Light bar size behind a TRD Pro grill
Discussion in 'Lighting' started by Stumpjumper, Sep 11, 2017.
  1. Sep 11, 2017 at 11:03 AM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Before I got my grill I had ordered a 32" light bar. I was planning to install in the lower opening below the license plate but instead I installed behind the grill. After installing the grill and light bar I think that I should have ordered a 40". What fits best a straight or curved 40-42"? Also is anyone running a light bar in both locations? The one I have is plenty bright enough but I am really tempted to go longer. I do not like having unused stuff sitting around so I thought that I would install both even though one seems to put out enough light. Also, I do not want to negatively affect the radiator cooling.
  2. Sep 11, 2017 at 12:15 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    I am running the Rough Country LED LB in the lower bumper for a really clean fit and finish. It's very very bright.
    Thought about running the Headlight Revolution LB behind the grill. You can google both or do a search on here. Both are fairly reasonably priced for off road lighting.
    I like the RC which comes with really strong rock solid black wrinkle powder coated mounting brackets. Rigid and Baja design are nice lights, but since I am not running the Dakar Rally and use my LB so little, I went with RC, 3 yr warranty. Happy.
    RC- disregard the reflection on the top of the cab, trick photography, which I don't know how to untrick.
  3. Sep 11, 2017 at 2:13 PM
    tundraoverland1
    tundraoverland1 New Member
    Las Vegas
    2015 White Tundra crewmax TRD 4x4
    IG: sfarrisjr88
    stefan702 likes this.
  4. Sep 11, 2017 at 2:33 PM
    I have a 42" no name brand i bought off Craigslist with the Pro grille...42" fits perfectKIMG0200.jpg
    GAknight and Eclipsed & Floating like this.
  5. Sep 11, 2017 at 6:56 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Straight or curved? Looks like you have on above the license plate too. I was thinking about doing the same thing even though the 32" I have behind the grill puts out plenty of light. Not sure I need 2 or even if I would notice much difference.
  6. Sep 11, 2017 at 7:06 PM
    It's a straight...one above license plate is from Rough Country was made for Tundra...but I've seen on here some other guys have a double row as well...Headlight Revolution.com makes one for inside for PRO grille has a cool HALO switch... I'm looking into ditch lights as well Ragofabrication.com sells brackets
    davezlowkey likes this.
  7. Sep 12, 2017 at 12:52 AM
    ubserved
    ubserved New Member
    Michael
    2017 Toytota Tundra Platinum Crewmax
    Grillguard, front LED light bar, Leer Tonneau cover, rear LED bars
    I like the led bars from rugged country. They are incredibly bright and look absolutely stunning.
  8. Sep 12, 2017 at 1:07 AM
    Rough Country?
  9. Sep 12, 2017 at 1:26 AM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I'm running 2 40s in the grill and one in the bumper.
    Mine are not very noticeable which I was going for.
    JH5370 and blue16 like this.
  10. Sep 12, 2017 at 3:30 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Are you running off 1 or 2 wiring harnesses and switches? The combo I am looking at would be 35 amps. I would prefer to run off one harness but I believe 35 amps would be bumping right up against the limit of my wiring.
  11. Sep 12, 2017 at 4:05 AM
    2 hrn and 2 sw ... I'm not a wiring expert sorry
  12. Sep 12, 2017 at 8:56 AM
    ubserved
    ubserved New Member
    Michael
    Yes. I went with the black series. A double stack 30" in front and two 2x8 units on either side of the tow package tucked up underneath the rear bumper. Those rear units are insanely bright. Great when you need more light behind your or when some moron wants to tailgate you. 8)
    http://www.roughcountry.com/lighting-and-accessories/lights.html
  13. Sep 12, 2017 at 10:32 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    had a F150 with a switched 300w KC on the roll bar/light bar for the tailgaters. I think just seeing that KC up there discouraged them. Only a little sports car would be bothered by the 18 watt back up lights I installed. I have the the solution for adding a 40" bar behind the grill and the 32" down below. When I bought the 32" I also bought a relay not knowing that one came with the light bar. Since I prefer one switch and already have the relay I can split the output form the switch to 2 relays. The easy way is to run one relay and split the wires to the light. I just not comfortable running 35 amps on 12 gauge wire. Looks like I am buying another light bar.
  14. Sep 12, 2017 at 12:45 PM
    ubserved
    ubserved New Member
    Michael
    I actually didn't use their provided switch. I had separate plasmaglow switches installed, one for the front and one for the rear.
  15. Sep 12, 2017 at 6:01 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I did not use supplied switch on mine. It was a rocker and I wanted a push button to fit slot left of steering wheel. I have not wired up one switch to 2 relays but do not see a problem. On my Tacoma I had 4 KCs on 2 switches and 2 relays because one set was driving lights and the other was spots.
  16. Oct 2, 2017 at 3:38 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Any impact on the engine cooling? I would think that with the reduction in air flow you might be running a little warmer.
  17. Oct 2, 2017 at 11:46 PM
    BOBONTUESDAY
    2016 Limited Trd
    Runs the same. Always below the middle. I tow a good amount and there's no problems. Idle a lot also 105k 0 problems. But I am in Minnesota I'm not dealing with like Califorina heat.
    The bars don't cover the whole rad. I've done a similar setup on a friend's raptor 0 problems.
  18. Oct 3, 2017 at 7:30 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Rago Fabrication Ditch light brackets and Freedom Light Pods from Rago Fabrication.
    blue16 and Eclipsed & Floating like this.
  19. Oct 3, 2017 at 7:32 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    It looks like the metal cattle gate fence you hit stuck to the front of your truck.:fistbump:
    You know I'm just playing, right??
  20. Oct 3, 2017 at 9:44 AM
    I got you brother it's all good LOL
  21. Oct 3, 2017 at 9:46 AM
    That's awesome sauce!!!
  22. Oct 3, 2017 at 10:14 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thanks Adam!! It wasn’t hard to install either..
  23. Oct 3, 2017 at 9:20 PM
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    A rigid 40 fits perfectly flush with the grill.
    RedRegCab, Njmike13 and blue16 like this.
  24. Dec 9, 2017 at 7:02 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Did you mount the bar to the grille or is it mounted to something sturdier behind the grille?
  25. Dec 28, 2017 at 7:32 PM
    ubserved
    ubserved New Member
    Michael
    I actually bought two plasma glow switches and mounted them on the lower right side on the bottom part of the dash near to my right knee when sitting in the truck. One red for the rear lights, one blue one for the front, the buttons light up when they are activated. I even went one step further and had them tied into my viper alarm remote. I the aux button and the front and rear lights come one, hit it again they turn off. Works wonderfully.
  26. Feb 14, 2018 at 11:16 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    How did you mount this? I was going to mount a light behind the grill but I like that your light is flush.
    Thanks,
  27. Feb 14, 2018 at 11:32 AM
    @inferno_pro_satx
    Curious as well..cause I like to take off my PRO grille every now and then to brush out debris from radiator
  28. Feb 14, 2018 at 7:38 PM
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    @1UPPER Did it first lol, he gave me the locations where to mount the brackets. I didn’t save them. Maybe he can share !!
    1UPPER likes this.
  29. Feb 14, 2018 at 7:54 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
  30. Feb 14, 2018 at 8:00 PM
    1UPPER[QUOTED] likes this.
