Light choices behind grille
Discussion in 'Lighting' started by SHAP357, Jan 3, 2019.
  1. Jan 3, 2019 at 8:00 AM
    SHAP357
    SHAP357 [OP] New Member
    2015 MGM Tundra SR5
    1.75 lift front/rear
    Im looking to get some more light on this truck since the stock headlights and fogs are terrible. I’ve been considering either a 30 inch single row bar in the lower bumper cut out, or something behind the Pro grille I installed. I’m figuring if the light is behind the grille and not down low, the throw will be better. Any insight to this?
    I like the driving kit by Diode Dynamics (2 single row bars mounted behind the grille) but their kit doesn’t work with the Pro grille as the lights would sit too high. I could always modify the mounts, no big deal. Anyone use DD and been pleased with the results?
    My other idea was mounting 2 10 inch BD S8s behind the grille like the DD driving kit. I like this over a single bar but I’m curious if anyone here has ever done that before?
    Thank you all.
  2. Jan 3, 2019 at 9:07 AM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
