Light constant chirping noise when accelerating
Discussion in '1st Gen Tundras (2000-2006)' started by Can Can, May 4, 2021.
  1. May 4, 2021 at 2:08 PM
    Can Can
    Can Can [OP] New Member
    Hello everyone! I live in Montana and we are finally getting some spring weather. Naturally I rolled down the windows to enjoy the weather... and thats when I noticed a chirping/squealing noise. Its relatively quiet, can only hear it when the window are down, and I can only hear it when accelerating while in drive. It does not make the noise when I let off the gas peddle. I parked the truck, revved the engine a few time and didn't hear anything.
    Have any of you experienced this before? It almost sounds like its coming from the rear. I'm just wondering if this is the beginning signs of a possible failing rear diff, or maybe some yoke bearings going bad?
    I know this is pretty vague, but I was hoping that some of you might have had this problem before I dig into it. Thanks in advance for any help. Cheers!
  2. May 4, 2021 at 2:31 PM
    DSLKSL
    DSLKSL New Member
    Don
    Press the gas pedal more and see if it gets louder :)
    bmf4069, Black Wolf and Darkness like this.
  3. May 4, 2021 at 2:36 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    How’s the transmission fluid look?
  4. May 4, 2021 at 3:06 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If at low speed, could be rear ujoints need a little grease ??
    FrenchToasty likes this.
  5. May 4, 2021 at 3:07 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    If it's fair to characterize the sound you hear as whistling, versus chirping, then there are other threads on here that have discussed this "faint whistling sound during hard acceleration".
  6. May 4, 2021 at 4:41 PM
    Serpentine belt? Classic for chirping and squealing.
  7. May 4, 2021 at 5:23 PM
    Professional Hand Model
    Hand Protectors
    I heard a Chirp the other day. Got out and it was three little birds on my door step telling me to not worry about a thing and stay home and work on my truck.
    Dannydirtyfingers and MrAristo like this.
  8. May 4, 2021 at 5:41 PM
    Can Can
    I would possible consider it a whistling noise. I took it to the mechanic the other day for some other stuff and a check up and they said they couldn't look at the tranny fluid because i have a rust coating on the truck. Im planning on checking the tranny fluid tomorrow. I have only heard it at low speeds. Ill keep you all updated. Thanks for all the hints.
  9. May 4, 2021 at 5:49 PM
    Gungoboom
    Gungoboom New Member
    2002 Tundra SR5 AC 4x4
    ??? I am not a mechanic so can someone explain that to me.
  10. May 4, 2021 at 5:51 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Sounds like a u-joint to me. Chock the wheels, shift to neutral (engine off) and shake the driveshaft at each joint to see if any have play in the u-joints. Also inspect for any rust streaking between the u-joint cross and caps.
  11. May 4, 2021 at 5:52 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I am a mechanic, can someone please explain that to me as well? :confused: :monocle:
  12. May 4, 2021 at 6:04 PM
    Can Can
    Rust protection coating*
  13. May 4, 2021 at 6:23 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Still makes no sense as to why the transmission fluid can’t be checked. Not that I suspect a transmission issue.
  14. May 4, 2021 at 8:48 PM
    remington351
    2006 SR5 DoubleCab
    My guess is:
    1. You selected a very bad mechanic
    2. Some DIY'er thought it would be a good idea to spray undercoat on the transmission pan
    3. Same Diy'er sprayed bed liner as undercoat
    4. Mechanic was lazy, couldn't find the dipstick and didn't feel like messing with it, then having to argue with the owner why he charged 1hr shop labor to heat the fluid to Toyota spec just to check with Toyota's dumbazz drip hole
  15. May 4, 2021 at 9:23 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  16. May 4, 2021 at 9:27 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    McRib is back?...
    bmf4069 and landphil[QUOTED] like this.
  17. May 4, 2021 at 9:34 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Could be your carrier bearing going bad :notsure:maxresdefault.jpg
