Lightning help
Discussion in 'Lighting' started by ryanw58, Nov 29, 2021.
  1. Nov 29, 2021 at 7:58 PM
    ryanw58
    ryanw58 [OP] New Member
    Ryan
    TRD Pro
    Looking for some guidance with lights. I own a 21 pro. I’m looking to order my bumper soon and would like some lighting advice. My plan was to use the factory fogs in the new bumper then get some new ones up top. What are the pros and cons of amber lights vs leds?
  2. Nov 29, 2021 at 8:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Amber is just a color. Are you asking halogen vs. led? Is this for the street or offroad?
  3. Nov 30, 2021 at 3:46 AM
    ryanw58
    Ryan
    TRD Pro
    I would probably turn them on as high beams on back roads and off road. I know that amber is just the colored ones but do they provide some sort of better lighting than led
  4. Nov 30, 2021 at 3:59 AM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Amber light diffuses much better in bad conditions, thus being able to see farther into things such as fog, snow storms, sand storms, etc.
    White light has the tendency to reflect off heavy fog, snow storms, etc causing a "blinding haze" effect and suffocates much of the light effectively reducing how well you can see into those things.
    Most people don't care for either explanation and just go for the aesthetics lol.
  5. Nov 30, 2021 at 12:17 PM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    Take your fog relay ground out the left side bend out terminal, then put a jumper on the bend terminal (to ground out fogs) run to headlight very top terminal relay. You’ll have high beams and fogs. I have a spare fog relay for inspection. Drive nights and deer everywhere. Running ditch side shooters hidden 30” bumper and highs and fogs while driving it’s like day. Plus I keep auto highs on all the time so I don’t need to switch to low, they automatically do I just hit my other light switch to turn ditch and bumpers off. Auto highs work excellent on our trucks.
