Lightest Weight Most Durable Off Road Wheels And Tires
Discussion in 'Wheels & Tires' started by TheGlamourousOne, Apr 25, 2019.
  1. Apr 25, 2019 at 9:57 AM
    TheGlamourousOne
    TheGlamourousOne [OP] New Member
    Henry W Bell III
    Who sells the lightest weight most durable off-road wheels and tires for a 2019 Toyota Tundra SR5 Crew Max
  2. Apr 25, 2019 at 3:41 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    You're going to be hard pressed to find someone to give you an answer on this, other than telling you to search for yourself.
    I would honestly just go on tirerack or discount tire and find yourself whatever size you want in a C load range.
    Backslider and GODZILLA like this.
  3. Apr 25, 2019 at 3:46 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Seriously... Lightest most durable? Cheapest as well I assume?
    There is no answer to this!
    What if one is 99% durable at 10lbs and another is 95% durable at 9 lbs? Which is the lightest most durable between those two?
    Made up #'s of course, but you get my drift.
  4. Apr 25, 2019 at 3:49 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Sure there is an answer. Just need the data.
  5. Apr 25, 2019 at 4:04 PM
    PermaFrostTRD
    Northern NY
    Tiresize.com. Plug in your size. Compare tire weights in that size.
    Heaviest to lightest for some common all terrains:
    Falken WildPeak At3w > bfg KO2s > cooper disco at3 xlt
    dpast88 and GODZILLA like this.
  6. Apr 25, 2019 at 4:11 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Wheels... Volk Racing TE37s are forged monoblocks and for sure one of the strongest/durable wheels on the market but they're $$$$$.
    Toyota10s, Ltaco17 and Rex Kramer like this.
  7. Apr 27, 2019 at 5:34 PM
    Mtran92844
    Mtran92844 New Member
    I can’t even find a set for sale.
    jagged155 likes this.
  8. Apr 27, 2019 at 6:30 PM
    Nick T
    Nick T New Member
    Nick
    Rock warrior wheels, forged and factory oem
  9. Apr 27, 2019 at 7:16 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    They are sold exclusively by the
  10. Apr 27, 2019 at 7:30 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    TE37 is the correct answer... roughly $3000-3500 a set for 18s, quite a bit more for 20s and 22s (wheels only, no tires)
  11. May 18, 2019 at 6:04 AM
    Joshgonz1024
    Joshgonz1024 New Member
    Josh
    DFW: Dallas
    2017 Tundra TSS
    Fox 2.0 Coilover & 2.0 rears, bed stiffeners, swingcase(junk), KC foglights, RCI skidplate, intake & throttle body mod. More to come...
    Stay away from mud tires, they are heavy. Ko2 and duratracs are “lighter”about 5lbs per tire than the others aggressive at tires(Coopers/Nitto).
    Also Lt tires are heavier than p-type, just depends on what you do.
    equin likes this.
  12. May 18, 2019 at 11:55 AM
    Mtran92844
    Where can I find a set of 18?
  13. May 18, 2019 at 12:26 PM
    reelcracker
    reelcracker Just a squirrel trying to get a nut
    Farva
    2018 off-road d/c
    Tyger steps, 6 " pro comp lift with fox rears, 20" drop stars -25 offset, toyo m/t's 35x12.50
  14. May 18, 2019 at 12:30 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Check out Mastercraft Courser CXT. They are lighter than other tires in the same size with the same load rating. They look great and perform well. They are a Cooper Tire company and are made to the same standards.
    dpast88, equin and Sunnier like this.
  15. May 18, 2019 at 6:27 PM
    ninjajay
    Spoolston, TX
    Ravspec, vivid racing, icb motorsport, I was quoted a 3 month wait to order
  16. May 18, 2019 at 6:45 PM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    Method 313 in a 17” is probably the lightest and strongest rim. It weighs 23.5 lbs. The rest is up to you
  17. May 18, 2019 at 8:01 PM
    Makoy339
    Super White TRD
    TRD parts
  18. May 19, 2019 at 5:17 AM
    RBDTx
    RBDTx New Member
    2019 Tundra TRD Pro White
    Bridgestone Dueler A/T Revo 3’s are quite light compared to all other brands, and, while not one of the more popular tires on this forum, three sets of 2’s have served me very well on the road and Texas Hill Country rock/sticky mud. The Bridgestone site shows LT285/65R18 to be 49 lbs, which I have found to be 5 or more pounds lighter than same size tire in every other tire I have checked.
  19. May 30, 2019 at 2:26 PM
    flinky14
    flinky14 If I'm the wife, who says no to new mods?
    Genna
    Alberta
    2019 Tundra CM Platinum 4x4
    -TRD Dual Exhaust - 3m - UV front window tint/rear limo tint -TRD Oil Cap -Toyota Bed Mat - TRD Pro Grille - ARE canopy (sliding Windoors, pop down sliding front window, headliner, rack rails) -OEM Toyota Remote Starter -Baja Designs Sport Fog Lights -TRD door sill protectors -Ronin Factory short antenna
    FN wheels are lightweight and I have heard good things on durability
    Hurricane and Big J like this.
  20. May 30, 2019 at 2:39 PM
    blizz86
    blizz86 New Member
    These methods are flow formed so they will be stronger than typical cast wheels, not as strong as forged but not as expensive either. Certain FN wheels are also flow formed and a bit lower priced vs the method 313.
    equin likes this.
  21. Jun 23, 2020 at 11:55 AM
    yellowledvetter
    yellowledvetter New Member
    Duratracs are lighter than comparable brands
  22. Jun 23, 2020 at 12:04 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
  23. Jun 23, 2020 at 12:09 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
  24. Jun 23, 2020 at 12:22 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Try evasivemotorsports I was able to get my gram light from them within a week. They also have the new te37xt mspec in stock according to the site
  25. Jun 23, 2020 at 12:24 PM
    cctxquicksand
    Also showstopper off-road
  26. Jun 25, 2020 at 5:58 AM
    Elduder
    Elduder New Member
    FN Fx Pros are just over 26 lbs for a 18x9, they also have a 2700 lb load rating if I remember correctly.
  27. Jun 25, 2020 at 6:12 AM
    tennisfreak
    tennisfreak New Member
  28. Jun 25, 2020 at 6:14 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Method 202 would be my vote. Not cheap! Nearly $4K for a set. 250B9FBC-E751-46CC-B9A5-B3C86F486C75.jpg
    831Tun likes this.
  29. Jun 27, 2020 at 2:50 PM
    Redcon41318
    Redcon41318 New Member
    Just curious is there a factor in wheels, how light is too light?
  30. Jun 27, 2020 at 2:55 PM
    Elduder
    Elduder New Member
    Just make sure the load rating is high enough. Anything greater than 2400-2500lb is good and strong. I wouldnt venture into anything less than 2400lb per corner, if you can even find something that fits our trucks with that load rating.
