded likes this.
  9. Oct 19, 2017 at 12:41 PM
    TheBeast The Beach
  10. Oct 19, 2017 at 1:57 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    I was thinking the AIP to. That makes the idiot lights do crazy things.
    Did it throw the check engine light ?
  11. Oct 21, 2017 at 6:58 AM
    winemule
    Jerry
    Cincinnati OH
    14 Tundra Crew Max
    no check engine light
  12. Oct 21, 2017 at 7:05 AM
    winemule
    Jerry
    Cincinnati OH
    14 Tundra Crew Max
    don't mean to sound stupid, what is the AIP
  13. Oct 21, 2017 at 7:09 AM
    Theyfzman
    Pa
    08 TRD
    Air injection pump
  14. Oct 21, 2017 at 7:15 AM
    winemule
    Jerry
    Cincinnati OH
    14 Tundra Crew Max
    Thanks,
  15. Oct 21, 2017 at 9:48 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    A buddy had this. It was a broken wire in the harness to the wheel sensor. Dealer ran a new single wire. No idea the cost.
    theboy12 likes this.
  16. Oct 22, 2017 at 10:08 PM
    theboy12
    theboy12 New Member
    Jon
    2013 Sequoia
    Nice post. Hope that is an easy fix.
  17. Nov 12, 2017 at 2:19 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Same thing happened to me, but no codes. I’m in a 201 CM.
  18. Nov 12, 2017 at 5:41 AM
    winemule
    Jerry
    Cincinnati OH
    14 Tundra Crew Max
    we went through a series of parts swaps because I had the parts on the parts. First the the injection pump, no luck. Then the rear ABS wiring, no luck. Then I took it to a shop that specializes in wiring issues, bingo, broken wire somewhere in the right side to the rear. They ran a separate wire and that fix the ABS issue, not the 4 wheel drive issue. The actuator in the transfer case is bad. Two issues that manifested themselves within 2 days of each other.
  19. Nov 12, 2017 at 5:42 AM
    winemule
    Jerry
    Cincinnati OH
    14 Tundra Crew Max
    Thanks for everyones input. Sounds like Toyota has an issues with the wiring harness.
